10-12-2015 05:30 PM
1,125 ... 2324252627 ...
tools
  1. mobrules's Avatar
    Finally on track for +24 hours
    Congrats man!!!!!!
    11-15-2014 09:49 AM
  2. robertopod1968's Avatar
    I think I'm just a battery drain. Every phone I've had has always had battery problems. Bought the Turbo a week ago. Today was a heavy use day. Sick kid playing games, Facebook, pictures and maybe an email or two and a few chrome searches Unplugged the phone at 8am, now it is 10pm I'm at 24% battery left! Checked the battery usage and it says the screen used 65% of the battery. But still....its only been 13 hours...better than my last phone that only lasted 4 without using it but still.....what happened to my 48 hours of battery?
    That's awesome battery life. Lasted you all day with kid game time and still could have went another 3-4 + hours depending on usage! Its 48 hours of normal usage which pretty much means not using it at all. But if it lasts 16 or so hours of heavy usage then who cares. Plug it in and sleep!
    11-15-2014 10:11 AM
  3. Rogus's Avatar
    Just an update after 15 days of having the DT. Average Per Complete Charge is 37 hours. I've been doing a full charge every other night usually starting from 5-10% battery left. I have no complaints about battery life.
    11-15-2014 10:25 AM
  4. jsieplinga's Avatar
    So does anyone else see a negative value for their mA? See the screenshot below with over an hour of screen on time. A never ending battery? I'll take it!
    Edit: Oops, didn't realize the volume was covering the top part. It read -479 mA
    Attached Thumbnails Droid Turbo: Battery Life-1804.jpg
    11-15-2014 12:51 PM
  5. camachinist's Avatar
    I've gone beyond the specs stuff and now just throw the phone on the charger when it gets down into the 20's, which is generally every third day in normal use. That's acceptable to me and pretty similar to my prior, non-smart, phone.
    11-15-2014 01:26 PM
  6. MA2GA28's Avatar
    Looks like you have the battery drain bug. Been reported on here a few times, where the phone doesn't register spent battery. May have to clear the cache partition to reset it, though some have said just turning the phone off and on a couple times also works.
    11-15-2014 01:30 PM
  7. eprindes's Avatar
    I bought Tasker years ago and found it crazy complicated - and just gave up. I'm actually pretty happy with battery life but more is good, right? Can Tasker be set up to data-connect regularly (like every 1-2 hours) to pick up email rather than only on screen on? I don't want to limit my Turbo's functionality TOO much
    Yes, I have mine set up to cut on auto sync every hour for 3 minutes to let everything sync and then cut off.
    ckelly33 likes this.
    11-15-2014 03:03 PM
  8. 1901Madison's Avatar
    Couldn't be happier with the Turbo battery. Today, 16 hours off the charger with over 5 hours screen time. Still 50% left. Math says I should be able to get 10+ hours screen time with 32 hours off the charger.
    Attached Thumbnails Droid Turbo: Battery Life-11641.jpg   Droid Turbo: Battery Life-11639.jpg   Droid Turbo: Battery Life-11640.jpg
    11-15-2014 09:45 PM
  9. Karl Turbo's Avatar
    The 1st day I got my Turbo I got 30 hours out of it and wondered what the fuss was about.
    Today as an experiment to max out battery life, I turned off GPS and set screen timeout to 15 seconds.
    Droid Turbo: Battery Life-screenshot_2014-11-15-23-30-08.jpg
    At least my screen usage was minimized.
    I'm stumped - I was busy working all day and certainly didn't look at any email. I did experiment with Moto Connect, maybe that's a battery guzzler? Also did more speech-to-text than normal, another possible battery guzzler?
    11-15-2014 11:51 PM
  10. donebrasko's Avatar
    Anyone else having problems with amazon kindle app? Mine is draining my battery but I never used it. I don't want to disable it because I may use it in the future. Has this happened to anyone else?
    11-16-2014 01:15 AM
  11. bizzyqu's Avatar
    were you in an area with no service?
    11-16-2014 01:17 AM
  12. cyberr8der's Avatar
    Was one of the 1st things I disabled. Is there an option to sync? Maybe set it to manual of so.
    11-16-2014 01:27 AM
  13. Littlejoe919's Avatar
    There's no reason not to disable it. Just turn it back on when you want to use it.
    11-16-2014 07:31 AM
  14. hal1's Avatar
    Looking at the screen shots on this thread shows that all (not some or most) show a negative mA.
    11-16-2014 07:35 AM
  15. 1901Madison's Avatar
    What does that mean?
    11-16-2014 09:37 AM
  16. ryuuzaki#AC's Avatar
    Droid Turbo: Battery Life-unnamed.jpgDroid Turbo: Battery Life-unnamed-1-.jpg so heres my battery life it drains rather quckly for me unless im on wifi which gives me a ton of hours but if im out and about its dead in a few hours i dont know why but ive disabled everything ive seen in this post maybe but i dont get it but yeah heres my times
    11-16-2014 10:19 AM
  17. cyberr8der's Avatar
    Do you have the Moto actions turned off? Can you share a shot showing your a awake time?
    11-16-2014 10:24 AM
  18. ryuuzaki#AC's Avatar
    i only have the display on since thats the only thing i do like from it and as for awake time today is alot better cause im home on wifi and had it charge around 7-8 fully cause it was at 10% so havent charged it since so this is for todayDroid Turbo: Battery Life-unnamed-2-.jpg
    11-16-2014 10:32 AM
  19. cyberr8der's Avatar
    That's allot of small wake-up calls. Do you have android device manager turned off?
    11-16-2014 10:51 AM
  20. jsieplinga's Avatar
    I really want to love this phone, but I an showing very high Android system and Kernel battery usage. My last phone (Maxx) had this as well. Could it be an installed app causing the high OS usage?
    Attached Thumbnails Droid Turbo: Battery Life-3743.jpg
    11-16-2014 11:09 AM
  21. hal1's Avatar
    He was concerned that his Gsam showed negative value for his mA (at least that's how I read it). I was pointing out that it seems that all of the posted screen shots show a negative mA. Unless you're not asking what I meant, but rather what a negative mA means.
    1901Madison likes this.
    11-16-2014 12:01 PM
  22. ryuuzaki#AC's Avatar
    i dont even have androidr device manager installed on my phone
    11-16-2014 12:25 PM
  23. cyberr8der's Avatar
    Go to your apps drawer and click Google settings. It's in there. Comes on all phones.
    11-16-2014 12:31 PM
  24. ryuuzaki#AC's Avatar
    Never noticed that before but turned it off lets see how it goes now thanks!
    11-16-2014 01:09 PM
  25. cyberr8der's Avatar
    Should help bring your wake locks down. Let me know how it turns out.
    11-16-2014 01:31 PM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
