doogald
Trusted Member
I have a question. My phone goes blank. I'll push the on/off button to try to get the display back but it takes constant pushing of the button to come back on. I'm wondering if I should take it in to get checked out or am I doing something wrong.
I wouldn't say that you are doing anything wrong. It could be a problem with an app running in the background taking too many processor cycles. You can go into settings / battery usage and look at the list of items, and any apps that you recognize (usually display, Android System, and Android OS are listed toward the top of the list) may be the culprit.
Another idea is to run in safe mode, which stops third party apps from starting with the phone. Long-press power to bring up the power off menu, then long press "power off" to bring up the choice to restart in safe mode. If you see the same problem in safe mode, then I'd suspect that it's a hardware problem.
