1. -Myk-'s Avatar
    This moron has a problem and a couple of questions.
    Problem: I hid my Verizon contacts on my contact list. I need to get one of them back and can't find a way to do it. How would you say unhide the built in Verizon Voice mail contact.
    Question:
    Is there a way to add common system setting into the notification pull down menu? like being able to switch the Turbo from ring to silence?
    Thanks for helping
    10-31-2014 09:38 AM
  2. Golfdriver97's Avatar
    I am taking a guess here, but when you pull down on the notification shade, there should be a square at the upper right. Click that, and it should bring you to your quick toggles. Sound should be toward the bottom.
    10-31-2014 09:41 AM
  3. -Myk-'s Avatar
    I did that, no sound option. I am looking for a way to add sound to it if possible.
    10-31-2014 09:49 AM
  4. Golfdriver97's Avatar
    Offhand, I am not sure. I don't think changes like that can be made on a stock device. The volume keys should silence the device.
    10-31-2014 09:54 AM
  5. Busted51's Avatar
    fastest way that I know to go from ring to silent is long pressing the power button until the menu shows up
    10-31-2014 10:00 AM
  6. Firedogee's Avatar
    This ^^^^^
    Sent Turbo fast from my 64GB Droid Turbo
    10-31-2014 10:08 AM
  7. -Myk-'s Avatar
    I found an app for it, it is called Notification Toggle. It lets you add all kinds of stuff to the notification pull down menu.
    https://play.google.com/store/apps/d...ficationToggle
    so now i just need to get that hidden contact back.
    10-31-2014 10:09 AM
  1. Root an HTC one Remix (Verizon HTC one mini 2) ?
    By Nia Christian in forum HTC One Mini 2
    Last Post: 04-01-2015, 10:57 PM
  2. Verizon Motorola Droid Turbo Any suggestions on a Qi charger?
    By ckelly33 in forum Motorola Droid Turbo
    Last Post: 02-01-2015, 08:44 AM
  3. Replies: 23
    Last Post: 12-30-2014, 08:28 PM
  4. Verizon Motorola Droid Turbo Google Now / Droid Command Center Widget
    By SteelGator in forum Motorola Droid Turbo
    Last Post: 11-02-2014, 10:09 AM
  5. Droid turbo...what app is needed in this situation?
    By Cajun_Mike in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 05:54 PM
