Re: Anyone else's Wifi signal doo-doo?
https://forums.androidcentral.com/e...om.farproc.wifi.analyzer&hl=en&token=2En9VTyr
run that on the DT and a couple others and you'll see the DT has pretty so-so
wifi reception. I've seen worse but I've seen a loooot better too.
I doubt anything is going to fix that.
One can have poor wifi reception and still get fine results with online speed tests,
it's not really very telling in this case. You are looking for the dB reading of the
signal, be it wifi G or N, or LTE/CDMA, etc.
As a point of reference, on my back patio I have a Nexus 7 that pulls -65db, a Galaxy S4
that is at -60db, and the Turbo which is at -70db, 5ghz 802.11n, didn't see a lot of difference
on G signal strength, other than on the N7.
You can absolutely cover the top edge of the DT with your hand and see the signal fall off like a
rock. I suspect the chip/radio is fine but the antenna is insufficient or not well routed or some such.
I have yet to try it out in the shop or in the far back yard, we'll see.
On the up side, the bluetooth range seems to be pretty good.
