1. darkSSide's Avatar
    Ok here is the problem. My battery is draining fast! Once it gets to 100% with some use on the internet within an hour it's at 50%. To top it off once it gets to 44% when in use it shuts off. If I turn it back on it will go through it's motions but once at the home screen it will shut off like it had no charge. Now if I hook it up to the charger and turn it on it will stay on.
    Do you think the battery needs to be replaced or is there something else going on?
    Any help in the right direction is very much appreciated. Thanks
    09-05-2018 09:34 AM
  2. B. Diddy's Avatar
    That's classic behavior for a failing battery. I think you probably need to get it replaced, if you want to continue using that phone.
    darkSSide likes this.
    09-05-2018 11:10 AM
  3. darkSSide's Avatar
    Ok good to know. I wouldn't want to waste money on changing a battery and it kept on turning off on me.
    Thanks
    09-05-2018 11:15 AM
  4. B. Diddy's Avatar
    Be aware that there's always a possibility it could be something else related to the charging circuits, so I can't guarantee it's an isolated battery issue. But the behavior is classic, so that's the first thing to try.
    09-05-2018 12:06 PM
  5. Scott337's Avatar
    The Turbo 2 did have issues with the charging process, with numerous phones that would just not charge at all using any micro-USB cable. I had two affected by that issue. If yours is currently charging OK but losing the charge fast it doesn't sound like you are affected by the failed port / charge circuit issue that affect yes so many of us.
    09-05-2018 03:18 PM
  6. darkSSide's Avatar
    My wife's has that issue so she only uses a wireless charger
    09-05-2018 03:42 PM
  7. Lucy Davies's Avatar
    I had issues like this & now it turns off at any percentage. Was due an upgrade anyway so got a new phone.
    10-11-2018 04:43 PM
  1. Issue with ram management and camere and performance on my my Lg Q Stylus
    Last Post: 09-05-2018, 11:17 AM
  2. Why is my battery draining so fast
    Last Post: 09-05-2018, 11:13 AM
  3. Option to show battery percentage is missing from system ui tuner
    Last Post: 09-04-2018, 07:27 PM
  4. Android battery monitor not responding
    By Zul Hairi Mohd Yusof in forum General Help and How To
    Last Post: 09-04-2018, 07:24 PM
  5. Twitter issue....
    By TANDC in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-04-2018, 06:44 PM
