Android Nougat 7.0 esta optimizado en Motorola Droid Turbo 2 de Verizon?
Tal parece que la actualizacion a nougat destruyo la bateria,pues ahora no dura ni la mitad de lo q deberia,ya se hizo wipe cache,calibrado de bateria y hasta reestablecimiento de fabrica desde el celular mismo y por lo que averigue no se puede rootear el movil,ni desbloquear el gestor de arranque,tienen alguna solucion comprobada?,gracias.
Re: Android Nougat 7.0 esta optimizado en Motorola Droid Turbo 2 de Verizon?
English translation :
Is Android Nougat 7.0 optimized for Motorola Droid Turbo 2 from Verizon?
It seems that the update to nougat destroyed the battery, because now it does not last even half of what it should, it has already been done wipe cache, calibrated battery and even factory reset from the cell phone itself and for what it finds out it cannot be rooted the mobile, or unlock the bootloader, have any proven solution ?, thanks.
Welcome to Android Central! Just to be sure -- when you say you wiped cache, you mean that you wiped the system cache partition, and not just the individual app caches, correct?
How's the cell signal strength? Poor cell signal can kill battery quickly.
Gracias por la bienvenida,efectivamente todo lo hice desde el sistema mismo,otros usuarios reportaron problemas similares,se que el Moto x force pudo resolver este problema desbloqueando el gestor de arranque y que tambien es rooteable,mi consulta basicamente es ¿hay forma de combatir el drenaje de bateria en nougat?,por que sinceramente no veo otra razon coherente,pus con Marshmallow esto no pasaba.
^ [Google Translate from Spanish:]
"Thanks for the welcome, indeed I did everything from the system itself, other users reported similar problems, I know that the Moto x force was able to solve this problem by unlocking the bootloader and that it is also rootable, my query is basically is there a way to combat the drain of the battery in nougat?, because I honestly do not see another coherent reason, pus with Marshmallow this did not happen."
The battery is almost 4 years old (and it's a pretty small battery). Maybe it's time to replace it. If you regularly let the battery drop to less than 40% before recharging, that's also bad for it.
Traducción de Google: la batería tiene casi 4 años (y es una batería bastante pequeña). Tal vez es hora de reemplazarlo. Si regularmente deja que la batería caiga a menos del 40% antes de recargar, eso también es malo.
