I'm another Ballistic Nylon owner who purchased the Droid Turbo not only for its capabilities, but also for the size and hand feel. Although its clear that utilizing one of the more protective "wrap around" cases would offer greater security against drop-damage, I'm unable to overcome my aversion to significantly altering the BN hand feel... which would result in a situation where I've purchased the case for the feel and placed a phone inside it.
So.... I'm looking for the least intrusive solution. In the past Case-Mate has produced a Hula Bumper case for Motorola phones... where the "case" is nothing more than a wrapper around the outer edge of the phone... protecting the corners in case of a drop, but not protecting the front or back. I thought this would be ideal, but unfortunately Case-Mate isn't producing one for the Droid Turbo and, per a phone conversation I had with a Case-Mate phone rep today, has no plans to produce one.
It might be worthwhile to lobby Case-Mate for such a solution... and obviously, the greater the number of requests, the higher the likelihood they'll change their plans. Still, I don't know enough about the differences in dimensions of the Kevlar and BN versions of the phone to know whether they would find they'd have to develop two solutions. If so, they would have to consider whether there would be enough return-on-investment there... and given they appear to have already chosen NOT to develop a product for either I'd say, sadly, the likelihood of them developing two solutions is slim to none.
NOTE: On another forum someone commented on the possibility of using just the bumper part of the Case-Mate Naked Tough case... but I asked the Case-Mate rep about this and she stated that it wouldn't work. Basically, the two parts (the bumper and the "back plate") work together... and if one tried using just the bumper the phone would just fall out.
I also investigated the Seidio Spring Clip Holster. It's a vertical belt-hung holster that accepts a naked phone. No protection really, but a way to carry a naked phone without stuffing a pocket and risking damage when the phone inevitably falls out. I believe someone mentioned this earlier, but I checked and sure enough, their web site has a marketing spot for the product with some sort of "coming soon" message. Based on this I contacted them via their web site's IM-like capability... In my conversation with them I discovered that the coming holster is expected to support ONLY the Kevlar version, NOT the BN version. Of course, it's possible the BN will fit, but be a very tight fit that could impact the BN material on the back of the phone. Won't know until it's available.
This leaves me with no current options... except to wait or consider buying one of the leather holsters available on eBay, Amazon or at Walmart. Hard to determine whether any of these will really fit the Droid Turbo though because most of the listings don't provide dimensions. On another forum someone suggested one particular leather holster on eBay... found using the following in the search window:
BLACK VERTICAL LEATHER BELT CLIP POUCH HOLSTER CASE FOR MOTOROLA DROID
TURBO
If anyone has any experience with this or any other vertical leather holster with a good fit could you please provide specific info on where it can be found or what you did to make it fit?
Thanks
