Snareman
I suppose there are a number of issues discussed here. For one, the heat generated by running power hungry apps is not necessarily internal battery heat, so not sure it has the same implications. As for "charge memory", I recall reading that li-Ion batteries are not subject to that. The Turbo charger will charge my Maxx, but not at the higher output. I do believe the technology has been well tested, but I prefer the convenience of a qi charger and will continue to use that option for daily charging. I'm looking for a qi with a higher output. Thought I had read about one rated at 2 amps but now I can't find it. Power transfer on most of them is only 70%.
I've been wondering about that as well. I'd assume they will show up at some point.
