06-13-2015 07:39 AM
74 123
tools
  1. Jack Jawczak's Avatar
    Interesting. Didn't see that in the Otterbox details when ordering the 64GB and case tonight. Will know soon enough. I'm not worried though since I can throw a machine shop at it
    11-16-2014 07:48 PM
  2. Jack Jawczak's Avatar
    I have the Turbo, 64g version with ballistic nylon and my Otterbox case fits perfectly.
    11-16-2014 07:49 PM
  3. Emperor's Avatar
    I picked up the Case Mate Naked Tough Case for my 64GB Turbo. Perfect fit.
    https://forums.androidcentral.com/e?...token=i18gFiuI
    Turbo 64GB Beast
    11-16-2014 09:59 PM
  4. maxman1's Avatar
    https://forums.androidcentral.com/e?...token=Y3teHcAv
    Turbo 64GB Beast
    My current choice as well. I also have the Incipio Dual Pro and have not experienced any of the problems expressed by others with the rubber dimples marring my 64GB BN. Although not as "grippy" as some, the CM is thin, offers moderate protection while not hiding the phone and fits a belt pouch easily.
    11-16-2014 10:29 PM
  5. 1BlinkGone's Avatar
    I almost went with the OtterBox Commuter case, even though I thought the Incipio case in red looked better and nearly as solid. I ended up going with the Verizon brand Shell/ Holster Combo with Kickstand since it covers the ear piece for while I'm at work, and is easy enough to take off for when I get home. I work in sheetmetal fabrication and am sick of the ear speakers on my phones going bad from exposure to metal dust. Hopefully this helps....
    All three fit my 64GB Ballistic Nylon model without issue.
    I too, have the same holster/cover set that Verizon sells with the nifty kickstand. Fits in my 32GB Ballistic Nylon Turbo just fine, and I think it's a decent case. I DO wish it had an inside layer of rubber for shock suppression, but the phone seems like it's built like a tank anyway.
    leehardballer12 likes this.
    11-16-2014 11:40 PM
  6. garyart1's Avatar
    https://forums.androidcentral.com/e?...token=EZvvj3Au
    Turbo 64GB Beast
    I picked up this same case also but I am only using the clear bumper ring and not the back. I was looking for just a bumper being I like the look of the BN back and this is the closest I came. It fits well and offers a little more protection than being totally naked. It also keeps the screen raised when laid face down and gives turbo a little more grip. I like this combo.
    leehardballer12 and reddingb like this.
    11-17-2014 08:17 AM
  7. Stratman Rick's Avatar
    Just ordered that Naked case. Thanks Guys.
    11-20-2014 11:44 AM
  8. JimBen73's Avatar
    I'm using the flip cover
    sent turbo fast
    11-20-2014 01:03 PM
  9. wheelerpr's Avatar
    sent turbo fast
    How do you like it? Does it work well and do the wave to view notifications still work?
    11-20-2014 02:16 PM
  10. DroidTurbo1's Avatar
    Same case for me on my 64GB BN, it fits great and gives the minimal protection/bulkiness I desired...but I like my tanks mostly naked
    PS. Kickstand is great for watching free NFL games on Verizon!
    11-20-2014 08:52 PM
  11. JimBen73's Avatar
    I like it because it gives me a better grip, the ballistic nylon feels a little slippery to me. If I wave my hand over it, it does nothing but as soon as I slightly open the case, the phone lights up. The phone does breathe when I get notifications and I can view them through the "window".
    sent turbo fast
    11-21-2014 12:29 AM
  12. ::Montgomery::'s Avatar
    Got a Tech21 and it fits the Ballistic Nylon
    Sent from my SM-G900V using Tapatalk
    I picked up this case yesterday and I am liking it so far.
    11-21-2014 07:44 AM
  13. Eclipse2K's Avatar
    The case does make hitting the volume keys and power button slightly more difficult than it would be on the MG version. Also, the top right corner does pop out in the pocket at times despite fitting firmly. I'm using this until the Tudia comes out for the BN version since I prefer thin cases.
    Sent from my Motorola Droid Turbo
    11-21-2014 06:46 PM
  14. graygr's Avatar
    Confused....why get the Ballistic Nylon model and then try to cover it up with a case?
    11-22-2014 07:59 PM
  15. Don Slyrocks's Avatar
    I put an Otterbox Defender with a SF 49ers logo on my 64 gb Droid Turbo Ballistic tonight and it fit just fine.
    It does work... I did it.
    Fits perfect.
    11-22-2014 08:27 PM
  16. Eclipse2K's Avatar
    64GB is one reason many do it. Also, the Ballistic Nylon doesn't protect it any more from edge damage.
    88horizon5speed likes this.
    11-22-2014 08:28 PM
  17. camachinist's Avatar
    Yeah, it could be made out of inconel and could still be easily damaged if not substantially protected from impacts and fluids in my business. Also, the case facilitates easy use of a simple integrated holster. However, I find I'm often carrying the phone in a coveralls pocket and that works too, screen in
    11-22-2014 09:49 PM
  18. leehardballer12's Avatar
    Mine comes out of the case as soon as I leave work! Lol
    I got the kickstand holster case so I could keep it out of my front jeans pocket since my job is pretty active and the phone is large. Also, with the holster, the front of the phone is facing the holster, so I'm hoping that helps protect against metal dust ruining my speakers. It also covers the phone well all around, so I'm not overly concerned about it getting nicked up hanging out on my belt.
    I have NFL Mobile set up on it now, so I may need to try out that kickstand.... ;-)
    11-23-2014 01:58 AM
  19. leehardballer12's Avatar
    I see what you mean....I think the way they handled that was by having those tabs in the back keep the phone from being flat against the case to provide a 'cushion'. It appears to do the job, since I've already dropped it flat on its back from waist high on the hard floor, with not even a scratch....good thing I still had it in the case and holster when it fell!
    11-23-2014 02:05 AM
  20. reddingb's Avatar
    Absolutely false. If the case does not state for the Ballistic Nylon version IT WILL NOT FIT. PERIOD!! Except for the Otterbox and the Incipio cases which allow the depth for both versions.
    12-20-2014 09:12 PM
  21. Bob Maida's Avatar
    OtterBox Commuter has been working perfect for me.... since I acquired the phone late October.
    12-21-2014 12:07 AM
  22. rxgadget's Avatar
    Thank you for contacting Seidioonline.com. We appreciate your interest in our products. We have not finalized plans to make products for the Ballistic Nylon version of the Droid Turbo yet. Your request has been forwarded to our product development team. If you would like to stay informed on future product releases for this device, we suggest periodically checking our online store, or you may sign up for email notifications here:http://www.seidioonline.com/Articles.asp?ID=303.
    If you have any questions or concerns, fell free to contact us at*832-204-1118.
    Thank you,
    Seidio Customer Service
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    12-23-2014 12:33 AM
  23. GADA 50's Avatar
    The cases definitely work I tried 5 different ones and they all fit fine my army green speck is my favorite.
    12-23-2014 12:39 AM
  24. rnd0209's Avatar
    Well I am currently using the speck candy case on my 64 and it fits like a glove. Great case.
    12-24-2014 09:51 PM
  25. Moo Cow's Avatar
    Fits perfect.
    Same here, except I dropped it and I busted up my toe and went on IR, the phone completely shut down after accumulating 21, um, "hours" last Saturday and got, ahem, overcharged when I tried to stretch a bit of overtime out of it. Also, I won't get much use of it after December, and my wife is likely leaving me for Michigan.
    Other than that, my 49ers Otterbox works fine, LOL!
    (But seriously, all bad jokes aside, it does work OK and fit perfectly. I have had no issues, although one thing I noticed between the Maxx and the Turbo is the direction of which the USB port protector swings open. Not a problem, but just something I noticed.)
    12-25-2014 02:48 AM
74 123
  1. Replies: 0
    Last Post: 11-03-2014, 01:33 PM
