03-15-2015 05:55 PM
38 12
tools
  1. flackberry's Avatar
    Anyone else having wifi issues? Mine pretty much drops out in my normal wifi areas - work and home. The Note 4 I took back and the icon I had before that worked fine. I even deleted the wifi connection and re-added with the same outcome. If it keeps up I'm going back to the store and asking that exchange it for another new one.
    10-30-2014 05:12 PM
  2. Firedogee's Avatar
    Did you accept the system update from the settings, phone info area. That may fix it.
    Sent Turbo fast from my 64GB Droid Turbo
    Richard Zingre likes this.
    10-30-2014 05:52 PM
  3. dungoyle's Avatar
    What Firedogee said. Mine works fine, and fast (39.71Mbps download)
    10-30-2014 06:04 PM
  4. Eclipse2K's Avatar
    Nope, mine works great!
    Sent from my Motorola Droid Turbo
    ajc312 likes this.
    10-30-2014 06:05 PM
  5. dungoyle's Avatar
    ^^^Wow.
    10-30-2014 06:06 PM
  6. Eclipse2K's Avatar
    ^^^Wow.
    Heh, I love Comcast.
    10-30-2014 06:07 PM
  7. Joe the Insider's Avatar
    My Wifi works great, Better on the Turbo than my Moto X 14
    10-30-2014 06:13 PM
  8. Firedogee's Avatar
    While watching Thursday night football on Wi-Fi I noticed the signal drops in half and video lags if I put my hand over the very top edge of the phone. This might be a defect?
    10-30-2014 08:16 PM
  9. billbrobaggins's Avatar
    Interesting, I just put my hands over the top half and went to 50% signal
    10-30-2014 08:51 PM
  10. flackberry's Avatar
    Tested at home on WiFi and the issue is the signal strength sucks. Compared to other phones in the house this one is low. I did do the small update today. I'm wondering if I should factory rest as maybe something changed with the update.
    10-30-2014 10:06 PM
  11. Firedogee's Avatar
    How can you compare signal strength? Are you seeing an actual signal numeric reading in an app or something?
    10-30-2014 10:12 PM
  12. cml21's Avatar
    My wifi signal is a lot weaker than other devices in my house. The wifi is also not turning on at reboot. Ugh.
    10-30-2014 10:15 PM
  13. Eclipse2K's Avatar
    Mine turns on after a reboot. Did you try and forget and reconnect
    cml21 likes this.
    10-30-2014 11:19 PM
  14. Robert Jordan1's Avatar
    The Flash app seems not compatible with Turbo?
    11-06-2014 05:12 PM
  15. lowrg3's Avatar
    Nah, mines good.
    Attached Thumbnails Verizon Motorola Droid Turbo Anyone else's Wifi signal doo-doo?-3108.jpg
    11-06-2014 05:23 PM
  16. wolf_walker's Avatar
    https://play.google.com/store/apps/d...analyzer&hl=en
    run that on the DT and a couple others and you'll see the DT has pretty so-so
    wifi reception. I've seen worse but I've seen a loooot better too.
    I doubt anything is going to fix that.
    One can have poor wifi reception and still get fine results with online speed tests,
    it's not really very telling in this case. You are looking for the dB reading of the
    signal, be it wifi G or N, or LTE/CDMA, etc.
    As a point of reference, on my back patio I have a Nexus 7 that pulls -65db, a Galaxy S4
    that is at -60db, and the Turbo which is at -70db, 5ghz 802.11n, didn't see a lot of difference
    on G signal strength, other than on the N7.
    You can absolutely cover the top edge of the DT with your hand and see the signal fall off like a
    rock. I suspect the chip/radio is fine but the antenna is insufficient or not well routed or some such.
    I have yet to try it out in the shop or in the far back yard, we'll see.
    On the up side, the bluetooth range seems to be pretty good.
    11-06-2014 05:34 PM
  17. RobinsonR810's Avatar
    I'm having the same issues! Ugh its so irritating and frustrating and depressing! I swapped it out for another phone and it worked well the first day and then BAM I have the issues AGAIN! uggh I don't know what to do at this point. I'm going to swap it ONE MORE TIME and if not then I'm just gonna go back to my old phone (first gen Moto X).
    But my issue is basically the wifi will only connect if I restart my phone. So once I connect at work then I leave for lunch and come back I have to restart my phone again to get back on the wifi. And sometimes that doesn't even fix it.
    dmark44 likes this.
    11-07-2014 03:47 PM
  18. RobinsonR810's Avatar
    Wow I cannot believe what I've gone through today with this phone. I installed the update, factory reset, wifi wouldnt connect at all. Then I went and put the phone in airplane mode and then wifi connected, for about 30 minutes and then disconnected. It wouldn't connect back. THis was at work so I get home and it won't connect at home. So I went to Verizon to switch it for the 2nd time. The guy was sooooo rude to my husband and I. I told him everything I've gone through and how it only fixes when the phone is restarted. I showed him how it wouldnt connect to any of the wifis there so he restarted it and of course it connected. I said well duh that's the fix but I"m not about to restart my phone every single time I need to be connected to wifi, that's absurd. So I told him I'll take a walk away from the wifi area so it can disconnect then I'll come back and I'll come back and it probably won't connect (because it does that to me all the time)...so I walk away, wifi isn't there anymore, I come back, and it freakin connects. So annoying it's like bringing a car to the mechanic and not recreating the problem. So anyways even though we showed him that it didn't work earlier and all he did was restart it to temporarily fix the issue he wouldn't exchange it. Now honestly if he were calm and told me that then I might have said oh well what can you do...but he told me that he went through my account and doesn't see any record of me trying to troubleshoot the issue with the techs. OMG I've spent so much time on the tech support chat with people that don't really try to help all that much and I specifically asked if I can see a tech to look at the phoen and they said they don't have techs at the stores...so I've chatted with people at verizon and they told me just exchange the phone. SO he basically calls me a liar saying that I never did any of the troubleshooting steps and he fixed it now so I should be good. And the way he talked to us was extremely rude, my husband tried to calmly explain that this is a temp fix but it will start acting up again like it has been all day. Well we got the manager there and the guy continued to talk crap to us yelling at us, it was so unprofesional and I can't beleieve he acted the way he did. THe manager told him to calm down but he continued to yell. Anyways, the issue could not be recreated (so annoying) so now I'll have to wait until the wifi stops working tomorrow and go back in for a replacement. I cannot believe that not a lot of people are having this issue as I've so far had two phones with the same problem!!!
    11-08-2014 12:06 AM
  19. hannsoft's Avatar
    http://tapatalk.imageshack.com/v2/14...3474633af9.jpg
    Nice numbers! I don't get that here with my laptop! ;-)
    Sent from my Droid Turbo using Tapatalk
    11-08-2014 06:49 AM
  20. hannsoft's Avatar
    No complaints here.
    Attached Thumbnails Verizon Motorola Droid Turbo Anyone else's Wifi signal doo-doo?-uploadfromtaptalk1415451063201.jpg
    11-08-2014 06:51 AM
  21. rwingert's Avatar
    12-15-2014 09:23 PM
  22. rwingert's Avatar
    Similar issue with me. Wi-Fi will work best when I turn phone to airplane mode, then Wi-Fi back on, with no phone service. Now I'm waiting for a replacement reconditioned phone. Not happy at all about that. Well see how this plays out. I'm so frustrated.
    12-15-2014 09:28 PM
  23. wolf_walker's Avatar
    I've seen more than a few people report cases of randomly disconnecting wifi, or wifi that will not re-connect to a knows and previously used network.
    Of all teh annoyance I'd have with wifi signal strength, I have not had those things happen at all.
    12-15-2014 10:20 PM
  24. VooDooCC's Avatar
    The turbo connects a lot better than my G'Nex ever did.
    12-15-2014 10:49 PM
  25. wolf_walker's Avatar
    Happened to have a first gen US Cellular CDMA Moto G on my desk today next to the DT, 4' from my $200 router..
    Verizon Motorola Droid Turbo Anyone else's Wifi signal doo-doo?-img_20141219_143912.jpg
    (wifi still blows)
    12-20-2014 04:42 AM
38 12
  1. Droid Turbo defective battery? any one see this?....
    Last Post: 12-11-2014, 04:34 AM
  2. Verizon Motorola Droid Turbo Top right speaker...
    By Danny1Bears3 in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 06:21 AM
  3. LG G3 - Call log not working! (Verizon)
    By eds1158533 in forum LG G3
    Last Post: 11-09-2014, 11:42 AM
  4. Why isn't the wifi on my Samsung working on my cell phone?
    Last Post: 11-07-2014, 12:23 AM
  5. Replies: 0
    Last Post: 11-06-2014, 07:36 PM
