1. Xelios's Avatar
    So I was informed by someone else who had this issue about it and turns out I have it too. When looking at a white screen, there's a bit of a pinkish tint almost like screen burn on the phone. Mine is above the capacitive keys, and runs up about a quarter inch above it. The guy that told me about it has it at the top of the screen. Does anybody else have this?
    11-01-2014 04:54 PM
  2. Firedogee's Avatar
    Just checked a totally white screen and no pink anywhere on screen.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-01-2014 05:35 PM
  3. Xelios's Avatar
    That's a shame. Finally had my phone all set up and all. Guess I'll be exchanging it for another.
    11-01-2014 05:47 PM
  4. Firedogee's Avatar
    Total bummer. Were you one of the guys with a gap between the cap buttons and the chin?
    11-01-2014 06:01 PM
  5. Xelios's Avatar
    Hadn't even heard about that. There's a small gap but it's not noticeably large. Can't get a fingernail in there.
    11-01-2014 06:06 PM
  6. tdizzel's Avatar
    Perfectly white screen here. And a gorgeous one at that.
    11-01-2014 06:28 PM
  7. mightyfacundo's Avatar
    Yep, same here.
    11-01-2014 06:32 PM
  8. Eclipse2K's Avatar
    A few people have mentioned that the gap isn't on their device but I too have a gap. Its small and the two display units at my Verizon store and my friends have the gap too. No big deal, I'm not exchanging it over what appears normal. Even pictures online appear to have the gap although you won't see the gold color.
    Sent from my Motorola Droid Turbo
    11-01-2014 07:06 PM
  9. arisenfury's Avatar
    My screen has this, starts from the top and goes down an inch or so. Not very noticeable and depending on viewing angle sometimes it goes away.
    11-01-2014 07:14 PM
  10. Zachtheowl's Avatar
    I exchanged mine today due to battery draining unusually fast...
    New one has noticeable color temp/,brightness difference left to right most noticeable on keyboard. Left looks dark slate gray right looks more tan gray. Defective?
    11-01-2014 07:29 PM
  11. Xelios's Avatar
    Yeah I'm going to return mine. On the minimum brightness, everything has a purple or pink tint to it. Nothing is fully black. This is frustrating. On the gallery when I'm view a photo and it isn't full screen, the background is like a bluish color instead of black too. Gotta be an issue.
    11-01-2014 08:01 PM
  12. latinusmaximus's Avatar
    Just got mine yesterday and it does have a pinkish/purple tint at the top of the screen that takes up about 1/3 of the screen. Also the phone got really hot while charging I downloaded GSam Battery Monitor and the internal temp got to 113 F. I did a little test and charged it to 100% right before going to sleep and left it off the charger for about 6 hrs and the battery drained 10% while on sleep mode. There is def something up.
    11-18-2014 08:13 AM
  13. Danny1Bears3's Avatar
    I noticed this as well but its not like REALLY PINK its like you look st it and say "is that pinkish? I can't even tell..." So it doesn't bother me. Also, if you turn up your brightness, it goes away.
    11-18-2014 09:38 AM
  14. Danny1Bears3's Avatar
    That temperature is normal. Mine did that as well. The engineers knew that would happen.
    11-18-2014 09:39 AM
  15. latinusmaximus's Avatar
    I got my wife the same exact phone and hers doesn't over heat and has a crystal clear screen. If I turn up the brightness it is less noticeable but its still not normal. If I'm paying 650 for a phone I expect it to work as designed.
    11-18-2014 12:06 PM
  1. Tempered Glass Screen Protector
    By Kaiser Droid in forum Verizon LG G2
    Last Post: 11-06-2014, 09:03 AM
  2. Shouldn't the Z3v get it's own section?
    By npaladin-2000 in forum Sony Xperia Z3
    Last Post: 11-03-2014, 11:33 PM
  3. Verizon Questions
    By Kaiser Droid in forum LG G3
    Last Post: 11-03-2014, 05:50 PM
  4. Replies: 1
    Last Post: 11-01-2014, 06:48 PM
  5. App or Widget to track cups water & other things?
    By pcguys in forum Android Apps
    Last Post: 11-01-2014, 06:31 PM
