1. hal1's Avatar
    The 2 bodies have 2 different thicknesses 10.6mm & 11.2. Does this mean 2 different cases or is the .6mm not relevant?
    Yes, I'm a bit anal.
    10-29-2014 10:13 PM
  2. maxman1's Avatar
    I've wondered this as well and AFAIK, no one else knows either. The local Verizon folks had no clue about the different sizes between the 2 outer cover materials. My "guess" is, will depend on the case - those with generous tolerance might work for both, those really tight may not. I'm going to just leave mine "as is" and use a generic pouch until the dust settles. FWIW, the ballistic nylon looks like it's built like a tank.
    10-29-2014 10:52 PM
  3. Unobtanium's Avatar
    Check out the answer from Joe the Insider (VZW Employee) in this thread
    10-30-2014 04:49 AM
  1. Verizon Motorola Droid Turbo Ordering from Motorola
    By Joe378 in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 10:41 AM
  2. Replies: 1
    Last Post: 10-30-2014, 08:55 AM
  3. Motorola turbo is released
    By trucksmoveamerica#AC in forum Samsung Galaxy Note 4
    Last Post: 10-30-2014, 08:08 AM
