10-12-2015 04:30 PM
1,125 ... 2021222324 ...
tools
  1. ckelly33's Avatar
    Here they are. Typically when I first open Gsam, my mA are 1200+. Pics I've seen here are much lower. Don't know if it is significant or not.
    Attached Thumbnails Droid Turbo: Battery Life-uploadfromtaptalk1415493681040.jpg   Droid Turbo: Battery Life-uploadfromtaptalk1415493689622.jpg   Droid Turbo: Battery Life-uploadfromtaptalk1415493697077.jpg
    11-08-2014 06:43 PM
  2. James Mallory's Avatar
    The android system is using most of the battery, which could be location settings, the moto active display, the wifi settings. all of that. So far what have you disabled? as far as settings
    11-08-2014 06:47 PM
  3. ckelly33's Avatar
    Location is on battery saver, command center is disabled, im on wifi and I did leave the active a screen on but pretty much all other moto settings are off.
    Sent from my SM-P600 using Tapatalk
    11-08-2014 06:50 PM
  4. James Mallory's Avatar
    here's mine. Have you done any discharging cycles? and how long have you had the phone
    Droid Turbo: Battery Life-screenshot_2014-11-08-18-47-27.jpgDroid Turbo: Battery Life-screenshot_2014-11-08-18-47-38.jpgDroid Turbo: Battery Life-screenshot_2014-11-08-18-47-30.jpg
    11-08-2014 06:52 PM
  5. ckelly33's Avatar
    Holy smoke! How tbe heck are you getting times like that?! I've had it since 10/31. Haven't done any full power cycles - I'm on call a lot so I'm a little afraid of needing it suddenly. Lowest I've gotten is like 14%
    11-08-2014 06:55 PM
  6. ckelly33's Avatar
    What else do I need to disable? Only thing I'd like to keep active are the screen sensors - which is probably the biggest offender.
    11-08-2014 06:57 PM
  7. James Mallory's Avatar
    yeah eventhough you shouldn't have to comprise to get good battery. I've disabled location services, changed some of the wifi settings, disabled the account syncing, and the moto always listening and always on features. I've also done 3 or 4 full charging cycles. meaning using the phone as normal letting it die then fully charging it back to 100 without using it. I know there's been articles online about how not to let it discharge fully and some that says it doesn't affect it in a bad way, but I based it off prior knowledge and did the discharge and it actually helped. At first my battery was terrible too getting around 16hrs with 5 hours of screen on time and idle time was bad too
    ckelly33 likes this.
    11-08-2014 07:05 PM
  8. ckelly33's Avatar
    Thanks. I cant do without account syncing either unfortunaltely. I haven't seen any suggestions on altering the Wi-Fi settings. What did you do?
    11-08-2014 07:09 PM
  9. James Mallory's Avatar
    here's my settings
    Droid Turbo: Battery Life-screenshot_2014-11-08-19-12-07.jpg
    11-08-2014 07:17 PM
  10. 1901Madison's Avatar
    My battery just keeps getting better and better. 15+ hours of on time and 4+ hours of screen time... and still have 59% left!
    Attached Thumbnails Droid Turbo: Battery Life-10478.jpg
    11-08-2014 10:14 PM
  11. beeare's Avatar
    I can understand turning off features if you don't like them, but having to do that to save on battery kind of defeats the purpose of having a phone with them in the first place.
    I wish that I could keep every feature on and get the battery life expected with this phone, but it appears that isn't possible. None of the features I personally disabled outweigh the benefits of the improved battery life. I love the moto suite of apps and have most of them enabled, but I can certainly live without swiping my hand over the phone to stop my alarm or shutdown an incoming call. I do like the the active display turning on when I bring my hand towards the phone, but if it's affecting battery life to the point that I can't get a full day using my phone the way I need to without charging it, then I'll happily forgo it.
    11-09-2014 02:50 AM
  12. Ggoblue's Avatar
    I am on a 32 hour battery pace and I'm pretty happy with that. I have 32 apps disabled. Also turned off the infrared sensors. That helped but I might go back to it.
    Edit: it seems like the battery keeps getting better. On a 40 hr pace now.
    Attached Thumbnails Droid Turbo: Battery Life-8270.jpg   Droid Turbo: Battery Life-8271.jpg   Droid Turbo: Battery Life-8272.jpg   Droid Turbo: Battery Life-8273.jpg   Droid Turbo: Battery Life-8274.jpg
    11-09-2014 05:02 AM
  13. Rogus's Avatar
    I realize that people run different apps than I do that might consume more battery and various screen on time, but I haven't turned off anything. I don't use Command Center. I have read that it's a battery hog. That's not why I don't use it. I just don't like it. Anyway, with everything turned on, I have never had less than 32 hours off a full charge to less than 10%. Highest was 42. Currently, 26 hours unplugged with 55% battery left. Don't understand why many of you get so much less.
    11-09-2014 08:19 AM
  14. mobrules's Avatar
    Here's my latest. I won't complain. Watched amazon video during train ride friday, played some games, used google maps for a trip saturday. Other than that general internet use, news and such. I'm pretty happy with it. I don't need apps syncing in the background and that saves a ton of battery. I use tasker to regulate it. I started with auromateit but switched. These settings are not for everybody.
    Attached Thumbnails Droid Turbo: Battery Life-1415544928658.jpg
    11-09-2014 09:04 AM
  15. beeare's Avatar
    I disabled command center, which I could care less about, in conjunction with a few other things, so although my battery life has improved significantly, I can't be sure what exactly to attribute it to. Is it a combination of everything, or is it one thing in particular, namely the command center widget? I guess, now that I'm done with the command center, I'll start turning other things back on to see if the battery remains as good as it is now. And if I turn them back on one at a time, then I'll be able to potentially pinpoint what's causing problems. The only things I disabled is: location (cause I can turn back on easily if I need it), the wave to silence, and approach to turn on moto display. I do like the approach to turn on the moto display feature, I'm not going to lie.
    11-09-2014 01:42 PM
  16. James Mallory's Avatar
    Droid Turbo: Battery Life-screenshot_2014-11-09-14-01-40.jpgDroid Turbo: Battery Life-screenshot_2014-11-09-14-01-33.jpg
    battery life has significantly improved!!!!
    mobrules likes this.
    11-09-2014 02:23 PM
  17. Izit legit's Avatar
    Nice
    11-09-2014 02:28 PM
  18. jmantucca's Avatar
    mobrules. can you take a screenshot of your tasker settings? I have some as well. Just want to compare. doing great today battery wise. 4 hrs 30 min SOT with 36% left
    ckelly33 and mobrules like this.
    11-09-2014 03:12 PM
  19. Brian Singleton's Avatar
    Turning off the "Approach" Moto Action as well as the attentive display seems to have made all of the difference in the world for me. Also disable the always listening voice commands. Still have Moto Display activated for the notifications, and all seems good now. I'm getting 36-40 hours pretty consistently.
    11-09-2014 04:51 PM
  20. mobrules's Avatar
    Thanks and no problem. The first is the display state triggers. The second is what happens when the display shuts off. Then I have it also set up to reverse the first set of actions and connect when the screen is activated. I just dont like the background stuff running if I am not using it. Post yours so I can compare please. I am actually new to Tasker and have a lot to learn I am sure.
    Attached Thumbnails Droid Turbo: Battery Life-1415573299996.jpg   Droid Turbo: Battery Life-1415573315487.jpg
    jmantucca likes this.
    11-09-2014 04:54 PM
  21. jmantucca's Avatar
    I just have it set up when not on wi-fi, screen off and on same mobile data triggers as you. As well as when connected to wifi, always mobile data off. Any reason why my held awake time is so high? I turned a ton of settings off, no syncing, apps dont auto update etc. turned wifi off in deep sleep. location services off. Attentive Display as well. Droid Turbo: Battery Life-screenshot_2014-11-09-18-08-34.jpgDroid Turbo: Battery Life-screenshot_2014-11-09-18-09-56.jpg
    11-09-2014 06:13 PM
  22. mobrules's Avatar
    Lower left side of the Gsam screen. Looks like a vacuum, app sucker. Check there and see. Maybe theres an app running when you dont know that it is. There is also a thread in here somewhere that lists apps that can be disabled. That helps alot too. Hope this helps a bit.
    11-09-2014 06:50 PM
  23. jmantucca's Avatar
    Those are my stats. App battery % seems right. Dont see anything out of the ordinary. Droid Turbo: Battery Life-screenshot-07_00pm-nov-09-2014-.jpg
    11-09-2014 07:02 PM
  24. beeare's Avatar
    Battery life has completely settled in. I'm ready to say that the battery on this phone is superior to the Maxx.
    Attached Thumbnails Droid Turbo: Battery Life-1415587565920.jpg
    11-09-2014 08:46 PM
  25. mobrules's Avatar
    My wakelocks look the same except the third one down which is related to your wireless signal. I dont use wireless very much really. Charge to 100 tonight then unplug and leave it alone. Then check the wakelocks in the am and see what it is then.
    11-09-2014 09:47 PM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 07:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 03:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 09:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:13 PM
