11-03-2015 08:05 PM
679 ... 1011121314 ...
tools
  1. cactusleon's Avatar
    I'm waiting for the Diztronic case to come out later this month for the Ballistic Nylon model. I prefer thin cases and the Tech21 while nice is more protection than I need.
    i would have liked the Tech21 but i cant find the thing anywhere
    12-10-2014 08:25 AM
  2. Eclipse2K's Avatar
    They're difficult to find no doubt. I randomly found one in store for my sister and snagged it immediately. I don't care for it on the Ballistic Nylon too much because the right corner randomly pops off while in my pocket. Works great on the MG model.
    12-10-2014 08:27 AM
  3. Rhyno81's Avatar
    I'm hoping someone makes a sturdy rubber case that just surrounds the edge of the phone leaving the front and back exposed. It would still be the first thing to hit the ground in a fall and would be just big enough to touch a flat surface when laid down to add traction. Phones should just start coming with a rubber rim then I wouldn't need anything at all. I like to go as minimal as possible on my cases.
    Bamzilla likes this.
    12-10-2014 11:41 AM
  4. PowrDroid's Avatar
    I really like the Incipio Dual Pro, but people have reported there are raised dimples on the inside back cover area that might damage the ballistic nylon. The Dual Pro typically sells for around $25. (They have a beautiful red one that color matches the red metallized kevlar.) Anyway, I found this Chinese knockoff on ebay for less than $5. Shipping would be about 2 weeks though.
    I emailed the seller regarding the raised dimple problem but never got a reply.
    2in1 Hybrid Silicone Impact Case Cover for Verizon Motorola Droid Turbo XT1254 | eBay
    Black Hybrid Silicone Impact Case Cover for Verizon Motorola Droid Turbo XT1254 | eBay
    12-10-2014 11:52 AM
  5. ibcop's Avatar
    You and me both.
    12-10-2014 01:33 PM
  6. elir41's Avatar
    Cruzerlite cases are now available on Amazon. Thinking of picking up the black.
    12-10-2014 02:06 PM
  7. Rhyno81's Avatar
    I like the case but hate that design on the back. Just flat would be fine.
    12-10-2014 02:09 PM
  8. Rhyno81's Avatar
    I just bought the Incipio DualPro Carrying Case. I had an Incipio on my Droid Razr and it never did me wrong. It took a 5 foot drop to concrete without a scratch.
    12-10-2014 02:21 PM
  9. PowrDroid's Avatar
    You've got the ballistic nylon, correct? Please post back about the dimpled inner surface of the back of the inside of the case and whether or not that messes with or otherwise affects the Turbo's nylon backing.
    12-10-2014 02:38 PM
  10. Bamzilla's Avatar
    I'm still waiting on just a simple bumper case with the back still open. I was unlucky enough to drop mine caseless in a parking lot. I was stupid and had my hands full so I had my phone sitting on a glossy external hard drive balancing in my hands as I tried opening my car door. Luckily it landed on an edge and was fine. A couple really small nicks on the side of it but you can't really see them unless you look for it.
    Sent from my XT1254 using Tapatalk
    12-10-2014 07:28 PM
  11. hannsoft's Avatar
    I can chime in on that one. I have that case. Those dimples do nothing to this phone. Not even sure I understand what the claim is that people are making. The rubber dimples make a mark on the nylon weave? How the heck...? The weave on my phone is quite tough... Unless the rubber is chemically sticky (which is not the case on mine) I can't imagine it leaving behind anything on the weave. At least, it doesn't on mine.
    What HAS happened to me is a cracked in the outer shell of the case, in one corner. I go bareback at home - prefer to hold the phone naked - so I take cases on and off a lot. The dual pro doesn't come off all that gracefully, so mine is now cracked.
    Aside from that though, great case IMO. Love the feel of the rubberized hard Shell.
    Sent from my Droid Turbo using Tapatalk
    dmark44 likes this.
    12-11-2014 07:17 AM
  12. MikeLip's Avatar
    Any idea if they would fit the ballistic nylon? The listing doesn't say.
    rxgadget likes this.
    12-11-2014 07:21 AM
  13. Rhyno81's Avatar
    Can you post a photo of the dimples everyone is referring to? I ordered the case but it's still a few days out and I'm just really wanting to know what to expect. Are these just a few small dimples that could be shaved off with a razor blade?
    12-11-2014 09:29 AM
  14. MikeLip's Avatar
    Go to the Amazon listing;
    http://www.amazon.com/Incipio-DualPro-Carrying-Case-Packaging/dp/B00OZT66RI/ref=sr_1_1?ie=UTF8&qid=1418308252&sr=8-1&keywords=incipio+droid+turbo
    Scroll down to the first review. There are a few too many to shave off. Besides, the fit would probably be sloppy without the bumps.
    12-11-2014 09:33 AM
  15. Ch4dders's Avatar
    You and me both.
    I'm in the same boat... Diztronic makes a great case at a decent price that provides adequate protection without adding much bulk.
    Honestly I am a bit irked by the lack of options when it comes to case selection for BN Turbo phones. Am I alone in this?
    12-11-2014 10:57 AM
  16. MikeLip's Avatar
    This is pretty common with VZW exclusives and, I assume, anyone elses. And the BN being a subset of an exclusive, that makes it worse. It is irritating for sure. But making the dies to mold cases is expensive so I suspect they will wait until there is enough demand to justify engineering and tooling.
    12-11-2014 11:09 AM
  17. hannsoft's Avatar
    Ok, a follow-up here. I DID see the marks that people are talking about when I looked closely this morning. However, they don't appear to be permanent, nor "damaging" .. I was able rub them away with my finger and there's no trace afterward.
    12-11-2014 12:51 PM
  18. hannsoft's Avatar
    Sure can:
    Attached Thumbnails DROID TURBO: Cases-uploadfromtaptalk1418320380870.jpg
    PowrDroid likes this.
    12-11-2014 12:53 PM
  19. HappyFunBall24's Avatar
    I emailed Cruzerlite yesterday and they confirmed that their cases work with the BN version.
    The lack of case choices for the Droid Turbo, especially for the BN version, is really disappointing. Just another example of The Man keepin' us down...
    So, what's the current status of cases that work with BN? I'm sure I'm missing some, but here's what I've seen so far:
    Fit: Otterbox, Incipio, Tech21, Speck, Lifeproof, Case Mate, Cruzerlite, some Amazon/Ebay listings (such as stated above)?
    Don't fit but going to release a BN edition: Diztronic, Tudia
    Btw, Seidio and Trident reps have said that they're going to have cases. No timetable for Seidio; Trident said the Aegis will be out in Jan. No word on whether they will fit BN or make separate cases for it.
    12-11-2014 01:03 PM
  20. KPMcClave's Avatar
    The $19.99 glossy silicone Verizon cases fit, as well. I have the black one (assume the purple fits the same).
    12-11-2014 01:14 PM
  21. MikeLip's Avatar
    Thank you for that. I emailed them but they haven't responded yet.
    12-11-2014 01:14 PM
  22. PowrDroid's Avatar
    This one looks somewhat similar to the Incipio Dual Pro, it's a two part silicone/hard case. They even show it with a ballistic nylon Turbo inside the case. Price is $9.99 and will be available on Sunday.
    http://www.amazon.com/Armor-Motorola...cUvbUpU4118760
    This looks like the exact same one as above available on ebay for $3.39 but ships from Hong Kong with earliest delivery date of 12/23:
    dungoyle and HappyFunBall24 like this.
    12-11-2014 01:17 PM
  23. Eclipse2K's Avatar
    The Tudia for Ballistic Nylon is available for preorder.
    http://www.amazon.com/gp/aw/d/B00QSO...cUvbUpU4119788
    Sent from my Motorola Droid Turbo
    HappyFunBall24 and KPMcClave like this.
    12-11-2014 10:00 PM
  24. HappyFunBall24's Avatar
    ^^ Looks sleek as heck... available 12/17, nice! I'm waiting on the Trident Aegis release in Jan because I prefer having port covers, but... decisions, decisions...
    12-11-2014 10:58 PM
  25. swelljibes's Avatar
    I'm another Ballistic Nylon owner who purchased the Droid Turbo not only for its capabilities, but also for the size and hand feel. Although its clear that utilizing one of the more protective "wrap around" cases would offer greater security against drop-damage, I'm unable to overcome my aversion to significantly altering the BN hand feel... which would result in a situation where I've purchased the case for the feel and placed a phone inside it.
    So.... I'm looking for the least intrusive solution. In the past Case-Mate has produced a Hula Bumper case for Motorola phones... where the "case" is nothing more than a wrapper around the outer edge of the phone... protecting the corners in case of a drop, but not protecting the front or back. I thought this would be ideal, but unfortunately Case-Mate isn't producing one for the Droid Turbo and, per a phone conversation I had with a Case-Mate phone rep today, has no plans to produce one.
    It might be worthwhile to lobby Case-Mate for such a solution... and obviously, the greater the number of requests, the higher the likelihood they'll change their plans. Still, I don't know enough about the differences in dimensions of the Kevlar and BN versions of the phone to know whether they would find they'd have to develop two solutions. If so, they would have to consider whether there would be enough return-on-investment there... and given they appear to have already chosen NOT to develop a product for either I'd say, sadly, the likelihood of them developing two solutions is slim to none.
    NOTE: On another forum someone commented on the possibility of using just the bumper part of the Case-Mate Naked Tough case... but I asked the Case-Mate rep about this and she stated that it wouldn't work. Basically, the two parts (the bumper and the "back plate") work together... and if one tried using just the bumper the phone would just fall out.
    I also investigated the Seidio Spring Clip Holster. It's a vertical belt-hung holster that accepts a naked phone. No protection really, but a way to carry a naked phone without stuffing a pocket and risking damage when the phone inevitably falls out. I believe someone mentioned this earlier, but I checked and sure enough, their web site has a marketing spot for the product with some sort of "coming soon" message. Based on this I contacted them via their web site's IM-like capability... In my conversation with them I discovered that the coming holster is expected to support ONLY the Kevlar version, NOT the BN version. Of course, it's possible the BN will fit, but be a very tight fit that could impact the BN material on the back of the phone. Won't know until it's available.
    This leaves me with no current options... except to wait or consider buying one of the leather holsters available on eBay, Amazon or at Walmart. Hard to determine whether any of these will really fit the Droid Turbo though because most of the listings don't provide dimensions. On another forum someone suggested one particular leather holster on eBay... found using the following in the search window:
    BLACK VERTICAL LEATHER BELT CLIP POUCH HOLSTER CASE FOR MOTOROLA DROID
    TURBO
    If anyone has any experience with this or any other vertical leather holster with a good fit could you please provide specific info on where it can be found or what you did to make it fit?
    Thanks
    12-12-2014 04:59 PM
  1. Issues with MTP Mode - Turbo Driver
    By pftomo in forum Motorola Droid Turbo
    Last Post: 12-12-2014, 03:02 PM
  2. Still looking for a good protective case
    By charleskoz in forum Samsung Galaxy Note 4 Accessories
    Last Post: 11-25-2014, 10:09 PM
  3. Is there a case that has an adjustable stand?
    By AnimalMotherASF in forum HTC One M8
    Last Post: 11-04-2014, 06:44 AM
  4. Replies: 1
    Last Post: 11-03-2014, 11:30 AM
