10-12-2015 05:30 PM
1,125 ... 3031323334 ...
tools
  1. 1901Madison's Avatar
    Screen time on the Turbo rivals the Maxx, but idle drain is a little worse. I'm guessing that a software update (Lollipop?) will fix idle drain.
    12-09-2014 09:42 AM
  2. mobrules's Avatar
    I assume this can't be a good sign. I've had a few issues over the past few days. A few days ago it stuck at 100 percent for most of the day. Yesterday I went down to 28 percent and then just suddenly died and when I plug it back in was instantly at 100 percent. So last night I wiped the cache and charged to 100% and then just let it sit idle overnight to see what would happen . It was down to 70% in 2 hours and then 28% this morning. Does it seem worth calling a warranty replacement in on?
    http://tapatalk.imageshack.com/v2/14...f253374725.jpg
    http://tapatalk.imageshack.com/v2/14...533f742017.jpg
    Yea at this point I would switch it out. Youve tried everything there is to do so get a different one and hope its better.
    12-09-2014 09:46 AM
  3. PowrDroid's Avatar
    Here are my stats after about 34 hours. Still have 6% left. Didn't do much optimizing. Does this look good?
    Not bad, but you could do better. You have 3 hr. 25 min. screen time. That's not a lot. What is your email sync frequency setting? Location services setting?
    12-09-2014 10:15 AM
  4. PowrDroid's Avatar
    I concur.
    12-09-2014 10:16 AM
  5. doogald's Avatar
    At this point, don't you think so?
    The only thing I can think to try is to uninstall GSAM for a day and see if there is a chance that the app itself is causing a drain for some reason. But clearly less than an hour on screen time with 75% usage in less than 12 hours - something isn't right.
    12-09-2014 10:37 AM
  6. Snareman's Avatar
    I do think so now, yes. I thought maybe the sticking at 100% thing was a fluke, although it surprisingly didn't fix itself when I rebooted several times. The dying at 28% yesterday grabbed my attention as did the sudden 100% reported charge and then the big drop last night I think put me over the edge.
    12-09-2014 11:26 AM
  7. eric002's Avatar
    I would say moderate usage. This is my first time actually taking a screenshot and monitoring the battery performance which is why I am asking if its pretty good. I see a ton of people on here getting 5-6 hours of screen time. My Brightness slider is at about 20%
    Right right right but you would say that if I'm only I would get 15 to 18 hours a juicer moderate usage on my current phone and I did send for another replacement droid turbo I should be getting more hours on a charge right?
    12-09-2014 11:54 AM
  8. Snareman's Avatar
    Well, no go as of yet for a replacement. Called tech support who had me calibrate the battery by holding the power button for 15 sec til the phone rebooted, told me to charge to 100% and then leave it for 30min and then if that doesn't work I have to do a phone wipe and THEN I can get a new phone if its still bad. She asked if she could call me back in an hour to see how it was going. She was very nice, but I wanted to laugh at her. Do you think anything will have declared itself in an hour from now which is about when I should be pulling if off the charger???
    Incidentally, my phone just charged from 75% to 100% in about 5 minutes, which is not right since it usually charges at 1%/min on the turbo charger. Perhaps that turbo charging feature has finally kicked in. Maybe I should have let her call me back in an hour.
    12-09-2014 12:09 PM
  9. eric002's Avatar
    Actually it right away, the lady from customer service told me the same thing. That I just nodded my head in disbelief though. I'm expecting this new new phone in the mail today to be better hopefully. I'll update everyone as to if that's the case or not. Hopefully it is.
    12-09-2014 12:11 PM
  10. Snareman's Avatar
    So did you end up going through the whole, charge, wipe, etc process before you got a new one?
    12-09-2014 12:13 PM
  11. eric002's Avatar
    Yep plus I got the whole let the phone said 30 minutes after 100% fully charged to recalibrate the battery. Which might make a little bit of sense but I'm still getting an average of 18 hours on a charge which is bs for this phone if you know what I mean.
    12-09-2014 12:14 PM
  12. doogald's Avatar
    Wait, are you saying that the things suggested in the other thread from last night: http://forums.androidcentral.com/mot...ml#post4113240
    didn't work? Specifically,
    1. You plugged in the phone and did a cache wipe with the phone plugged in
    2. You kept the phone plugged in for 30 to 45 minutes after it reported 100%
    3. Also importantly, you stopped using Qi charging
    and all of this didn't solve the problem?
    12-09-2014 01:15 PM
  13. Snareman's Avatar
    Yes. I did all of that last night. I didn't use the Qi charger last night. Charged with the turbo charger and let it sit overnight. She had me do the one additional thing of holding the power button down for 15sec until the phone rebooted. She said that recalibrates the battery somehow. I'll jump through their hoops (and try it one more time) and see what happens.
    12-09-2014 01:20 PM
  14. ffactoryxx's Avatar
    I have my exchange email set to 5minutes or push. Turned off Gmail sync. Location battery saving mode. Any other things you can think of?
    12-09-2014 02:15 PM
  15. PowrDroid's Avatar
    I could mention a lot more, most of them are listed in this thread.
    When you say you turned off Gmail sync, how did you do that? Within the Gmail program itself?
    I'd probably turn the exchange email sync down to 15 or 30 minutes, if you can live without email for 15 minutes. [Ha!] I would be curious to know how long your phone takes to poll your email servers. If you can watch your phone's notification area for 5 minutes until the Email program polls your servers you can see how long it takes by watching the busy icon (I think. I can see it with my K-9 email program.) I mention it because email was one of the battery users in your screenshots you posted.
    Go into Settings > More > Mobile Networks > Preferred Network Type > LTE/CDMA
    Go into Settings > Data Usage > scroll down and long press on Android OS and/or Android System and see what is using battery. Maybe you can shut something else down or completely off.
    12-09-2014 03:25 PM
  16. Sean Cogan's Avatar
    I've been following this thread off & on since I got my Turbo and thought I would post what I am getting out of my battery. I'm not going to take the time to post screen shots to "prove it", etc. so take it for what you feel it's worth. I'll take no offense if you call bullish*t.
    Settings:
    Brightness at 30%.
    Location is always on high accuracy, with very light use of Maps.
    Bluetooth is always on, only connects in my car.
    WiFi always on, only connects at my house, approximately 50% WiFi/50% 4G.
    All Moto screen actions, assist & voice are turned off, all screen notifications are turned on.
    Home screen widget is Chronus with time, weather & battery %.
    I receive & handle an average of 50 emails per day. Using stock e-mail app. Corporate e-mail is 'push', personal e-mail synchs every 15 minutes.
    I average 45 minutes of phone calls and 10-12 texts.
    Heavy Chrome browser use, news feeds, stock updates & web surfing.
    No Facebook or other social media used.
    I am now averaging 30 hours battery with 9.5 hours screen-on time.
    No complaints here.
    12-09-2014 04:35 PM
  17. Snareman's Avatar
    BTW, are you suggesting to not use Qi at all going forward? And what does that do or what does the Qi cause?
    12-09-2014 04:46 PM
  18. doogald's Avatar
    Based on the reports from those threads in the Motorola forum, it seems that the common experience for people reporting these issues of the battery meter not reporting proper levels are people who are charging with Qi. My guess is that there is some sort of issue with the battery meter incorrectly reporting full charge when you use Qi when there is still capacity. If it were me, I'd go through a cycle where I use the phone until it powers off on its own from low battery, fully charge by plugging in without unplugging, and then not using Qi again until there is a software update for the phone.
    That's just a guess on my part. I like Qi charging, but I don't *need* it. It's nice to have for me, but I can live with plugging in.
    12-09-2014 05:36 PM
  19. MR Hussey's Avatar
    So I've disabled almost all bloatware, kept the motoactions, downloaded Automateit and set it to screen off-sync off, greenify to close all nonessential apps after 5 minutes of screen off, Bluetooth and WiFi on, screen brightness auto, fairly good signal most of the time. I average around 18 hours with 3.5 hours of screen time. The longest I've ever gotten it has been 22 hours. I would consider myself a moderate user.
    Is this about what is expected or do I have something fishy going on? I didn't expect the full 48 hours claimed, but I thought I'd be able to hit 20 hours of heavy use with everything enabled no problem.
    Oh, and I've had the phone since Oct 31st. That's important to know. Have drained it completely and let it fully recharge several times.
    12-09-2014 09:43 PM
  20. Johnny Fever's Avatar
    PowrDroid-
    Where do you find sync setting for gmail/google stuff? I found it for my yahoo mail but not gmail.
    Also how much do the LTE/CDMA settings matter?
    Mine is currently "global"...
    Im getting phenomenal battery life... so far....
    JF
    12-09-2014 10:03 PM
  21. doogald's Avatar
    PowrDroid-
    If you don't mind me answering, from home open "Settings". Look under "Accounts" for "Google" and tap it, tap the Google account you want to change, uncheck "Gmail" (and whatever else you don't want to sync.}
    In my experience with a Droid Maxx, it doesn't matter at all. I think that they only time it would matter is if you find yourself getting a message that it cannot find a network and it asks you to connect to a GSM network. That rarely happens to me; in fact, I may have only seen this outside the US.
    But I'd say try it for a few days and see if it makes a difference for you.
    PowrDroid and Johnny Fever like this.
    12-09-2014 10:09 PM
  22. Johnny Fever's Avatar
    Ok thanks.
    With yahoo mail, you can select at what time intervals it will sync.
    From what I can tell, google only lets you turn off the sync...not set it at intervals. Truth is, I havent checked to see how often its been syncing by default. Does anyone know that?
    Yahoos longest time was up to one hour.
    12-09-2014 11:44 PM
  23. doogald's Avatar
    That's right. It uses push sync, so there is a service that receives updates when they are available from the server, using a service called Google Cloud Messaging. For a lot more info about that, see Google Cloud Messaging - Wikipedia, the free encyclopedia
    12-10-2014 07:01 AM
  24. mobrules's Avatar
    As with everything your mileage may vary. Can you post screenshots of the gsam battery monitor apps? Need to see the main screen, the app sucker screen and kernel wake locks screen. I think the screen and 4g signal are the biggest battery hogs. Everyone is going to have different results though. Post the screen shots and there's several members in the thread that will try to help if you like. You also did not mention location settings. That can drain a battery also. But some people use and need it.
    12-10-2014 09:13 AM
  25. HES's Avatar
    I too did a switch out. I am guessing I just had a bad battery. We'll have to see.
    mobrules likes this.
    12-10-2014 10:04 AM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
