10-12-2015 05:30 PM
1,125 ... 3940414243 ...
tools
  1. this_is_nascar's Avatar
    Screen On Time.
    Sent from my Ballistic Turbo
    Thx.
    Sent with my Kindle Fire HDX 7" via Tapatalk.
    01-23-2015 07:27 PM
  2. KA1OTE's Avatar
    This is my husband's phone, pics taken last night when he finally couldn't take it anymore and needed to charge again. (In actuality, he could've lasted through today I think.)
    Other than the SoT, I'll need to compare my phone to his to see what he's doing and what I could do to get closer to this battery life.
    This Turbo is a BEAST!
    Droid Turbo: Battery Life-screenshot_2015-02-09-22-40-42.jpgDroid Turbo: Battery Life-screenshot_2015-02-09-22-41-02.jpgDroid Turbo: Battery Life-screenshot_2015-02-09-22-41-11.jpg
    02-10-2015 03:23 PM
  3. lgbalfa's Avatar
    does your battery drain if you are connected to wifi?
    02-11-2015 12:47 AM
  4. Erick Garnica's Avatar
    With almost every phone it does including this one. When I don't use my phone I turn off WiFi for better battery management. But that's just me
    02-11-2015 01:08 AM
  5. 88horizon5speed's Avatar
    When I put my phone down I have GPS, data, BT and WiFi off. If I turn on my screen and need any of them ill turn them back on and off as I need. I leave sync on always because its a pain in the neck. If i disable sync and then reenable it sometimes chrome wont be checked and i have to go re check the box to sync chrome- very annoying. when i go to sleep i turn it on airplane mode and restart to close all apps
    02-11-2015 09:09 AM
  6. mobrules's Avatar
    I use Tasker. I have triggers set as screen timeout. Screen off-shuts down background sync, shuts off 4g, shuts off wifi, and shuts off Bluetooth. Screen on- re-enabled everything. For me it works flawlessly. I want to be able to control what runs in the background. I just don't see the point of data and battery being used when the phone isn't being used. It also extends this already awesome battery. I usually charge around 50% and 48 hours. Somewhere in this thread are screen shots showing my setup and results.
    02-11-2015 10:43 AM
  7. this_is_nascar's Avatar
ID:	162869Click image for larger version.
ID:	162870Click image for larger version.
    Maybe I don't know how to properly read these charts as of yet, but from what I can see, he really didn't do anything on the phone, did he? Less than an hour and a half on screen time over 3-days, seems as if not anything was really done on the phone. Don't get me wrong, that's still awesome battery life, but it doesn't appear the phone was used for anything.
    02-11-2015 04:27 PM
  8. mobrules's Avatar
    You are correct. But we all use it differently. I have gone 3 days before with about 5-6 hours screen time. But there are so many things that go into battery life I don't think you can truly compare 2 different users. Signal strength, screen brightness, background apps, gaming and apps, WiFi connection vs 4g. These are just the first examples that come to mind.
    02-11-2015 05:03 PM
  9. this_is_nascar's Avatar
    You are correct. But we all use it differently. I have gone 3 days before with about 5-6 hours screen time. But there are so many things that go into battery life I don't think you can truly compare 2 different users. Signal strength, screen brightness, background apps, gaming and apps.
    Thanks, I understand that. I would have loved to seen the stats for the 3-days with 5-hours OST. I don't think I've ever come close to that as of yet and don't expect that I ever will, even with the Turbo.
    02-11-2015 05:08 PM
  10. mobrules's Avatar
    I think there are screen shots somewhere back in the 100 pages of this thread. Check them out. There's a lot of good tips in this thread specifically.
    02-11-2015 05:21 PM
  11. this_is_nascar's Avatar
    Thanks, I'll take a look.
    02-11-2015 05:25 PM
  12. KA1OTE's Avatar
    He used his phone. He is just extremely quick when checking company email or texting with me.
    His Turbo is also very bare-knuckled. He hasn't put anything on it.. only downloaded a handful of apps needed for his business travel (i.e., United, Poly World Clocks) and a few for banking and passwords. Other than that, he hasn't allowed me to do anything to it. Although I did talk him into letting me at least disable the bloatware. And even that took a certain amount of pleading on my part.
    02-11-2015 05:59 PM
  13. lgbalfa's Avatar
    if my phone is at 100% when i pull it off the charger and i don't use it for 10 hours while it is on standby, it usually is at about 91%.
    does that seem normal - a 9% drop in about 9 hours just on standby?
    thanks
    02-12-2015 10:02 AM
  14. MA2GA28's Avatar
    thanks
    Not sure how you'd not use it for 10 hours after a charge (unless you charge it right before bed and get a REAL good night's sleep). But, the discharge sounds about right. Overnight, my battery will typically drain 9-11% over 7-8 hours.
    02-12-2015 11:47 AM
  15. 88horizon5speed's Avatar
    my battery usually drops about 2-5% overnight
    thats with putting it on airplane mode and disabling bt, wifi, etc and using it for my alarm. If I left it normal id say 5-8%, 10% or more probably indicates something is syncing
    02-12-2015 11:58 AM
  16. Erick Garnica's Avatar
    Battery life monster
    Attached Thumbnails Droid Turbo: Battery Life-3165.jpg   Droid Turbo: Battery Life-3164.jpg
    02-12-2015 01:04 PM
  17. 88horizon5speed's Avatar
    I dont want to tell you how to use your phone, but I have done lots of research and running these batteries to 3% isnt exactly good for these batteries
    Eclipse2K likes this.
    02-12-2015 06:35 PM
  18. Eclipse2K's Avatar
    You can do it once in a while with no harm but this is correct. The juice is there if you need it but Lithium Ion batteries LOVE juice. Charge them when you can! I understand the need to go without long charges but I'm not sure why others don't want to charge each night.
    02-13-2015 03:53 PM
  19. 88horizon5speed's Avatar
    the proper care for lithium ion batteries is to usually run them down to about 25% battery and then charge back to 100 %. Every 30 days perform at calibration (not for the battery memory effect as Li-Ions dont have that) but to calibrate the devices built in battery sensor) by running it down to 5-7%. I do 7 because amounts under there can ruin the battery. These batteries are also not designed to have fade free power after many many charge-discharge cycles. If you charge it everytime you hit 75% saying "Im running low" thats a good way to deteriorate the battery because youll be using up many more charge cycles each day.
    On the Turbo, I use 1 charge cycle every 2-4 days (based on charging at 25-30%) because the battery life is so good. This will help extend the batteries life. If anyone disagrees on this method then please let me know what you do, I understand there is some debate in how to care for batteries so I am curious what others do. Also if anyone doesnt know I am running a long term statistical analysis on the battery life and health in my phone. I have recorded every piece of important battery and usage information since I bought the phone a few months ago.
    Eclipse2K and mobrules like this.
    02-13-2015 05:53 PM
  20. philly's Avatar
    phone has incredible battery life. easily get a days use with like 7+ hours of on screen time on it.
    02-13-2015 06:38 PM
  21. Erick Garnica's Avatar
    Same here. With disabling bloat ware and using greenify I have gotten great battery life every day no matter how hardcore I use my turbo.
    02-17-2015 03:32 AM
  22. robertopod1968's Avatar
    Now with a Turbo charge. An hour less screen time, but similar app usage, some BT streaming, and 10+ hours off WiFi. Something is up...
    Attachment 158648Attachment 158649
    The phone was held awake by something for almost an hour longer on the second one. That's the difference
    02-18-2015 11:26 PM
  23. 88horizon5speed's Avatar
    do you reboot your phone at times like for example before you go to sleep? This helps to kill off lingering apps and prevent them from using alot of battery
    02-19-2015 12:31 PM
  24. kirksucks's Avatar
    It's not the 48 hours they promised but it's not bad.
    Attached Thumbnails Droid Turbo: Battery Life-5943.jpg
    02-20-2015 12:24 AM
  25. 88horizon5speed's Avatar
    What is your screen on time? I dont see why everyone assumes that there are no factors going into the 48 hours? If your on your phone for 12 hours straight using an app like facebook you wont see the "promised 48 hours"
    02-20-2015 10:01 AM
  1. Droid Turbo on AT&T?
    By y2jdmbfan in forum Motorola Droid Turbo
    Last Post: 09-04-2015, 08:32 AM
  2. DROID TURBO: FYI tethering does not work (resolved 10/31)
    By Clocks in forum Motorola Droid Turbo
    Last Post: 11-18-2014, 04:13 PM
  3. Anyone go from an S5 to a Turbo?
    By lindseybp in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 10:31 AM
  4. DROID TURBO: How do I see pictures after I take one?
    By edgefever in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:46 PM
  5. Just Picked Up a Droid Turbo
    By Masheen in forum Motorola Droid Turbo
    Last Post: 10-30-2014, 02:13 PM
