1. dmiller440's Avatar
    I am looking for suggestions on the best way to use the Droid Turbo as an Alarm Clock.
    Hardware/Software suggestions appreciated
    Any cool setups or suggestions? Please post photos and ideas.
    Is there a good Bluetooth speaker with Qi Charging and NFC capabilities?
    11-01-2014 06:42 PM
  2. russel5150's Avatar
    I use mine. I downloaded Zedge for ringtones and I have one that will wake u up w a small heart attack.
    Stock alarm clock works fine I have never needed an extra app for it
    Search wake up alarm clock on zedge.. It works for me
    dmiller440 likes this.
    11-01-2014 10:30 PM
  3. tech_fan's Avatar
    I have my Note 3 on a desktop stand. Its a universal stand made by Spigen which can be ordered by Amazon. My Moto 360, when put in the charging unit turns into a nice horizontal clock. I use the Timely app for my alarm clock. It has some real cool functions like a gradual alarm clock.
    11-01-2014 10:33 PM
  4. Bamzilla's Avatar
    I'm doing the same thing I did with my Galaxy Nexus: stock alarm with the neon tone. So much nicer to wake up to than my old click radio beeping loudly. The app timely is nice as well. Google bought the company for its talent I believe.
    Sent from my XT1254 using Tapatalk
    11-01-2014 11:19 PM
  5. ancientdroid's Avatar
    My favorite alarm app which I have used for years is Gentle Alarm. It has never failed and has numerous options. It is in desperate need of a UI refresh though. It hasn't been updated in a while though which has me concerned. Timely is nice has well though it doesn't have some features like quick alarm which I like on Gentle Alarm.
    Using either with something like a Vu Tylt wireless charger is the perfect combination for a bedside alarm clock.
    11-02-2014 01:27 AM
  6. doogald's Avatar
    Fwiw, if the turbo is like last year's droids, there is also the daydream mode if you want the phone to actually display the time while charging. Settings, display, daydream. There is an option on the bottom, when to start, and you can change that to be while charging. This starts a display when the display would normally time out and shut off. There should be a list of several apps that can be used, though I've found that all but droid dream keep the capacitive buttons lit on the droid maxx.
    I personally wouldn't use this because I'd be worried about wearing out the amoled display, but some people like it.
    dmiller440 and Rogus like this.
    11-02-2014 07:17 AM
  7. dmiller440's Avatar
    Thanks. This looks like a good option. Is there actually a risk of burn in or wearing out the screen? The capacitive buttons appear to be off in that mode. The MDT also seems to have a sleep mode that is set from 11pn-6am as default. Is this a Moto or Android Feature?
    11-02-2014 07:40 AM
  8. Codger1212's Avatar
    So the alarm clock I use is Clock JB+ and here is why. It is similar to the stock clock app (jelly bean style) but color customizable. You can also set it to open up with the alarm screen. The most important thing to me though is the capacitive buttons stop glowing unlike with other alarm apps I have tried. Wish the stock app would offer these options.
    11-02-2014 07:44 AM
  9. doogald's Avatar
    That's moto. I think you're describing moto display, which flashes unread notifications on the display when it's off. That can be set not to show while you're sleeping for a time period you choose, yes. Also the assist app can turn off sounds at night.
    I've read reports of amoled burn in before. There are actually apps that are supposed to reverse it. Screen Diagnostic is one. I tested my year old Droid Maxx with it a few weeks ago - it had no burn in.
    https://play.google.com/store/apps/d...een.diagnostic
    So, you could try out daydream for a few weeks and then use that app to look for burn in.
    11-02-2014 08:35 AM
  1. Moto Voice: What are you calling your Turbo?
    By Firedogee in forum Motorola Droid Turbo
    Last Post: 07-13-2015, 10:31 AM
  2. Replies: 8
    Last Post: 11-03-2014, 08:38 PM
  3. Google Nexus 6 Courier Used by Google Play?
    By dvniel in forum Google Nexus 6
    Last Post: 11-01-2014, 11:58 PM
  4. Replies: 1
    Last Post: 11-01-2014, 07:54 PM
  5. Replies: 1
    Last Post: 11-01-2014, 06:51 PM
