10-12-2015 05:30 PM
1,125 ... 89101112 ...
tools
  1. Robisan's Avatar
    @jec11718 If you haven't already, go into Settings > Accounts > Google and turn off syncing for all Google services you're not using. I believe the default is to sync everything and, at least for me, I don't use most of them.
    11-03-2014 10:17 AM
  2. donebrasko's Avatar
    A resounding YES. Did you take the plastic off the screen?
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    I'll update now. The plastic is still on my phone. As soon as my brother in law took the plastic off his m8 he put a scratch on it. I am very weird about that kind of stuff.
    11-03-2014 10:21 AM
  3. camachinist's Avatar
    Still not dead yet. Also I still haven't taken the system update.
    Attached Thumbnails Droid Turbo: Battery Life-237.jpg   Droid Turbo: Battery Life-238.jpg
    11-03-2014 10:25 AM
  4. Firedogee's Avatar
    Can't see the total hours on from your screen shot?
    11-03-2014 10:31 AM
  5. camachinist's Avatar
    Sorry about that don't know how that happened
    Attached Thumbnails Droid Turbo: Battery Life-239.jpg
    11-03-2014 10:32 AM
  6. Rogus's Avatar
    Can you post your graph so we can see how the usage is spread out?
    Didn't take a screen shot of my graph.
    11-03-2014 10:52 AM
  7. Masheen's Avatar
    I'm only pointing out that I've become accustomed to better. I would have questioned this upgrade if I knew that the battery life on this phone was not as good as the Maxx. It's still too early to know for sure, but my initial impression has me a little concerned.
    All kidding aside, a 5 hour screen on time is excellent! When I first got my Maxx I would push 7 hour screen times, however, once the KK updates hit, my time was reduced to 4-5 hours. Updates do this to your phone. My brother had the same thing happen to him with his G2.
    Also, beware, there are apps that don't show up in either GSam or stock Battery watcher. In addition, every device reports usage differently. For example, cell standby may be coupled with Android System or Android OS on other devices, (Not the turbo obv because cell standby is unusually high) Also, Facebook and Facebook Messenger do not show up on stats when it fetches data or syncs in the background. Only actual usage time of the app will display as a loss. Sometimes it is hard to find apps and processes that drain battery. GSam is excellent for finding those rogue apps that go haywire and wreck battery, but sometimes you need to investigate a bit more into it. Social media apps use a lot of battery life, Facebook much more than Instagram, which surprisingly doesn't use much. I merely scratched the surface on how battery life may be affected by certain apps.
    I bought the Droid Turbo so that I don't have to Sherlock Holmes check my entire phone's system and kernel processes because I know that I have enough battery to run what I like. On my Galaxy Nexus, my battery was so bad that I had all of the location settings off, most of the syncs off, including what I consider necessary Google account sync settings, screen brightness set to 0 at all times, and a ton of other things that I would have liked to have on. It was ridiculous... I told myself that I never want to be in that position again. The Maxx relieved me of my anxiety, and the Turbo continues to do so. The Turbo has the best battery life on the market, although WE don't get the claimed "Two days of use" there are people out there who do. Like one member said in another post: "If we are posting on these forums, we are most likely heavy (heavier) users" so we do not fall into that category. For what the Turbo has, I am very impressed with the battery life, as I was concerned because of the qHD display.
    11-03-2014 10:56 AM
  8. 1901Madison's Avatar
    Guys, dropping to 99% or 98% very quickly should be of no concern. When you charge your phone, it charges to 100% and then trickles down back to around 95 or 96%, then charges back to 100%, and back down to 95%, etc., etc. This is to prevent over-charging and is the current technology used by lithium-ion and lithium-polymer batteries. So, when you take your phone off the charger, the battery meter may show 100%, but it's really probably somewhere between 95-100%. The "drop" from 100% down to 98% is really just the battery meter calibrating itself and providing you the accurate percentage. You'll probably notice that once the phone meter gets down to 95% or so, it discharges more consistently.
    Masheen likes this.
    11-03-2014 11:07 AM
  9. Firedogee's Avatar
    Same reason I bought the Turbo. I'm tired of crippling and micromanaging my smartphone. I want it to be as Smart and as pleasurable to use as possible. No more sherlocking it for me. Just good old Turbo speed for Days! Best. Phone. Ever.
    Masheen likes this.
    11-03-2014 11:08 AM
  10. Masheen's Avatar
    We're ridin the same wave. I never thought there would be an Android phone that I had almost no desire to root... Then came the Maxx, and now came the Turbo.
    11-03-2014 11:11 AM
  11. 1901Madison's Avatar
    I think a lot of people are confusing the Maxx's battery life with the Turbo's battery life because of the battery readings. My Maxx would hold what appeared to be a 100% charge for a long time, but would then seemingly discharge a little more quickly afterwards. Also, I noticed that once my Maxx hit the 67 or 68% mark, it would fly down to about 62% within minutes, even if idled. The phone would do the same thing around 27%. I'd put it down for 15 minutes and come back to see it at 19%.
    The Turbo is far more consistent with battery drainage. I think people are thinking their Maxx had significantly better battery life, but that is partially an illusion due to the inconsistent discharge readings.
    Also, for those who believe that the Maxx had significantly better battery life than the Turbo, I suggest turning down screen brightness if you can bear it. The Maxx's screen was only 720, so it could withstand more brightness. If you run the Turbo's incredible screen on close to max brightness, that sucks a lot of juice. I've been at about 10% brightness indoors and 40% outdoors. That's plenty for me.
    PeninaD likes this.
    11-03-2014 11:12 AM
  12. 1901Madison's Avatar
    Good point about cell standby. Why is it so high? Mine is high even when I am on wifi.
    11-03-2014 11:17 AM
  13. jec11718's Avatar
    Thanks, will do...still not great but hoping it settles down.
    11-03-2014 11:20 AM
  14. jec11718's Avatar
    This is really ugly...fully charged when unplugged this morning 3.5 hours ago and screen at half brightness
    Attached Thumbnails Droid Turbo: Battery Life-1914.jpg
    11-03-2014 11:30 AM
  15. Firedogee's Avatar
    Gotta be an app or game you downloaded. Have you tried the GSam battery monitor? It has a feature called AppSucker that shows which apps are misbehaving.
    11-03-2014 11:36 AM
  16. jec11718's Avatar
    Just installed it one minute ago.
    11-03-2014 11:38 AM
  17. Firedogee's Avatar
    It won't start monitoring until the moment you first open it, so give it a few hours to get some good data.
    11-03-2014 11:42 AM
  18. Masheen's Avatar
    The way I see it, the Cell Standby being unusually high isn't unordinary in how the Turbo functions. It is, however, in how it shows up as being so high, or that may be normal too. For example, what the Turbo is showing as a high Cell Standby, my Maxx would have shown the same drain, but coupled with either Android System, Android OS, or Phone Idle. There is uniformity in how Android reports battery stats. Maybe someday there will, but currently, every phone has a unique way of reporting system processes.
    11-03-2014 11:48 AM
  19. S4Rs's Avatar
    First things I did is go to Settings, more, change mobile networks to LTE/CDMA rather than Global. Put location setting on battery saving. Screen on auto brightness and make sure social and email apps aren't syncing more than 1x per hour under Accounts settings. Also, for WiFi advanced settings, I change always on to only when plugged in and then uncheck the box for always scanning even when WiFi is turned off. That should help.
    PS. Since you are in a bunker, you could either turn off mobile data to get a better CDMA only signal or just go to airplane mode and use Wi-Fi at work (no phone or data). There are apps like Tasker that can automate this kind of stuff too. Best of luck!
    Sent Turbo fast from my 64GB Droid Turbo
    You do not want WIFI to be only when plugged in. If you set that you will disconnect from wifi at home when the screen is off, and your phone will start doing things off the carrier network. This is not even close to as efficient as a strong wifi signal at home. Plus the WIFI in qualcomm chips is top notch. I never turn off wifi or bluetooth or nfc. They manage themselves. Just look in the battery stats at the end of the day. Worth the hit IMO.
    camachinist likes this.
    11-03-2014 12:06 PM
  20. Masheen's Avatar
    I concur. However, I also believe that switching from global to LTE/CDMA helped my signal strength and battery. Could be placebo effect, but it doesn't negatively affect me.
    11-03-2014 12:26 PM
  21. Firedogee's Avatar
    It only turns off Wifi if unplugged AND deep sleep. Never had problems with this setting eating 4G data and I've used it for 2+years
    11-03-2014 01:26 PM
  22. jec11718's Avatar
    this is how bad it is....its plugged in now, and im posting from the chromebook. this sucks.... less than 2 hours screen on time and it was at 18%. gsam hadnt had but and hour of monitoring and the app sucker still listed the os as the biggest draining (7%). im really hoping this battery isnt bad. this is the ballistic 64gb. my wife has the 32 black fiber, and it was at 58% and almost 10 hours of unplugged and 2 hrs on screen time.
    11-03-2014 01:35 PM
  23. Firedogee's Avatar
    Somebody on a different thread said there's had a bad battery so they gave it a spanking and then exchanged it for a new Turbo at the store. Maybe same for yours?
    "Spare the charge, spoil the Turbo."
    11-03-2014 01:41 PM
  24. Almeuit's Avatar
    I saw a commercial stating 8 hours on a 15 min charge? I take it that is with a bunch of power saving things on?
    11-03-2014 01:41 PM
  25. jec11718's Avatar
    A good possibility it will get exchanged
    11-03-2014 01:45 PM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
