03-25-2017 10:58 AM
585 ... 222324
tools
  1. gilgamess3's Avatar
    my droid turbo drains a lot because of Google play service; how can I fix it? Thanks
    09-15-2016 07:40 AM
  2. secretagent72's Avatar
    To take a screenshot simply press the power button and the volume down simultaneously
    11-30-2016 11:09 AM
  3. zen45's Avatar
    alerts about email, and adds and about software updates on line gps all drain your phone if you don't need them running all the time turn them off ! google drains your battery down , email alerts I don't need I will read them when I get home on my pc , my GPS I only use when I'm on the road then turn it off I only use text and phone service on my phone if something else is needed I turn it on and off when I'm finished, I charge my phone on the second or third day of use
    12-10-2016 10:08 AM
  4. PowrDroid's Avatar
    This requires an element of timing the presses correctly. If you can't get the hang of the timing a voice command will also work.
    Say:
    <your personalized Droid Turbo launch phrase>
    "Zap my Screen"
    12-12-2016 12:59 PM
  5. Lennie Johnson's Avatar
    I've had a Droid Turbo for a couple years, and for the past couple months, when I send a picture message by text, it wants to lock up, and say I can't send the message. Once I power down and back up, all is fine. What's the cause? Anyone else had this issue? I hate having to power down all the time, and would like a permanent fix to this. Love the phone, and this is the only quirk I have ever had with it.
    12-13-2016 09:51 AM
  6. PowrDroid's Avatar
    I've never had this issue.
    Does it lock up when sending texts over WiFi only? Or does it do it on WiFi and 4G? If you could test and see if it does it on WiFi and 4G it would be a data point in an attempt to find a solution.
    12-13-2016 11:19 AM
  7. kaleem kaim's Avatar
    Hi
    Whenever i swap sim cards n my motorola droid turbo it just signs out of all the accounts. None of the apps that requires some form of log in work with mobile data. Some like WhatsApp & viber work with wifi but not with mobile data even if I re insert the original sim back. App like Twitter stops working altogether even with wifi & cant b logged in & I have to re install it.
    Help me out if there z any solution
    01-04-2017 06:46 AM
  8. Raraw's Avatar
    My droid turbo want say droid can't hear nothing why is that
    03-05-2017 12:39 AM
  9. Raraw's Avatar
    My droid turbo doesn't speak droid like I hear other droid do !! why it and how can I fix it ? I want to hear my phone say droid.
    03-05-2017 12:43 AM
  10. zen45's Avatar
    you may have to set it up in "alerts" I have mine set up to say "what is your wish my master" when I receive a txt in darth vaders voice
    03-25-2017 10:58 AM
585 ... 222324
  1. Broken Droid Turbo
    By Kupo15 in forum Motorola Droid Turbo
    Last Post: 11-09-2014, 02:18 PM
  2. Replies: 2
    Last Post: 11-03-2014, 11:59 PM
  3. Replies: 0
    Last Post: 10-31-2014, 05:24 AM
  4. Picture Messages and multi text message.
    Last Post: 10-31-2014, 03:29 AM
  5. Replies: 0
    Last Post: 10-31-2014, 03:16 AM
