11-15-2014 10:22 PM
29 12
tools
  1. tech_fan's Avatar
    I have a Note 3 that i am streaming music from Google play to my car stereo. I have to crank the volume up on both units to get sound. When i do the sound distorts. Is the Droid any better in this area? Was thinking it might be my Entune radio but the same problem happens with my Sony bluetooth headphones.
    10-31-2014 08:02 PM
  2. jfoofoo's Avatar
    I didn't have issue with note 3 and I am not having issue with Droid turbo..... maybe your issue is your sound system?
    tech_fan likes this.
    10-31-2014 08:10 PM
  3. tech_fan's Avatar
    I thought that might be the case too but I tried my Sony headphones which r bluetooth and my car stereo and the same problem occurs.
    10-31-2014 08:11 PM
  4. Firedogee's Avatar
    Yes, it's fabulous. I have Moto Buds as well as a pioneer receiver in the car and it sounds great in both. I'm sure this phone supports APT-X technology, which those devices do as well. It helps it sound that much better.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    10-31-2014 08:32 PM
  5. tech_fan's Avatar
    You seem much happier with this device then you did the Moto X. Finally got my Moto X return issue fixed so now I can upgrade again.
    PeninaD likes this.
    10-31-2014 08:38 PM
  6. jfoofoo's Avatar
    is there an app on your phone that may affect the sound? Is there something at your location that is interfering your bluetooth connection? Have you tried to use a regular 3.5 mm jack connection to see if the sound works?
    10-31-2014 10:02 PM
  7. tech_fan's Avatar
    Yeah. When I try and plug it into a jack and use it without wireless, the sound is much better. I have tried it at home and in the car and the same distortion occurs. The distortion in the car is so bad, that I gave up on streaming music in the car. It will even happen if I stream podcasts from another app.
    10-31-2014 10:13 PM
  8. jfoofoo's Avatar
    is there another phone with bluetooth you can try to pair up with your car to see if that works? we need to figure out if the issue is with the phone, the receiver, or if there is interference on the bluetooth connection at your loction.
    10-31-2014 10:29 PM
  9. f1nzup's Avatar
    I have no problems streaming my Note 3 with my 2012 Acura TL. For music on my phone I use the native Samsung Music app just because it works best with my TL's Bluetooth, and I have no problems with volume.
    Sent from my Note 3 Using Tapatalk
    10-31-2014 10:44 PM
  10. tech_fan's Avatar
    I could try. I did notice with my Alpine unit, when I switched from the IPhone 5 to the Note 3, the sound quality dropped and I had to crank up the volume almost all the way up to get sound. I wound up not using it because it was a pain the neck. Now I just remembered the reason why I had stopped with the Alpine unit.
    10-31-2014 11:15 PM
  11. VooDooCC's Avatar
    When you say you have to turn the volume up on both units, are you meaning the phone Bluetooth volume? Trying to cover all possibilities.
    Talking through tapping
    10-31-2014 11:19 PM
  12. Firedogee's Avatar
    Yeah, the X itself wasn't that bad. Just the whole delayed shipping and no communication from Moto the whole time. Then they went and dropped the price 1 day after I finally got my X and wouldn't give me a refund for the difference. It just wasn't meant to be, and now that I have the Turbo I understand why
    So glad you got yours returned. Which Turbo are you going for? I hope you like it as much as I do! Let me know after you get it.
    10-31-2014 11:45 PM
  13. motofanforever's Avatar
    The dropped price and all.....just in the US is it? Cuz, in my country there's no Turbo and the X is best device on offer(if u don't count the iPhone 6.....I don't)
    11-01-2014 02:23 AM
  14. Firedogee's Avatar
    Yup, Verizon Moto X only
    11-01-2014 09:34 AM
  15. tech_fan's Avatar
    I thought I might the Droid Turbo with the smooth back but, I am starting to like the ballistic nylon. So, I will probably go with that one in the 64GB version. When I spoke with Verizon, they were unwinding the contract for the Moto X and told me that it would be taken care of in 24 hours. When I checked my account, I see they have not removed it as of yet. So, looks like I might need to wait until tomorrow.
    11-01-2014 03:48 PM
  16. Firedogee's Avatar
    Yeah, it took a little over 24hrs for mine to show up on the website after the reversal was requested.
    FWIW I love the ballistic nylon even more after 2 days!
    11-01-2014 03:53 PM
  17. NoahForeman's Avatar
    Streaming is great to my S11 Flex HD headphones, but those do use apt-x.
    Posted from my Droid Turbo via the AC App
    PeninaD likes this.
    11-01-2014 04:12 PM
  18. Firedogee's Avatar
    I'm glad to hear APTX is working nicely for another Turbo owner.
    11-01-2014 04:34 PM
  19. tech_fan's Avatar
    I have narrowed it down to what I believe to be the music recording. Some of the extreme high vocals are crackling. I did wind up downloading an app called Equalizer which automatically reads the information from the song and makes adjustments to the equalizer which helped increase the volume. Now, if I have both up, its real loud.
    11-02-2014 04:25 PM
  20. tech_fan's Avatar
    Sadly enough and I am still struggling with this decision, I might got the route of the Galaxy Note and the main reason is the lack of accessories. Or, I might go the route of the Droid Turbo still. I get bored with the looks and usually go through cases, once every 3-4 months. The Droid Turbo just does not seem to have much.
    I really do not want another Note series either. I do not like TW and I am using an Nova Launcher on it right now. Big Red also has not reversed the Moto X from my account either. Although,. I paid a visit to the local corporate store and got some real traction with the matter so, I think it might get fixed on Monday. There are so many notes to my account that it fills the 2 pages of their screens. It took my 4 times to try and order my wife's iphine which one of them was done manually. This last time by visiting the Corporate store was more successful.
    11-02-2014 04:30 PM
  21. Firedogee's Avatar
    Yikes, sorry to hear about all that. Keep us posted.
    11-02-2014 07:16 PM
  22. intheor911's Avatar
    The volume is much lower maxed out when using bluetooth headphones compared to my Note 3. Kinda sucks at the gym because I can hear a lot of background noise. Same thing in the car. I have to turn the volume up much higher to get the same level as my Note 3.
    11-02-2014 07:42 PM
  23. tech_fan's Avatar
    Yeah. Went to Verizon and saw the Droid Turbo. Feels great. Love the zippy feel of it. Was worried about running it naked though. See some threads about nylon coming loose. I am going to be on the Edge program so half of me is concerned about how well it holds up. The other half of me doesn't really care. The residual on the phone is like 125 or 150. Not a deal killer if I have to keep the phone.
    Oddly enough I go in and out with cases. One month I'll have a case on my Note the other month I will not. It's a Ying vs yang thing.
    11-02-2014 07:46 PM
  24. beeztrain's Avatar
    Loud!
    11-07-2014 05:00 PM
  25. wolf_walker's Avatar
    Can't speak as to quality but the range streaming bluetooth is a good bit less than my
    Galaxy S4 so far. It breaks up in the kitchen, GS4 does not.
    11-07-2014 05:24 PM
29 12
  1. Shouldn't the Z3v get it's own section?
    By npaladin-2000 in forum Sony Xperia Z3
    Last Post: 11-03-2014, 11:33 PM
  2. Verizon Questions
    By Kaiser Droid in forum LG G3
    Last Post: 11-03-2014, 05:50 PM
  3. Is there a pda.net that works with the Droid Maxx?
    Last Post: 11-01-2014, 10:17 PM
  4. How do I retreive old text messages that my phone deletes?
    Last Post: 11-01-2014, 08:04 PM
  5. Replies: 1
    Last Post: 11-01-2014, 06:48 PM
