12-08-2014 01:38 PM
31 12
tools
  1. Firedogee's Avatar
    Just came across this thread and hope it might help those of us who aren't happy with the maximum volume during a call.
    Voice privacy? - Android Forums at AndroidCentral.com
    Basically there is a setting in the phone app called Voice Privacy which supposedly decreases the max volume during calls. Try turning this setting off from within the phone app and see if it helps.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-02-2014 05:43 AM
  2. Firedogee's Avatar
    Just switched it over an hour ago. Gonna do a power cycle and then try some calls with friends later. Will let you know.
    11-02-2014 07:13 AM
  3. russel5150's Avatar
    I turned mine off, and haven't had a darn call since!! I like it already!! Lol
    stridr69 likes this.
    11-02-2014 07:36 AM
  4. Rogus's Avatar
    It made a difference for me.
    11-02-2014 09:32 AM
  5. delrey1900's Avatar
    Didn't I suggest that to you yesterday on another thread, lol!
    11-02-2014 10:25 AM
  6. doogald's Avatar
    I am pretty sure that voice privacy is not meant to decrease volume but it encrypts calls end to end so that they cannot be eavesdropped. That said, calls are already encrypted, so I doubt that it will cause much concern if it is turned off.
    See calls - What does the voice privacy setting do? - Android Enthusiasts Stack Exchange
    11-02-2014 12:32 PM
  7. Firedogee's Avatar
    Sorry, I must have missed that Delrey! Thanks.
    PS. How are you liking your Moto X?
    11-02-2014 01:39 PM
  8. parkschr1's Avatar
    Where is audio effects in the sound settings? I must be blind.
    11-04-2014 04:19 PM
  9. doogald's Avatar
    From home, settings / sound. Should be the second option listed after volumes.
    11-04-2014 04:41 PM
  10. kjjb0204's Avatar
    Didn't seem to help. I had to experiment with the placement of the very top of the phone to be directly on top of my ear canal to really get loud enough sound. I'm on bluetooth enough though that hopefully it doesn't impact my needs.
    11-04-2014 05:17 PM
  11. parkschr1's Avatar
    Man! I do not have that option on my droid turbo. There is no sound effects choice.
    11-04-2014 08:08 PM
  12. parkschr1's Avatar
    My choices under sound is:
    volumes
    phone ringtone
    phone vibration pattern
    vibrate when ringing
    default notification sound
    dial pad touch tones
    etc
    11-04-2014 08:15 PM
  13. Firedogee's Avatar
    volumes
    phone ringtone
    etc
    It's the second option, just below volume. It's called audio effects.
    11-04-2014 08:20 PM
  14. parkschr1's Avatar
    Shoot. I must have a different software version or something. There is no sound effects on this phone. Thanks for trying.
    11-04-2014 08:37 PM
  15. parkschr1's Avatar
    Audio effects is on my old razr maxx in the exact spot everyone is telling me. But not my droid turbo. I did do the update. Maybe that is why it is not there. Maybe there will be a fix.
    11-04-2014 09:32 PM
  16. markymark's Avatar
    I don't have the Turbo, but on my RMHD there is an alternative way to get into Audio Effects. Open up the Google Play Music app, open up the menu (top left corner). Go into Settings and select Equalizer. See if this works.
    11-04-2014 09:39 PM
  17. Danny1Bears3's Avatar
    I found today that since the ear piece is so high up, I have to hold the phone lower than I'm used to in order to have my ear canal in the direct path if the ear piece. Might be a stupid suggestion but it helped for me...
    Turbo-Shot from my Ballistic Turbo
    11-04-2014 09:46 PM
  18. parkschr1's Avatar
    Dont have the equalizer choice. Thanks for trying to help.
    11-04-2014 09:47 PM
  19. parkschr1's Avatar
    Danny, I noticed just a while ago that by doing that it helped. It just felt a little awkward, but this may be the only option right now. Thanks buddy.
    11-04-2014 09:49 PM
  20. Retinella's Avatar
    I tried that and turning off voice privacy made no difference in the call volume.
    Posted via the blazing fast Motorola Droid Turbo (64 GB).
    11-04-2014 10:08 PM
  21. Njbrandon's Avatar
    Would turning up the voice and treble on the EQ raise the overall volume?
    11-05-2014 09:52 AM
  22. Firedogee's Avatar
    Let us know if you try it?
    11-05-2014 10:33 AM
  23. kjjb0204's Avatar
    Worth a shot. I changed to Vocalizer and will try a couple of calls and report back.
    11-05-2014 10:39 AM
  24. asylvia's Avatar
    how did changing the equalizer work? i'm having this issue as well. sounds like we need an update to fix this.
    11-05-2014 10:46 AM
  25. Cajun_Mike's Avatar
    Is it likely the low ear piece volume is a low wattage issue rather than a software issue? Can't be fixed by a software update because there's just not enough power going to that driver?
    11-05-2014 12:34 PM
31 12
  1. Droid Turbo defective battery? any one see this?....
    Last Post: 12-11-2014, 05:34 AM
  2. Replies: 2
    Last Post: 11-08-2014, 10:24 PM
  3. Replies: 1
    Last Post: 11-07-2014, 01:26 AM
  4. Is there a fixe to blank screen on zeepad?
    Last Post: 11-06-2014, 11:56 PM
  5. Replies: 0
    Last Post: 11-06-2014, 08:36 PM
