1. Will Simoneaux's Avatar
    For some reason I can't switch to the front camera on my turbo. I was able to restart my phone and then it reappeared and I was able to use it. Now It's happening again and I tried to restart the phone again but it didn't fix it this time.. Any ideas what the problem is?
    11-01-2014 10:00 AM
  2. ckelly33's Avatar
    mine works.
    11-01-2014 10:02 AM
  3. Firedogee's Avatar
    The phone has a minimum handsomeness threshold for selfies.
    Jk, don't know. I'll test mine out.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-01-2014 10:02 AM
  4. Will Simoneaux's Avatar
    Going to have to get a replacement. Haven't even had the phone a week. ๐Ÿ˜’
    11-01-2014 01:16 PM
  5. Firedogee's Avatar
    I noticed it sometimes won't switch to front camera if you opened camera app with the Twist hand action. That might be the problem.
    EDIT: Ignore what I wrote above. It works for me either way. Maybe update the Moto Camera app from Google Play store and give it another try before returning?
    11-01-2014 02:03 PM
  6. ashbranon's Avatar
    I have had the same problem with the front facing camera... Once I uninstalled it and re-downloaded the app and it worked this time it's not. Any ideas on the fix?
    11-15-2015 10:27 PM
  7. Alex_goodman18's Avatar
    How did you uninstall the front facing camera app? It's a default app, so I'm not sure how to do it
    04-27-2016 04:18 PM
  8. doogald's Avatar
    I believe in settings / apps, find camera, you can tap and then tap the button "uninstall updates". Then back in the play store the camera app will show an update.
    It's worth a try...
    04-27-2016 06:42 PM
  1. Why isn't my camera working on my phone?
    Last Post: 11-23-2017, 11:08 AM
  2. Verizon Questions
    By Kaiser Droid in forum LG G3
    Last Post: 11-03-2014, 05:50 PM
  3. Replies: 8
    Last Post: 11-02-2014, 07:35 AM
  4. Is there a pda.net that works with the Droid Maxx?
    Last Post: 11-01-2014, 10:17 PM
  5. Samsung Galaxy Note 4 Camera modes
    By PhilNUK in forum Samsung Galaxy Note 4
    Last Post: 11-01-2014, 06:37 PM
