1. Ema Seijas's Avatar
    I have a Droid Turbo 2 running Marshmallow. After Nougat was released, I updated my phone and it was pretty much bricked because it didn't accept any chargers, and when it randomly did, my battery power plummeted. I was still within warranty so I ordered a new phone from Motorola and was back to "the good ole days" of prime battery power that lasted me two days. I haven't updated my phone to Nougat out of fear that the same problem will happen, but after having the replacement phone for only about three weeks, my battery is useless again, as if I've updated to Nougat. My phone takes forever to charge, runs hot, and drains within three or four hours. This didn't happen the first couple weeks I had it, I noticed it happen when Spotify suddenly deleted my 1200 saved songs from my phone. I tried redownloading them and the battery life has bever been the same. I've since uninstalled Spotify, but if anything, the battery life has gotten worse. I can barely use my phone now without needing it on the charger. My battery monitor is useless because according to it, I shouldn't be using this much battery. Again, I'm running Marshmallow, but it seems to have a kind of Nougat-y feel to it. Is there any way to fix this? I'm now out of warranty and I want to be done with this phone, but I'm stuck with it for now.
    Battery tanking on Marshmallow-tmp_10619-screenshot_20170424-1201331177334975.jpgBattery tanking on Marshmallow-tmp_10619-screenshot_20170424-120138756174689.jpgBattery tanking on Marshmallow-tmp_10619-screenshot_20170424-120145299948695.jpg
    04-24-2017 03:11 PM
  2. KeithLa's Avatar
    I'm experiencing exactly these symptoms on a new DT2 (replacement) purchased from Motorola in February, however it's upgraded to Nougat. Wasn't a problem until the past week, suddenly it's running very hot (even to 110F and higher) even just sitting idle with screen off. Battery draining rapidly, even while in standby screen off.
    Obviously something in background is causing this, but I can't correlate to *any* new apps or updates. No particular app or process pops in Battery settings or the CPU cooling app I installed.
    05-07-2017 01:27 PM
  3. Ema Seijas's Avatar
    Yikes. An update to Nougat (surprisingly enough) fixed my problem.... I was never able to find out what the problem was either, although this sounds less like a spontaneous Marshmallow problem and more of the run-of-the-mill Nougat issues everyone's been having... Hopefully they come out with an update soon.
    05-07-2017 04:13 PM
  1. Replies: 0
    Last Post: 04-24-2017, 03:07 PM
  2. Replies: 0
    Last Post: 04-24-2017, 02:38 PM
  3. Replies: 0
    Last Post: 04-24-2017, 02:36 PM
  4. Replies: 1
    Last Post: 04-24-2017, 03:13 AM
