10-12-2015 05:30 PM
1,125 ... 2223242526 ...
tools
  1. beeare's Avatar
    I have to agree. Most of the time my screen is on auto and I cant see any difference.
    I disagree. Next to the 1080p Galaxy S5 I notice no difference. I just sold my Maxx on Ebay and was playing around with both phones right next to one another, and there is a significant difference. The brightness on auto too is hugely different, with the screen being much brighter on the Turbo. Holding them independently and using them normally, you wouldn't notice much of a difference, but right next to one another, there's a big difference. Also, at this point I think the battery is better on this phone anyway, so I'm not stressing Motorola's decision to throw in the extra pixels.
    11-12-2014 11:21 AM
  2. PowrDroid's Avatar
    I just did this at the Verizon store last night. Set my RMHD on auto brightness, turned the store's Turbo from max brightness to auto brightness, waited about 30 seconds and compared them in the same lighting conditions. Not even close--Turbo was much brighter.
    11-12-2014 11:33 AM
  3. mobrules's Avatar
    I still have my RMHD. Comparing them side by side I don't see a whole lot of difference with auto brightness. Yes the Turbo screen is much sharper. Its like comparing the screens on different televisions. I have a Vizio that does not get as nice of a picture as my Samsung. They both have smart/auto brightness. The Samsung is much sharper despite having similar specs. Its also a matter of taste. I notice looking at any screen that is too bright and sharp eventually is an issue for me. The auto brightness setting for both phones look very similar to me.
    11-12-2014 12:20 PM
  4. Mike Koppler's Avatar
    So I'm not sure if this good or not. I've been off the charger since 8am today...
    Droid Turbo: Battery Life-screenshot_2014-11-12-14-15-12.jpg
    11-12-2014 02:19 PM
  5. PowrDroid's Avatar
    Hmmm... what lighting conditions were you in? I was in the Verizon store with overhead fluorescent lights.
    11-12-2014 02:33 PM
  6. mobrules's Avatar
    Thats a very good point. I compared it in my car and my livingroom. I didnt try it in the store. Had to use another line to upgrade so I didnt want to be obvious what I was up to.
    11-12-2014 03:07 PM
  7. TurboFast's Avatar
    Here are Tips from Motorola to extend Droid Turbo battery life. I found the duplicate email and airplane mode suggestions extremely helpful.
    Since I can't post links yet, just Google "Droid Turbo delete email account" and the first link will be for the Moto website.
    mobrules and bizzyqu like this.
    11-12-2014 03:14 PM
  8. OCnNC's Avatar
    I'm not a power user, just had the phone one day, pretty much out of the box settings (put app updates on wi fi only). Put it on the turbo charger this morning for about an hour before work, updated app, a few calls and texts, streamed pandora 3 hours, maybe 30 mintues streaming live flash video (Dolphin browser), some messaging, fiddling with the phone and trying things out, a few new apps, 12 hours later at 72%. Again, not a power user but this phone will do me just fine I think! main question at this point is care and feeding of the battery so that those days (or two) I NEED a long battery life I have it. Should I routinely turbo charge overnight, wireless charge during the day at work, or wait till battery is at X% before charging with either method?
    11-12-2014 08:36 PM
  9. beeare's Avatar
    I sit next to a colleague at work with an RMHD and while I had the Droid Max, i noticed my screen looks significantly better than his, as did he. After noticing yesterday how much nicer the Turbo screen is next to the Maxx, I'm sure the Turbo next to the RMHd is way more profound.
    11-12-2014 11:52 PM
  10. bizzyqu's Avatar
    Another 15 hour day
    Attached Thumbnails Droid Turbo: Battery Life-11076.jpg   Droid Turbo: Battery Life-11077.jpg
    11-13-2014 01:00 AM
  11. mobrules's Avatar
    Not bad at all. High bluetooth time so I think its pretty good.
    11-13-2014 08:41 AM
  12. MA2GA28's Avatar
    I finally found a way to drain the battery: Download 20 songs and then make ringtones for an hour!
    I did just this last night, and the battery dropped close to 18% over the 90 minutes of downloading/music playing/ringtone making, screen on time (auto-bright in a lit room), and I had GPS on as well (forgot to toggle it off). All of this was on strong Wifi, so I was a bit surprised the battery drained so much. Of course, I still got a total of 19 hours on a 92% drain, so no complaints there.
    11-13-2014 09:50 AM
  13. softballmom 01 07's Avatar
    I think I'm just a battery drain. Every phone I've had has always had battery problems. Bought the Turbo a week ago. Today was a heavy use day. Sick kid playing games, Facebook, pictures and maybe an email or two and a few chrome searches Unplugged the phone at 8am, now it is 10pm I'm at 24% battery left! Checked the battery usage and it says the screen used 65% of the battery. But still....its only been 13 hours...better than my last phone that only lasted 4 without using it but still.....what happened to my 48 hours of battery?
    mobrules likes this.
    11-13-2014 10:15 PM
  14. bizzyqu's Avatar
    thats actually pretty good, especially if gaming. 48 hours can only be achieved with VERY light use, if at all
    11-13-2014 10:20 PM
  15. mobrules's Avatar
    I think you can get 48 easily. If the settings are set up to achieve it. Granted the screen time isn't as good as some but it will do it. Screen uses more battery than anything. But I always try to max out the battery.
    Attached Thumbnails Droid Turbo: Battery Life-1415935545562.jpg
    11-13-2014 10:30 PM
  16. bizzyqu's Avatar
    what are your settings? I cant break 16 hours
    11-13-2014 11:06 PM
  17. mobrules's Avatar
    I use Tasker. Triggers are screen time out and wake up. For time out the actions are mobile data off, vibrate ringer, auto sync off, bluetooth off and wifi off. The actions that apply to wake up are the same but just reversing and connection mobile data on, auto brightness on and auto sync on.
    Calls and texts still come through. Email and twitter sync when the screen wakes up.
    Im now at 16% with 2days 8hours. 7hour screen and 56 hours phone radio. Hope this helps. Any questions just ask.
    11-13-2014 11:18 PM
  18. Brian Singleton's Avatar
    How is Tasker these days? I used it with my OG Droid 5 years ago, but haven't installed since. Has it evolved? More user friendly?
    11-14-2014 09:49 AM
  19. mobrules's Avatar
    I had a hard time with it at first but found youtube videos that helped me set it up. Ive had it running now for two weeks and havent had any problems. I used the smart actions on my RMHD the same way as I use Tasker. I was pretty spoiled by smart actions but this is working.
    11-14-2014 09:58 AM
  20. calibr21's Avatar
    Another 15 hour day
    The battery consumed by your display is definitely above average. For most users, the display consumes 5.5-6% of the battery / hr. Yours is closer to 9%.
    Are you using manual brightness instead of auto, resulting in a brighter display? Or are you using your phone outdoors a lot?
    11-14-2014 12:56 PM
  21. bizzyqu's Avatar
    Using auto, mostly indoors. Having a good day so far today 80% charge after 5 hours. 1hr 14min screen on.
    11-14-2014 01:36 PM
  22. ckelly33's Avatar
    I bought Tasker years ago and found it crazy complicated - and just gave up. I'm actually pretty happy with battery life but more is good, right? Can Tasker be set up to data-connect regularly (like every 1-2 hours) to pick up email rather than only on screen on? I don't want to limit my Turbo's functionality TOO much
    11-14-2014 01:49 PM
  23. jemcmichael's Avatar
    Earlier in the thread you were using AutomateIt. Why did you end up switching?
    Sent from my XT1254 using Tapatalk
    11-14-2014 03:24 PM
  24. mobrules's Avatar
    I havent messed with it enough to know. Sorry
    I think both work about the same. I watched some youtube how-to videos for tasker and tried it. Just decided to stay with it. No real other reason. Seems to work thought.
    Just Fyi- I just flashed/installed 5.0 onto a nexus 7 and there is a battery saving setting in it. So Tasker might have been a hasty purchase. Time will tell.
    11-14-2014 04:05 PM
  25. bizzyqu's Avatar
    Finally on track for +24 hours
    Attached Thumbnails Droid Turbo: Battery Life-12102.jpg
    11-15-2014 07:47 AM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
