cdd543
Good day. Having major issue with Droid Turbo 64GB with location prompt. I keep getting a prompted
"In a previous version of Android, you turned off the ability for Google apps to access your location.
When I press yes or not now it keeps prompting. Even does this for Maps.
This occurs if either Location is set to ON or OFF.
System version 21.44.8
Android version 4.4.4
Thank you,
Pretty sure you still need to go into settings/location to edit gps usage. Change it to high accuracy and it should be good to go.
