10-12-2015 04:30 PM
1,125 ... 1718192021 ...
tools
  1. ckelly33's Avatar
    Lol, I'm gloating too but it hasn't helped my battery.
    11-05-2014 06:53 PM
  2. ckelly33's Avatar
    What is the other "this and that"?!
    11-05-2014 06:53 PM
  3. Firedogee's Avatar
    What us the other "this and that"?!
    It's classified... The Unicorn Alliance would have both our heads if... Wait, somebody is at my door.... Aldjfndiansndhchvogoennwnjwjcj
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-05-2014 06:56 PM
  4. Robisan's Avatar
    1) A little of this and a little of that... Oh and Gloating over the Dems #EpicFail
    Good luck with your two year Senate rental. The 2016 map is just as bad for the Repugs as the 2014 map was for the Dems.
    ... adding, at least for comedic value, when God takes away a Bachmann he gives you an Ernst. She's loony toons.
    11-05-2014 07:05 PM
  5. Firedogee's Avatar
    LOL, I knew you were from that bizarre world across the aisle Robisan... But I still love you anyway. Let's (appear) to work together before the frustrated American people throw us all out of office
    ckelly33 likes this.
    11-05-2014 07:08 PM
  6. cyberr8der's Avatar
    No complaints here. This is a test run I did keeping WiFi off and only running on LTE.
    11-05-2014 07:21 PM
  7. redintegra19's Avatar
    I don't have a lot of time to play with the phone but I thought the battery life is pretty good.
    Droid Turbo: Battery Life-1805.jpg
    11-05-2014 07:58 PM
  8. mobrules's Avatar
    Wow
    11-05-2014 08:29 PM
  9. cyberr8der's Avatar
    What was the screen time on that?
    11-05-2014 08:33 PM
  10. redintegra19's Avatar
    just under 5 hours. Around 1.5 of those are on 4G, rest on wifi. I got the phone sunday, used the battery completely and then did a full charge.
    11-05-2014 08:37 PM
  11. InfiniteClouds's Avatar
    Droid Turbo: Battery Life-screenshot_2014-11-05-21-43-37.jpgDroid Turbo: Battery Life-screenshot_2014-11-05-21-43-42.jpg
    I'm thoroughly impressed.
    11-05-2014 08:50 PM
  12. chris20nyy's Avatar
    Finally some good numbers starting to come through. Did that last update maybe make some changes?
    11-05-2014 10:02 PM
  13. camachinist's Avatar
    I'm still on the OEM software and the phone seems to be doing fine, comparable to what's being reported here, though I did follow a lot of the advice here to optimize efficiency.
    Regarding the battery itself, I found this video to be interesting, in that the reviewer discussed, and showed, the battery of the Droid versus that of the Maxx.
    It appears, perhaps, that the battery vendor has improved the energy output and put it into a smaller package, if the reviewer's observations are correct. In any event, an interesting look at the inside of this unit.
    11-05-2014 10:13 PM
  14. camachinist's Avatar
    When the battery lasts so long it's hard to do comprehensive testing on it .
    Here's a picture of some interim numbers
    Attached Thumbnails Droid Turbo: Battery Life-684.jpg
    11-05-2014 10:51 PM
  15. Pinzgauer's Avatar
    Coming from the Droid Maxx, I don't see much if any improvement in battery life.
    11-06-2014 04:59 AM
  16. eprindes's Avatar
    16 hours with 3 hours screen time, not impressed at all. Btw 8 of those hours I was asleep with everything cut off. Been a week and not getting any better. I do use a Moto 360 but have talked to others who get much better battery life than me with the 360. No lie right now the 360 has a longer charge than the turbo. Any advice would be much appreciated. I'm far from a noobie but just can't figure out the issue here
    Attached Thumbnails Droid Turbo: Battery Life-3293.jpg   Droid Turbo: Battery Life-3294.jpg   Droid Turbo: Battery Life-3296.jpg   Droid Turbo: Battery Life-3297.jpg
    11-06-2014 05:30 AM
  17. ryanr509's Avatar
    Something was holding your phone awake. In the gsam app it says 3:50 of being held awake but only 2:38 of screen time. If u look at my gsam shot the difference in my screen time and being held awake time is only 25min.
    Attached Thumbnails Droid Turbo: Battery Life-1415275421390.jpg
    11-06-2014 06:03 AM
  18. eprindes's Avatar
    Im assuming thats the 360 but i was getting similar battery results prior to having the 360. When i take my phone off the charger today after work i'll disconnect 360 and do a test run w/o to determine if thats the culprit.
    11-06-2014 07:37 AM
  19. nicholasdejohn's Avatar
    So I figured I would show my battery stats to get some advice. I'm on day 2 with my device and I have only done one complete charge. Last night, I went to bed with 45% battery left and woke up with only 28% left. I was hoping for more but please, let me know if I am doing something wrong.
    I use the feature built into the phone that keeps the phone quiet at night. Other than that, I try and shut everything down when I am done with it.
    Attached Thumbnails Droid Turbo: Battery Life-2653.jpg   Droid Turbo: Battery Life-2654.jpg
    11-06-2014 08:19 AM
  20. Busted51's Avatar
    for those of you getting 5+ hours screen time and use gsam.. can you open your gsam apps readout and post a picture.. I'm only getting 4ish hours of screen time but all 4 hours are on chrome surfing the web.
    11-06-2014 08:28 AM
  21. pdarrah's Avatar
    I posted way back (a week ago!) and was pretty happy with battery life. A week later and I am still happy
    I'm coming from a RAZR M that was screwed up by KitKat. Prior to KitKat, my M would just make it through when I had a long day (typically Wednesday) with about 20% left. After KitKat, the only way to survive a Wednesday (or similar day) was to find some time to charge it in the middle of the day. Yesterday, I had a typical Wednesday and took screen shots before I plugged in when I went to sleep.
    Droid Turbo: Battery Life-tn_2014-11-06-04.22.38.pngDroid Turbo: Battery Life-tn_2014-11-06-04.22.43.pngDroid Turbo: Battery Life-tn_2014-11-06-04.23.02.png
    I didn't really do ANY battery management. A good chunk of my day is in low signal (I have an awesome 5-bar at home, but you can see I wasn't there much). I even played around with Slacker radio for about 45 minutes in a poor signal area w/o WiFi available. I keep WiFi on all day - but only had it available during the 6 hrs at my office and at home. I'm syncing my office email (IMAP) and 3 gmail accounts.
    To compare, here is the info from my poor M from 2 weeks ago:
    Droid Turbo: Battery Life-tn_2014-10-23-02.29.40.pngDroid Turbo: Battery Life-tn_2014-10-23-02.29.44.pngDroid Turbo: Battery Life-tn_2014-10-23-02.30.05.png
    For that day, I was being very careful & trying to conserve as much battery as I could. Needless so say, I'm thrilled with how the Droid Turbo is working out!
    11-06-2014 08:43 AM
  22. novanoto's Avatar
    According to GSam, I'm averaging 19 hours/battery life, with 8 1/2 hours active and 5 hours screen time. This is with all bloat disabled, wifi usually on, and a not-seemingly terrible signal area. Just doesn't seem like my battery is getting nearly the time that others are. Between this, my back capacatative button not working at times, and the fraying of the nylon, I think I'm gonna swap it for another of the same model. Hopefully!
    11-06-2014 08:57 AM
  23. PowrDroid's Avatar
    I watched that video the other day. It looks like the Turbo battery is slightly longer and wider than the Maxx battery. Relevant portion is at 9:15 in the video timeline.
    11-06-2014 10:22 AM
  24. Brian Singleton's Avatar
    Clearly by the attached Wakelocks are my problem. I seem to have way more (although they are very short times) than anyone else posting on here. Anything that appears longer was either screen on or audio being listened to. Facebook, Twitter, and all other social networking refreshing is turned off. Still struggling to comprehend what is wake locking so much!?! Any guesses?
    Droid Turbo: Battery Life-screenshot_2014-11-06-11-09-29.jpg
    Droid Turbo: Battery Life-screenshot_2014-11-06-11-11-05.jpg
    11-06-2014 11:15 AM
  25. cyberr8der's Avatar
    Go to Google setting / android device manager and see if remotely locate this device is enabled. I have found that to be a hog.
    11-06-2014 11:17 AM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 07:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 03:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 09:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:13 PM
