08-27-2016 10:17 PM
92 123 ...
tools
  1. Clocks's Avatar
    It comforts me that its the only charger included (they wouldn't have done that if it was bad, right?), but since I'll never need a mid-day charge I wonder if it would be at all healthier for the battery to simply use a normal 1a charger overnight.
    10-30-2014 04:47 PM
  2. wcshort22's Avatar
    The charging slows as the percentage goes up so I don't think it hurts it too bad if at all
    10-30-2014 04:48 PM
  3. Firedogee's Avatar
    I'm a fan of using exclusively whatever charger is included in the box. I think this is why my previous Droids last so long.
    Sent Turbo fast from my 64GB Droid Turbo
    mumfoau likes this.
    10-30-2014 04:52 PM
  4. dungoyle's Avatar
    My current plan is to keep the turbo charger in my brief case for emergency charge purposes. Otherwise, I'll probably just drop the phone on a QI pad.
    EDIT: The turbo charger is wicked fast BTW. I used it to get my initial 100% and it took very little time to get there.
    Emperor likes this.
    10-30-2014 04:54 PM
  5. Masheen's Avatar
    I was wondering the same. I asked that question in the other thread. Does the turbo charger speed hurt the battery when compared to a slower charger? Should it be used when absolutely necessary or every day/night? I assume the answers to these questions are no, it does not harm the battery. I don't think that Moto would have included it stock if it did. They assume (rightfully) that we will all use the included charger as our main charger for this phone. There would be future lawsuits if it damaged the components of the phone, including the battery.
    It is interesting to discuss though. Everybody has something different to say when it comes to these Li-Ion batteries. My father bought the Note 4 the other day and they told him to let the phone discharge to 5% before fully charging it to 100% at least three times to "condition" the battery. They further said that if you charge your phone at 50% instead of when it gets low, that the phone recognizes 50% as being "low" and battery life will decrease.
    Whether or not that is true, my father listened to the T-Mobile salesman for his previous phone, the G2, and noticed significantly less battery life when he started charging at 50% after always charging when it got very low.
    10-30-2014 04:55 PM
  6. smd4usc's Avatar
    Is it both pieces that make it turbo charge or is it the part that plugs into the wall?
    10-30-2014 05:42 PM
  7. dungoyle's Avatar
    The USB cable that goes from the wall wart to the phone looks like an ordinary USB cable.
    10-30-2014 05:53 PM
  8. Firedogee's Avatar
    Just the wall part, and requires the hardware in compatible phone chipsets (like the Turbo) in order to work at the higher charge rate.
    10-30-2014 05:57 PM
  9. aue123's Avatar
    i tried plugging the Droid Turbo charger into the Droid Maxx to see if I could even get a "regular" charge and it doesn't even register on the phone.
    Guate2 and dmark44 like this.
    10-30-2014 06:08 PM
  10. stormweaver1983's Avatar
    Good to know!
    10-30-2014 06:17 PM
  11. aue123's Avatar
    Turning off the Turbo at 11% and plugging into the Turbo charger, 33 minutes later its at 48% Phone feels slightly "warm"
    10-30-2014 06:34 PM
  12. tdizzel's Avatar
    That's odd. I plugged it into my Ultra and it charged just fine.
    I probably won't use the Turbo charger much. I'm not comfortable with how warm it gets even though it probably won't really cause much damage. I'll only be charging it at nighttime so the old school charger should work just fine.
    Busted51 and dmark44 like this.
    10-30-2014 08:52 PM
  13. macawmatt's Avatar
    Not here. We have a high powered USB hub that we charge our phones and bluetooth devices through. Will be plugging a Qi charger into a port though instead of plugging the phone in every night.
    11-10-2014 09:57 AM
  14. paintdrinkingpete's Avatar
    A lot of the "speed" of a charger is related to the USB standards regarding the power output. For the most part, the rate at which a charger can charge a device is dependent on the amps that the charger can deliver, because USB power is generally set at 5V (Amps x Volts = Watts). What Motorola did with the "Turbo Charger" is actually increase the voltage that it can deliver to higher than 5V. If you look at the specifications on the charger, I believe it's actually rated to provide output at 3 different power levels: the standard 5V, 9V, and 12V. By doing this, they are able to deliver considerable more watts than a standard USB changer which is limited to 5V output.
    In order to comply with USB, the charger must normally operate at the standard output of 5V, and it only steps the voltage up with the device it's connected to is designed to use it.
    The Droid Turbo's processor is built recognize the required power level and accept the higher voltage output, and then step back once fully charged, just as any other phone does. For this reason, you should have no issues plugging it in and walking away and/or leaving it charging overnight -- at least not any more than any other phone with a regular charger. (The "should I charge my phone" overnight is separate argument in and of itself).
    I've noticed the phone gets quite warm when charging on the turbo charger, but cools down quickly once it reaches 100% battery, even if it's still plugged in.
    The part that plugs into the wall is what delivers the extra power, however I wouldn't be surprised if the cable were specially made as well...it's possible that if you used a generic USB cable that the turbo charging features wouldn't work. (I haven't tested that)
    I'm kind of surprised by this, because it did work with my tablet and my bother in-law's phone. Whether it works or not, just know that unless the phone has a processor that allows it to use the "turbo charger" setting, it will charge at 5V/1.6A and not the higher power levels, so it won't charge other devices any faster than their usual charger.
    11-10-2014 01:02 PM
  15. Masheen's Avatar
    I had posted this, but it got buried in a battery life thread. I'm going to post it here, since it has good information pertaining to this subject.
    "To put everybody's concerns at ease. I've been researching Qualcomm QuickCharge 2.0 to see if it is damaging to the phone or battery. On QC's website, they have done extensive testing (done by UL) and have built temperature monitoring software into their new chipsets that communicates with the charger and adjusts accordingly. I believe that when our phones do get hot due to Turbocharging, which is a Motorola re-brand for QuickCharge 2.0, it has been tested to not harm our phones or the battery within them. Technology advances at a rapid pace, and just like lithium ion capacity increased over the years, the temperature threshold must have as well. Just think, Motorola and Qualcomm would not publicly release a product that may potentially cause hardware damage, the lawsuits would ruin their company. I believe that this feature has been thoroughly tested and is fully baked. We shouldn't worry. "
    http://industries.ul.com/blog/qualcomm-quick-charge-2-0
    https://www.qualcomm.com/info/analys...m-quick-charge
    acentralmt and EleGenius like this.
    11-10-2014 02:36 PM
  16. NoahForeman's Avatar
    Qi every night, Turbo Charger only for emergencies.
    Posted via the Android Central App on my Droid Turbo.
    11-10-2014 02:55 PM
  17. sharkita's Avatar
    I ordered the turbo charger to use with my 2014 Moto X, and I must say it's awesome - I just love it! I was also a bit nervous about using it as my daily charger, but I'm starting to use it more and more. It's really neat Moto ships it with the Turbo, since I paid over $40 for mine. I sincerely don't think Moto would send only the turbo charger if it wasn't safe to use all the time, even overnight. They have to assume a number of Turbo owners are switching from iPhones and don't have one or two (or a drawer full in my case) of old chargers to fall back on, right?
    11-10-2014 03:18 PM
  18. paintdrinkingpete's Avatar
    I would think those are safe assumptions. If a phone ships with a charger, and provides no warnings to the contrary, you HAVE to be able to assume that it's safe for everyday use.
    I mean, the battery in the Turbo is so large that it takes a LONG time to charge on a standard USB charger as it is!
    11-10-2014 03:25 PM
  19. RobinsonR810's Avatar
    ya my turbo charger worked on a samsung galaxy s5
    11-10-2014 03:52 PM
  20. Zeppelin2k's Avatar
    I've been using a normal USB charger over the turbocharger. Yes, the turbocharger is safe and Moto would not ship it otherwise.. your phone is not going to catch fire because you're using it. The point is, it's not a matter of "causing irreparable hardware damage," it's about maximizing battery life. It's known that keeping a Li battery at high temperatures is going to lower it's life span (read How to Prolong Lithium-based Batteries - Battery University). The turbocharger is clearly outputting higher wattage to charge faster, which must generate more heat than a standard charger (that's just physics, you can't really get around this). And higher temperatures are going to lower the batter lifespan.
    How much of an effect this will have I can't say. I don't know how much hotter the battery gets with either charger (although speaking of this, it's pretty easy to monitor temps and I should do so...). For all I know, this newer battery is much better at handling high temps, but I haven't heard anything about this. So for now, I'll stick with a normal charger unless I need the turbo.
    acentralmt likes this.
    11-10-2014 06:13 PM
  21. Masheen's Avatar
    Depending upon what else is going on while it is on the turbo-charger it can get pretty hot. For example, Google+ backup for pictures and videos, other syncs, MMS messages. I've seen my phone get to 46 degrees Celsius once (114.8 degrees Fahrenheit). Usually, it doesn't go over 40 degrees Celsius (104 degrees Fahrenheit).
    11-10-2014 06:31 PM
  22. anon(5630457)'s Avatar
    I've only used it once in the week I've had my Turbo. I use my wireless charger as my main charger, and I use it when I'm sleeping.
    11-10-2014 06:35 PM
  23. Masheen's Avatar
    That Battery University website is one of the first hits on Google when you search for how to prolong Li-Ion batteries. They have great information, however, the Qualcomm Quick Charge 2.0 is too new of a tech, and Battery University does not make a mention of how that type of tech would affect a phone like ours. I linked the Qualcomm website because they had UL extensively test the Quick Charge 2.0 tech after developing it, and I confide in them to give us a product that will not significantly lessen our battery's lifespan when used. I rationalize it by assuming they (UL & Qualcomm) know the temperature level that will harm the type of battery they use, and aim for a max temp lower than that. Also, if the tech has advanced to the point where Quick Charge is available, they may have also developed a type of Li-Ion that insulates and protects itself against temps that would normally damage that type of battery. I didn't allow myself to ruminate any longer over it. I don't keep a phone for more than two years, and the way tech advances, I'll be using something else before any sign of real battery deterioration occurs, if any at all.
    acentralmt, travaz and dungoyle like this.
    11-10-2014 06:45 PM
  24. paintdrinkingpete's Avatar
    That's a good point, especially if the phone is being used to do other things at the same time.
    I've definitely noticed my phone gets warm while charging, but it's no worse than when I'm using it for GPS directions, for example.
    My normal habit is plug my phone in after dinner in the evening, get it to a full charge, then unplug it. Especially with this phone that'll get me through until the next evening, but I do keep an old Blackberry charger at my desk at work for emergencies. I plan to keep using the turbo charger.... But I've been keeping an eye on just how hot it gets.
    11-10-2014 06:58 PM
  25. Masheen's Avatar
    Very true. My phone gets just as hot, if not hotter, while using GPS.
    11-10-2014 08:20 PM
92 123 ...
  1. Is the first boot supposed to take this long? :/
    By MRW1215 in forum Google Nexus Player
    Last Post: 11-16-2014, 10:21 PM
  2. Is There A Transfer Data App On The LG G3?
    By huntnyc in forum LG G3
    Last Post: 11-11-2014, 05:11 PM
  3. Can the Note4 even play music through bluetooth?
    By Jason W1 in forum Ask a Question
    Last Post: 11-11-2014, 01:25 AM
  4. Extra Turbo Charger Rec
    By JJD323 in forum Motorola Droid Turbo
    Last Post: 11-10-2014, 06:48 PM
  5. Resetting the Alternate password on my S5
    By nickzasaurus in forum Samsung Galaxy S5
    Last Post: 11-10-2014, 06:46 PM
