dungoyle
That's a real shame, especially since that is not the typical user experience with the Turbo. Since you JUST got it, may I suggest a factory reset (since you just got a system update), and trying running with as little extra applications as you can get by with a day or two and see if these symptoms persist? Also, while this may not be related in your case, I know that people migrating from Apple or with Apple using friends often have texting issues upon migrating to Android. There is a thread or two discussing that in the forum as well.Got the 64gb ballistic nylon version of the droid turbo on Verizon and I'm pretty disappointed. I've had all sorts of issues come up that I've never had with an android phone before.
1) a lot of my texts either come in REALLY late or dont come at all until I force a refresh of the messaging list. This has been the biggest issue so far.
2) Sometimes the screen will stop responding to touches. I'm sure there is some background process that is running that's blocking it because the touches will be recognized shortly thereafter.
3) Ever since activating Advanced Calling, my phone calls drop a LOT. I end up turning off advanced calling for business calls just so that I can be more confident in the call not dropping. Of course, by doing that, I can't use data while using voice...a blast to 10 years ago.
Just not happy with this phone at all and I wouldn't recommend anybody getting it.
