Will there be a Developer Edition? ??????
I'm feeling very dumb right now, but I don't see a Moto option in settings. Is it called something else? Or something similar? I only see Motorola Privacy and Motorola ID.
Maybe you need to do the Motorola setup still? Try and run setup again.Sorry, here is my device headline in settings. I don't see it?
I read something about getting a minimum $100 off on the turbo with any functioning smartphone. Will Verizon accept a phone with a small corner of glass chipped off but that still boots?
What all of the bloat are you guys disabling? Specifically all the VZW junk....thanks
1901MADISON, Click on apps, click on moto, click on the little settings icon up in the corner, brings up screen with assist, actions, voice, display. Click on display, second choice is select apps. Hope this helps. I'm still learning myself, love it so far.
long press the power button then select silent.vibrate.sound
