11-30-2014 04:13 PM
39 12
tools
  1. parkschr1's Avatar
    Gosh dang it. I am dumb. I still do not see audio effects under the sound settings. Thanks for trying to help. Maybe I have a different software version or build number.
    11-04-2014 09:03 PM
  2. parkschr1's Avatar
    Audio effects is on my old razr maxx in the exact spot everyone is telling me. But not my droid turbo. I did do the update. Maybe that is why it is not there.
    11-04-2014 09:31 PM
  3. parkschr1's Avatar
    Here is a link to the screen shot to show everyone:
    https://drive.google.com/open?id=0Bz...amM&authuser=0
    11-04-2014 09:34 PM
  4. kjjb0204's Avatar
    That's really strange that its not there for you. Don't worry too much, I turned that off and didn't make a bit of difference in my volume.
    11-05-2014 10:35 AM
  5. neviander's Avatar
    I was having the same issue. I don't remember seeing one particular trick, I found elsewhere, on this thread so I thought I'd share. If you put the middle of your ear to the top right corner of the phone, it's way louder. It's still an issue, but I've had a phone that you had to shove into your ear to be able to hear the other person talking, or if there's any relatively loud background noise, forget about it, and I don't want to relive that. I'm actually not even on the phone part of the phone that much. I'm thinking the next update will make the earpiece volume...more functional.
    The external speakers are very loud, WAY louder than my Galaxy Nexus ever hoped to be. Everything else about the phone is top notch, and OH the battery life, so good.
    11-09-2014 10:27 PM
  6. UnkleBidii1's Avatar
    I'm having or been having this same problem with my Droid Maxx. In-call volume has always been low for me even though I have very good hearing. I've gone thru multiple Maxxs before finding a decent one that sounded a little better than previous ones. I'm wondering if it has to do with their so called ability to last 48hrs. For that reason they want to generate as less power toward the earpiece volume, which sucks cause this is a good phone and I want to hang on to it for as long as possible. I'm hoping the Lollipop update does something positive with their earpieces. But I haven't found much online with the Droid Maxx, just Razr Maxx with the same issues. I always have to have the volume at 100% to hear decently.
    11-29-2014 10:32 PM
  7. MikeLip's Avatar
    I don't have any problems with earpiece volume. In fact I can usually turn it down some. And I wear hearing aids. But the aids make me sensitive to phone position and I find that if I hold the phone so that the leftmost part of the speaker (looking at the phone from the display side, earpiece up) is closest to the microphone of my aids I get best results. You might want to shift the phone around on your ear.
    11-29-2014 10:42 PM
  8. leehardballer12's Avatar
    They must have fixed this issue because I've had no issue. Actually, I have to turn it down in 'normal' conditions. I was concerned about this before I got the Turbo coming from a BB Z30 which I felt had too low call volume. I have been very pleased with the call quality on this device.
    11-30-2014 02:29 AM
  9. JimBen73's Avatar
    Yes, call quality is good on mine aswell
    sent turbo fast
    11-30-2014 03:30 AM
  10. LaskoFan's Avatar
    It has now been two weeks with my Turbo. I have a 64 BN and was very concerned about this situation prior to purchase. I'm happy to report that this has not been an issue and I'm loving the phone. Just my two cents.
    11-30-2014 06:56 AM
  11. areyes163's Avatar
    I just traded my turbo in for a Sony Z3v but the call volume on mine was fine. At first the volume was low until I realized the volume for calls only emits from the right side of the speaker. When held normal the volume was low. When insisted the phone so the right corner of the speaker was against my ear it was loud. To loud actually. Good luck and best wishes. The Turbo was a excellent device.
    11-30-2014 07:13 AM
  12. Janehughes's Avatar
    Alright-
    This might seem too easy, but a friend of mine had the same problem with his new Motorola Droid Turbo and was told to remove the protective screen cover. Now the phone sound is working perfectly. Good Luck.
    MikeLip likes this.
    11-30-2014 12:31 PM
  13. BlueBlazer60's Avatar
    Alright-
    Good humor lives forever.
    11-30-2014 01:57 PM
  14. Bamzilla's Avatar
    At first I thought in call volume was low but after shifting my position and getting used to it it's plenty loud that I've turned the volume down. I was at the Cavs-Spurs game recently and took a call with the crowd chanting and the mics are so good my friend didn't realize I was in the arena until I told him. No issues now.
    Sent from my XT1254 using Tapatalk
    11-30-2014 04:13 PM
39 12
  1. Why is there no Spo2 in my S heath on my Note 4 ?
    Last Post: 08-08-2015, 09:25 AM
  2. Verizon Motorola Droid Turbo Any suggestions on a Qi charger?
    By ckelly33 in forum Motorola Droid Turbo
    Last Post: 02-01-2015, 08:44 AM
  3. Verizon Motorola Droid Turbo Google Now / Droid Command Center Widget
    By SteelGator in forum Motorola Droid Turbo
    Last Post: 11-02-2014, 10:09 AM
  4. Using wifi to make calls-minimum broadband speed?
    By andyapples in forum Ask a Question
    Last Post: 10-31-2014, 08:43 PM
  5. Droid turbo...what app is needed in this situation?
    By Cajun_Mike in forum Motorola Droid Turbo
    Last Post: 10-31-2014, 05:54 PM
