10-12-2015 05:30 PM
1,125 ... 1112131415 ...
tools
  1. mobrules's Avatar
    OK...battery is the main reason I got this phone. Got a full charge this morning, running GSam battery app. Let's see what this thing can do........
    Good luck. Post screen shots later.
    11-04-2014 09:23 AM
  2. Jay Evans's Avatar
    Pretty good for low signal and 5hrs screen time!
    And still having around 30%+ left when I went to bed! I am impressed with the Turbo so far. My wife is seeing similar results with her's too.
    11-04-2014 09:48 AM
  3. Firedogee's Avatar
    I wear a moto 360... does that keep the phone awake?
    Not sure, but I would guess you've found the culprit. Maybe they need to patch Turbo to make battery use more efficient with 360?
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-04-2014 09:50 AM
  4. Firedogee's Avatar
    Same. My phone drops to 99 or 98 within minutes (or immediately) after unplugging. But then it goes back to normal and barely sips power. It might just be that the phone isn't really at 100 when you take it off the charger and once you take it off, it re-calibrates.
    This is my hunch too ^^^^^
    1901Madison likes this.
    11-04-2014 09:52 AM
  5. jec11718's Avatar
    I think I've found the culprit.... This screen shot is with the 4g data turned completely off.... Wi-Fi on and cell radio on. 87% left... Now I'm gonna turn on 4g let's see what happens....
    Attached Thumbnails Droid Turbo: Battery Life-1925.jpg
    11-04-2014 10:47 AM
  6. Firedogee's Avatar
    That makes sense, trying to hug a very bad 4G signal is the death knell of any phone. The Turbo does bear hugs!
    11-04-2014 10:50 AM
  7. jec11718's Avatar
    Up until this point.... Both icons are in the bar at the top... My DNA would only show the one at time... Even if both were on... Will the turbo show both even tho its only using one, ie I have both on, both show but one is grayed and one is white..???? With 4g off it doesn't show but with it on, it's gray and WiFi is wht.
    11-04-2014 10:54 AM
  8. jec11718's Avatar
    See how its there but gray?? Now let's watch the battery fall like a stone in a deep well!!!!
    Attached Thumbnails Droid Turbo: Battery Life-1926.jpg
    11-04-2014 10:58 AM
  9. Firedogee's Avatar
    I'm not sure. I'm thinking that this phone is prepped for VOLTE so maybe it is holding 4g even when Mobile data is turned off. Anybody else with more knowledge wanna chime in?
    PS. Jec11718, mind showing us your screen shot later today with mobile data off?
    11-04-2014 11:12 AM
  10. MA2GA28's Avatar
    So far, so good for battery life on my Turbo.
    I'm currently in my first run off full charge, and I'm at 30% after 27 hours off the charger. I won't post the screen shot, as I ran the system update yesterday evening, and of course the phone had to reboot. However, the usage has been relatively heavy since I've been testing the phone during this time. Some videos, a number of pictures, watching You Tube videos, the downloaded update, streamed music for about 8 hours, lots of FB and Instagram, made a 30 minute phone call (I know, right?), texting the wife, downloading some apps, creating ring tones, downloading some songs, internet browsing, app settings, etc. Also have left GPS on the entire time as well.
    Granted, 85% of the time I have been on Wifi, but still a good showing early on that should get better as the battery is worked in. Seems to be in-line or slightly lagging from my old Droid Razr Maxx, but that's expected due to the higher performance and better screen. I'll be sure to post a screen shot of the next charge round.
    11-04-2014 11:12 AM
  11. jec11718's Avatar
    I can do that but I turned it on to document the steep decline in battery. The last hour...almost 9% gone, and that's just some web browsing and posts on here, and took the screen shots. I'll post the one hour mark with both WiFi and 4g data on..... The first three hours of unplugged no WiFi or 4g. Then almost nine hours Wi-Fi only, then one hour of both..screen shot forth coming..
    11-04-2014 11:39 AM
  12. jec11718's Avatar
    This is one hour and one minute on both. 87% to 79%.... See my post 59 minutes ago gsam number is 87%....I'm not impressed with this battery.
    Attached Thumbnails Droid Turbo: Battery Life-1927.jpg
    11-04-2014 11:45 AM
  13. beeare's Avatar
    Best battery day so far. This is closer to what I was getting on my Maxx. Been on 4G since 7:30am which represents all of my screen time. At least 15 emails, on Whatsapp for a good 25 min, and a few goggle now searches.
    Attached Thumbnails Droid Turbo: Battery Life-1415119055802.jpg   Droid Turbo: Battery Life-1415119559070.jpg
    11-04-2014 11:46 AM
  14. Firedogee's Avatar
    Not good for almost zero screen time. Give it a few more days and see if it evens out?
    11-04-2014 11:47 AM
  15. jec11718's Avatar
    I can try, but exchange for different phone? Remember, my wife's 32gig model is not half as bad as this....
    11-04-2014 11:49 AM
  16. Firedogee's Avatar
    Curious what apps/updates/settings might be different on hers?
    11-04-2014 12:25 PM
  17. Robisan's Avatar
    IMO you have a defective phone and you should exchange it. Your results are different from everybody else is here and from your wife's. Assuming you're otherwise happy with the phone, exchange it for new Turbo.
    11-04-2014 12:40 PM
  18. willypguy's Avatar
    My battery dropped 20% overnight, I am considering exchanging mine.
    11-04-2014 12:46 PM
  19. Firedogee's Avatar
    When are you gonna exchange for a new Turbo? Lol
    11-04-2014 01:10 PM
  20. Robisan's Avatar
    Well, my X is going back. We'll see about the Turbo. May wait until I can get L pre-loaded. May take that long to get my refund processed anyway...
    11-04-2014 01:16 PM
  21. JIH2009's Avatar
    So here are the results of the last 50% of the battery. I left it alone at 10:30pm at 20%, 6:30am at 9% it seemed to use more battery when on the lower end of battery amount left. 12 hours idle..(recovering from a cold, lots of sleep)...7% loss vs. 11% loss over 8 hours idle. I got it down to 4% this morning, in the process of taking screencaps it shut down. Didn't get the Display time shot, but its around 5hrs 25min of screen on time. I plugged it into the Turbo charger at that point, turned it on and it took almost exactly 2hrs to get to 100%
    Droid Turbo: Battery Life-screenshot_2014-11-04-09-00-37.jpgDroid Turbo: Battery Life-screenshot_2014-11-04-09-01-21.jpg
    mobrules likes this.
    11-04-2014 02:01 PM
  22. mobrules's Avatar
    So here are the results of the last 50% of the battery. I left it alone at 10:30pm at 20%, 6:30am at 9% it seemed to use more battery when on the lower end of battery amount left. 12 hours idle..(recovering from a cold, lots of sleep)...7% loss vs. 11% loss over 8 hours idle. I got itClick image for larger version.
ID:	145821Click image for larger version.
ID:	145822 down to 4% this morning, in the process of taking screencaps it shut down. Didn't get the Display time shot, but its around 5hrs 25min of screen on time. I plugged it into the Turbo charger at that point, turned it on and it took almost exactly 2hrs to get to 100%
    Congrats. That's pretty impressive.
    JIH2009 likes this.
    11-04-2014 02:07 PM
  23. mobrules's Avatar
    Try using Automateit or tasker. I used the first for a few days and saw 3-5 % drop overnight on average. I started with Automateit but paid for tasked and plan the run that tonight to compare the two.
    11-04-2014 02:11 PM
  24. Thoma015's Avatar
    When I check my battery status, the blue bar under "awake" is solid. Why won't my phone sleep? Everything else is fine, gps only has a few marks. My way WiFi is solid but this is expected as I keep it on. Any suggestions?
    PeninaD likes this.
    11-04-2014 02:39 PM
  25. Deron Baker's Avatar
    So, my Turbo has been draining a little faster than I'd like while idle. So this morning, I disabled the features where the phone keeps the screen on when you are looking straight on (Attentive Display) , and I also disabled the proximity sensor setting for active display. My theory is that those features are causing a bit of idle drain.
    I remember with my parents galaxy kno 3, I turned off the feature where she keeps the screen on wall you are looking at it. That seems to help a battery life a little bit with those phones. I'm hoping it will do the same with this one.
    Turned all the off:
    camachinist and mobrules like this.
    11-04-2014 03:10 PM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
