10-12-2015 04:30 PM
1,125 ... 3132333435 ...
tools
  1. Snareman's Avatar
    I too did a switch out. I am guessing I just had a bad battery. We'll have to see.
    Did you have to go through the process of the charging to full and letting sit, doing a phone wipe, etc and still had a problem even after all that? Mine seems to be running ok since I did the stuff yesterday (thankfully not a wipe). We'll see if it stays steady. I let it sit overnight last night and instead of losing 60% it only lost 4%. I guess that's an improvement. :-)
    mobrules and doogald like this.
    12-10-2014 11:50 AM
  2. eric002's Avatar
    I have the same thing with my older turbo. Battery will last about 15 to 18 hours on average per charge. I had to do a it was customer service trying out a second new phone. Hopefully better results. I will post results when I go to my fullest full charge.
    12-10-2014 05:41 PM
  3. Snareman's Avatar
    What does that mean?
    12-10-2014 06:29 PM
  4. eric002's Avatar
    Meant to say that I called up customer service and tell them that I was only getting about 15 to 18 hours of juice in charge now I am cycling the new battery on the phone and seeing what's up with that too.
    12-10-2014 10:20 PM
  5. Karl Turbo's Avatar
    So I was averaging 2 days after getting a replacement phone due to an issue with the speaker in my first one. I thought I had a better battery as the original phone averaged 30-36 hours which seems typical for average users like me. Then I added a single POP3 account to GMAIL that gets maybe 10 - 20 emails a day, with polling set to 30 minutes.
    Droid Turbo: Battery Life-2014-12-10-05.19.06.jpg
    And there you have it. A crappy mail program that can't even do a Select All or Mark All Read sucks 25% of my battery life which is now down to the same 30-36 hours as before based on a single POP3 account. I've seen multiple complaints similar to mine related to Gmail, so I know this isn't an anomaly (also, Gmail used similar battery on 2 separate phones.) Does anybody know of a simple solution to this Gmail issue?
    12-10-2014 11:24 PM
  6. MR Hussey's Avatar
    Okay, here are my results from today. A few things-
    1. Usage today consisted of texting and web browsing, as well as 15 minutes of playing a game.
    2. It's odd that the during the period of time my phone was in deep sleep and had ~1% Discharge per hour, my battery percentage dropped at least 10%. See pic 2.
    3. Android and Kernel are both sucking up a lot of power. Too much if you're asking me.
    4. My phone wakelocks seem high. I've disabled syncing for most things besides google inbox and contacts. Notifications are turned off on any apps that aren't related to communication or work.
    I'm just not sure if this is typical or not. I am definitely not a super heavy user, yet my turbo barely gets me through a day. Should I try wiping my phone and starting over? What are people's results that have gotten a new phone from Motorola?
    Attached Thumbnails Droid Turbo: Battery Life-8278.jpg   Droid Turbo: Battery Life-8281.jpg   Droid Turbo: Battery Life-8282.jpg   Droid Turbo: Battery Life-8283.jpg
    12-11-2014 02:03 AM
  7. doogald's Avatar
    Try using the email app k9 instead for non-gmail accounts. That should be better.
    rxgadget likes this.
    12-11-2014 06:41 AM
  8. doogald's Avatar
    Is inbox required for you? I used it for two full weeks and have gone back to the Gmail app. Inbox definitely drains battery faster than the Gmail app, and has fewer features anyway (including two steps to delete messages, no way to mark messages unread, no ability to change the notification sound, no way to shorten the quotes on message replies.)
    GatsbyGlen and HES like this.
    12-11-2014 06:46 AM
  9. PowrDroid's Avatar
    This is an option. What about the stock email app?
    12-11-2014 09:13 AM
  10. GatsbyGlen's Avatar
    I use AquaMail and configure it to check mail once every 4 hours. Otherwise, I check on demand.
    12-11-2014 11:40 AM
  11. Karl Turbo's Avatar
    I've used K9 before. Didn't really excite me though that was a couple of years ago.. Any reason why it would use less battery? I can generally live with the Gmail after the initial shock of having to manually mark 100 emails as read (can't believe Google never thought of such a blindingly obvious occurrence - I wanted to throw my phone away after setting up 3 email accounts when I first got it.)
    12-11-2014 06:05 PM
  12. doogald's Avatar
    I believe that k9 allows select all and it's worth checking out to see if it uses less battery. It may. Could be that Gmail just downloads any available messages each time it checks, while k9 just downloads what it hasn't already. Who knows. You can find out by trying - it's a free app. You can always uninstall it if it doesn't work out.
    Karl Turbo likes this.
    12-11-2014 07:40 PM
  13. bfranker's Avatar
    I too found the stock email and gmail apps to be unacceptable. Tried some and settled on Blue Mail. I like it a lot better than even my previous Android stock email app on my Razr Maxx. I've got 3 POP3 accounts getting checked every hour and it doesn't even show up on my battery meter. LOL I was checking every 15 minutes and don't recall there being any noticeable battery drain with that frequency either.
    12-11-2014 08:53 PM
  14. mobrules's Avatar
    Soooooo..... This is interesting. Got the VOLTE update last night. No big deal on that but I wonder if they added some other things with it. I have Tasker set up to shut down 4g and background data from a 2200-0600. I usually lose about .5 to 1.0% battery per hour of those hours(at night). Charged up before bed last night, unplugged and watched about 10 minutes of HBO GO, then asleep. Got up today and battery is at 97% and lost average of. 03% overnight. That was at over 9 hrs up time. That's freaking awesome. Maybe it's an a fluke but I also wiped the cache after the update last night. I won't be able to really test it until this weekend. Anyone else noticing something like this?
    12-12-2014 07:57 AM
  15. fonger13's Avatar
    I don't think it's a fluke, I believe they made some fixes to the idle drain, I don't turn my 4G off so my normal drain is usually 1 - 1.2% per hour, now it's .6-.7, love it! But I heard the stuck at 100%/quick charge/quick drain bug haven't resolved yet.
    mobrules likes this.
    12-12-2014 08:17 AM
  16. 1901Madison's Avatar
    Glad to see others are seeing this too! Before the OTA update, I used to lose about 1% hour idle drain. Today, took the phone off the charger at 6:45am, but the phone didn't drop to 99% until about 8:30am, and that includes a couple of text messages and some screen time. I won't really be able to measure until I go through more of the day, but it sure looks like whatever was included in the OTA update greatly improved idle drain. Very excited about this. NOW we might be able to get more like the 48 hours mixed usage that was advertised.
    12-12-2014 09:10 AM
  17. ckelly33's Avatar
    Definitely a battery improvement for me as well.
    12-12-2014 10:27 AM
  18. Rhyno81's Avatar
    Does anyone have a good app for automating things like wifi on/off? I'd like to be able to find an app that logs my location when I successfully connect to a wifi signal, prompt me to add that location as a stored location, and then auto-start my wifi when I am in those locations and auto-off when I'm out of those locations.
    12-12-2014 03:08 PM
  19. mobrules's Avatar
    1 Tasker
    2 Automateit
    3. MacroDroid
    I cant take credit for the last one. Someone posted that in a different thread. (EDIT- PowrDroid) I primarily use tasker. However I really like the looks of MacroDroid.
    12-12-2014 03:24 PM
  20. doogald's Avatar
    Llama is good for location based switches as well, though not like what you describe (i.e., when you attach to a WiFi access point, have that location marked as a place that toggles WiFi.) But you can mark a connection to a particular cell tower to toggle WiFi on (and, when you leave that location, toggle it off.)
    That said, my huge guess would be that using geofencing like that probably drains the battery faster than just keeping WiFi on all of the time, unless you are doing this for security reasons instead.
    12-12-2014 03:38 PM
  21. HES's Avatar
    I tried all of that prior to getting on the call. I tracked the battery for a couple of weeks. That way when I got on the call with Verizon I didn't have to screw around. I had a new phone shipped to me within an hour of getting on the phone.
    12-12-2014 03:54 PM
  22. anon(5061193)'s Avatar
    I just can't say enough about the Turbo battery.. A full day and a half...at least..and it seems to be getting better.
    12-12-2014 05:35 PM
  23. Eclipse2K's Avatar
    There's no way the phone can keep this up. I'm just waiting for the rapid drop in battery, lol.
    Sent from my Motorola Droid Turbo
    Attached Thumbnails Droid Turbo: Battery Life-uploadfromtaptalk1418428387907.jpg
    12-12-2014 05:53 PM
  24. beeare's Avatar
    Anybody know what this wake lock is? Started hitting me today, the 2nd day after the update. The first day was phenomenal, but today, not nearly as good.
    Attached Thumbnails Droid Turbo: Battery Life-1418429372113.jpg
    12-12-2014 06:10 PM
  25. quantum tao's Avatar
    did you try rebooting, clear cache stuff?
    Droid Turbo: Battery Life-screenshot_2014-12-12-19-24-00-1-.jpg
    12-12-2014 06:26 PM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 07:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 03:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 09:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 01:13 PM
