We've got the DROID TURBO. Got questions? Ask us!
Masheen
499
10
Will there be a Developer Edition? ??????
Very good question. I was concerned I wouldn't be able to Root/Rom the Droid Maxx when I first got it. Then to my surprise, I realized that I had almost no reason to do so after seeing how stock-like it was and how fast the updates hit.
ghbishop
58
Re: Just Picked Up a Droid Turbo
Agreed - I got the 32g BN too and the blend was the first thing I noticed looking at it in the store.
rigg
Active member
Mar 26, 2014
34
When I hit the little microphone icon in the Google search bar at the top of the screen, it asks me "Complete Action Using"
1) Google
2) Moto Voice
Which should I select?
1901Madison
1,538
I'm feeling very dumb right now, but I don't see a Moto option in settings. Is it called something else? Or something similar? I only see Motorola Privacy and Motorola ID.
Masheen
499
10
its under the Device headline, which is the second heading, if you count Wireless & Networks as being first
Eclipse2K
5,722
107
Sorry, here is my device headline in settings. I don't see it?
Maybe you need to do the Motorola setup still? Try and run setup again.
If anyone is wondering how fast the WiFi can go (I'm on AC technology) well here you go.
Sent from my Motorola Droid Turbo[/QUOTE]
AndroidIsMyThing
81
I read something about getting a minimum $100 off on the turbo with any functioning smartphone. Will Verizon accept a phone with a small corner of glass chipped off but that still boots?
Xelios
131
They did with me. Didn't give me a single issue about it. As long as it boots was what I was told there.
Bill Fugle
4
1901MADISON, Click on apps, click on moto, click on the little settings icon up in the corner, brings up screen with assist, actions, voice, display. Click on display, second choice is select apps. Hope this helps. I'm still learning myself, love it so far.
Xelios
131
What all of the bloat are you guys disabling? Specifically all the VZW junk....thanks
I've taken out the amazon stuff, audible, cloud, familybase, google hindi/pinyin/korean stuff, help, message+, myinfozone, my verizon mobile, nfl mobile, slacker, verizon location agent, verizon support and protect, and VZ Navigator.
adam 968
5
Audio quality through earphones
Hi,
could you tell me something about the audio quality of the turbo? (compared to the maxx, for example)
The only reason I am leaning towards the Z3 is its DAC and relatively (for a phone) high music quality.
I know it is a bit complex, as the earphones and the music source play significant roles in the end result, ie the music listening experience.
I am not too satisfied with this on my maxx. Not even with good earphones and quality flac files.
Based on my experience, htc one m8 and iPhone 5s have been on the top of the chart in this respect, now joined by z3.
Thanks
EngineerGuy
100
Re: Audio quality through earphones
Dumb question, but is there a shortcut that I'm missing to put the phone into the vibrate or silence setting? The Razr had a slide out drawer off of the home screen which was handy for this task, along with toggling WiFi.
Thanks.
fonger13
129
How's the brightness on this phone? Can it be used out door on sunny day?
I read a review on on another site that stated the NIT for the turbo is only 250. That's really weak if it's true.
1901Madison
1,538
Got it, thanks!
RemusGhostofRome
