1. Clocks's Avatar
    So does anyone know which mics are used to pick up video audio? I was hearing some random scratching sounds in a video I recorded and I wonder if any of the mics on the back (where my fingers were) are used for video?
    10-31-2014 10:34 PM
  2. Clocks's Avatar
    I figured this one out.
    This right bottom mic is the only one used to record audio during a video. If you are used to sitting your finger there you will hear that scratchy sound when your finger moves and you'll muffle the audio.
    Verizon Motorola Droid Turbo [SOLVED] Scratching sound during video recording-20141101_143057.jpg
    Verizon Motorola Droid Turbo [SOLVED] Scratching sound during video recording-20141101_143127.jpg
    11-01-2014 02:36 PM
  3. Firedogee's Avatar
    You are on a roll Clocks! I think you should work for AC.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-01-2014 02:58 PM
  4. Clocks's Avatar
    This is also important since a lot of cheap cases don't have the holes needed for the 3 extra mics (the 3rd one is to the bottom right of the camera lens). For example I ordered a $2 tpu case from ebay for my 2014 x and it doesn't have *any* of the rear mics uncovered! Not only would this impact video recording it would also impact the noise cancellation and voice recognition.
    PeninaD likes this.
    11-01-2014 03:04 PM
  1. Verizon Questions
    By Kaiser Droid in forum LG G3
    Last Post: 11-03-2014, 06:50 PM
  2. Replies: 8
    Last Post: 11-02-2014, 08:35 AM
  3. Replies: 3
    Last Post: 11-02-2014, 01:51 AM
  4. Is there a pda.net that works with the Droid Maxx?
    Last Post: 11-01-2014, 11:17 PM
  5. Verizon Motorola Droid Turbo Question regarding Messaging app
    By jaymzb0nd in forum Motorola Droid Turbo
    Last Post: 11-01-2014, 06:15 PM
