1. fun4jad's Avatar
    Having trouble connecting my PC to my Droid Turbo 2:
    1) every time I connect, it sees the device, but I have to change it from MTP to charge, then back to MTP to see any disk
    2) when I do this little trick, it only sees the SD card, not the internal storage
    Running Android 7.0 system version 25.11.10.kinze_verizon.verizon.en.US (FWIW)
    Like not to play this little game every time I connect (keep it in MTP).
    I think the 2nd part is because I'm running adoptable storage, so it may not be an issue, but frustrated with the first issue - any help would be appreciated!
    Thanks,
    Jerry
    04-11-2017 09:22 AM
  2. doogald's Avatar
    If you adopted storage, the SD card *is* internal storage. I'm not sure why you have to play the MTP shuffle to connect, but only using an SD card as portable storage would show both internal and SD card external discretely.
    04-11-2017 10:42 AM
  1. Replies: 3
    Last Post: 05-07-2017, 06:36 PM
  2. Replies: 3
    Last Post: 04-26-2017, 08:58 AM
  3. How to embed a hyperlink in SMS message
    By Mr Mendelli in forum Ask a Question
    Last Post: 04-12-2017, 12:19 AM
  4. How to stop screenshots from saving twice
    By Zeshan Mian in forum Android 7.0 Nougat
    Last Post: 04-11-2017, 08:57 PM
  5. Connecting and disconnecting
    Last Post: 04-11-2017, 08:05 AM
