1. jfoofoo's Avatar
    Love the idea of super fast charging but can't help but notice how hot the phone gets. It was at 42 celsius/108 fahrenheit... Is this still within safe level for battery? I never seen any phone gets this hot. My Note 3 and moto x (2nd gen) has never really reached the 40/104 mark...
    How hot does your phone get when on turbo charger?
    10-31-2014 10:26 PM
  2. Busted51's Avatar
    i didn't measure exactly the temp but it does get warm. not hot though. and the software comes with safety off if the phone gets too hot. I would think that the level in which this activates is well within safe temp.
    10-31-2014 10:44 PM
  3. camachinist's Avatar
    Mine arrived today with a 0% charge so I let it charge up to 100% before using it. IMO, it was pretty warm, about the same as my MacBook pro when the battery is charging, for the first 15 minutes or so, then it cooled off. It took just over 2 hours to go to 100%. If anything, it might have run a bit hotter than normal due to being in an Otterbox. I ran it a bunch today and concluded tonight with about 73% left so will give the charger another go tomorrow and check it again. I have a HVAC temperature probe for my electrician's handset so can accurately measure the temp inside the case. Will update.
    jfoofoo likes this.
    10-31-2014 11:41 PM
  4. Firedogee's Avatar
    I've seen it get as high at 110°
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    10-31-2014 11:50 PM
  5. Firedogee's Avatar
    Try the GSAM battery app. It gives the internal temp readout and graph over time.
    10-31-2014 11:51 PM
  6. mwbryant1977's Avatar
    I have also seen mine reach around 110 while charging on Turbo Charger . But it also gets close to 110 like about 108 occasionally when running intense apps like high graphics games like some of the newer 3rd person shooters.
    12-02-2014 09:52 AM
  7. mwbryant1977's Avatar
    has anyone tested how much difference having it in like an outer box case makes as far as how high temperature level goes, while charging or under heavy use?
    12-02-2014 09:54 AM
  8. mse65's Avatar
    I have a life proof on my turbo and was woken up the other night when my phone reached 137.5°. I was using an inductive charging stand at the time so I pulled the device out of the life proof case and charged it caseless. I can not say how hit it got but there were no more alarms and when I woke up and retrieved the phone, it was not hot to the touch.
    04-08-2015 10:59 AM
  9. CharlieL3's Avatar
    I thought the Turbo didn't have an internal temperature sensor. The All-In-One Toolbox app I load that tells me the state of the sensors shows that it isn't there.
    04-08-2015 02:10 PM
  10. 1Coopgt's Avatar
    Couldn't tell ya. I'm asleep when mine is charging .
    04-08-2015 06:44 PM
  11. KSDroid01's Avatar
    Apparently it does; the GSAM app reports temperature that seems to track my finely-calibrated organic sensor/manipulator device. I think the hottest I ever noticed was around 115°, when I was turbocharging concurrently with running Google Nav. I've held it in front of my ac vent a couple of times and would like to get a sturdy vent mount to alleviate this situation.
    Posted via the Turbo
    Attached Thumbnails How hot does your phone get while using the Turbo Charger?-76639.jpg
    04-08-2015 07:21 PM
  12. CharlieL3's Avatar
    That's good to know. I'll open up Elixir and see if it shows a temperature sensor. Thanks!
    (On edit): Elixir shows that the ambient temperature sensor isn't available, either. I wonder where the numbers are coming from in GSAM.
    04-09-2015 05:03 PM
  13. Phoenix212's Avatar
    It sounds like a few people on this forum have had overheating issues when using Qi chargers and cases. I wonder if this is yet a "known issue" at Motorola?
    04-10-2015 12:18 PM
  14. psf57's Avatar
    I use Qi charging all the time. The hottest it got was 94. Low temp of 60.3. Using the Verizon Cradle stand.
    04-10-2015 01:30 PM
  15. Bo Lee1's Avatar
    The only time I have ever noticed it getting hot while charging was if I had it plugged into an after market charger. The one that came with it it doesn't not does the Qi charger. But with an after market it will reach 140 degrees.
    06-12-2015 03:12 PM
  16. Awest081013's Avatar
    Mine has gotten to 104 with the otter box case on tonight it's never gotten that hot before, so I'm wondering what's going on
    11-25-2015 09:41 PM
  17. SouthernblondeLKS's Avatar
    I tend to turn my phone off when I'm charging it. It chargers quicker and it doesn't get as hot. At least, that's the way it works for my phone. Mine is in an otterbox, so I'm sure that generates more heat than if it wasn't in a case.
    11-26-2015 10:56 PM
  18. yenh127's Avatar
    My Turbo gets burning hot- often nearing 120°F+ when measured through Ampere
    12-31-2015 12:32 AM
  19. 1Coopgt's Avatar
    Mine reached 102 while charging last night . Nothing to worry about .
    01-01-2016 09:27 AM
  20. Jimmy Sullivan's Avatar
    my Turbo 2 is running at 102 degrees right now.. it's usually around 108 to 110 when turbocharging.. I've had this Turbo 2 for about a year and it always seems to run a little hot compared to other phones I've had
    06-25-2017 08:56 PM
  21. adamgilcrist's Avatar
    No Doubt that turbo charger can charge your phone within a few minutes. In between our mobile phone gets very hot. I have a Moto G 4th gen and it starts getting hot when connected with turbocharger. Sometimes, I really worried about it.
    11-30-2017 04:33 AM
  1. Does the Z2 Overheat?
    By androidforum in forum Sony Xperia Z2
    Last Post: 04-13-2015, 09:38 PM
  2. Replies: 4
    Last Post: 04-10-2015, 05:21 PM
  3. How do you close apps on Verykool smart phones?
    Last Post: 04-10-2015, 03:36 PM
  4. My phone was peed on is this repairable?
    Last Post: 04-10-2015, 03:14 PM
