1. Davidoo's Avatar
    Ok, I just went into a corporate store to pick up a Turbo and left without it. Very concerned about low signal. They had all 3 models on display. Signal strength is critical to me because at my home it is not too good, at most 2 bars of 4G. I currently have an S3.
    I put my S3 on the counter next to the 3 Turbos. The store has a great signal and 4G was minis 61db on my S3. All 3 models of the Turbo only had 2 or 3 bars and between -96 and-100db. That's not just a little difference, that is horrible. I checked the other devices they had in the same display table, including a Moto Maxx and every one was 5 bars 4G and in the -60 range strength. I checked almost every other device in the store and they to were all in the -60s.
    Am I missing something or did Moto screw up the radio in the Turbo. This is especially concerning if I have to use VOLTE for simultaneous voice and data.
    10-31-2014 12:06 PM
  2. Firedogee's Avatar
    A system update was sent out yesterday after many of us bought our phones so that might have fixed some of these issues. After the update my Turbos signal is as good or better than my Droid RAZR M at home and work.
    Sent Turbo fast from my 64GB Droid Turbo
    10-31-2014 01:06 PM
  3. Sactown4's Avatar
    I'm loving the phone, but my signal sucks. 2-3 bars indoors in Manhattan. GS3, GS4, and IPhone all much better. I have the update.
    How do I find out dB?
    10-31-2014 01:13 PM
  4. Firedogee's Avatar
    Settings, More, Mobile Network, Signal Type and Strength
    10-31-2014 01:22 PM
  5. Sactown4's Avatar
    Thanks.
    I'm at -76 for 1x and -107 for 4G at home.
    10-31-2014 01:44 PM
  6. Firedogee's Avatar
    Thanks.
    That's about what I'm getting, which is good for where my house is
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    10-31-2014 02:46 PM
  7. Davidoo's Avatar
    After going out for dinner tonight I went to a different VZW corporate store and did the same test with the 3 Turbo models. Now it is completely different. I suppose these stores have some type of local cell transmitter because all the signals were in the -50db range, including my old S3, which is way higher than you would ever get out on the streets. This time the Turbo signal was as good or better than my S3. I can't figure out why they would be so different in one store compared to another?
    10-31-2014 08:40 PM
  8. JJ Jones's Avatar
    Store 2 may be closer to a tower than store 1 was.
    10-31-2014 09:43 PM
  9. Firedogee's Avatar
    Most corporate stores have a repeater in the store to make everybody happy. Perhaps store 1 had a Walmart repeater?
    11-01-2014 12:01 AM
  10. Davidoo's Avatar
    Just concerned about why only the Turbos seemed to have trouble in store 1.
    11-01-2014 12:05 AM
  11. Firedogee's Avatar
    "These aren't the droids you are looking for."
    11-01-2014 12:31 AM
  1. Why is there no Spo2 in my S heath on my Note 4 ?
    Last Post: 08-08-2015, 08:25 AM
  2. Root an HTC one Remix (Verizon HTC one mini 2) ?
    By Nia Christian in forum HTC One Mini 2
    Last Post: 04-01-2015, 09:57 PM
  3. Verizon Motorola Droid Turbo Any suggestions on a Qi charger?
    By ckelly33 in forum Motorola Droid Turbo
    Last Post: 02-01-2015, 07:44 AM
  4. Verizon Motorola Droid Turbo Google Now / Droid Command Center Widget
    By SteelGator in forum Motorola Droid Turbo
    Last Post: 11-02-2014, 09:09 AM
  5. Droid turbo...what app is needed in this situation?
    By Cajun_Mike in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 04:54 PM
