1. Dojam's Avatar
    I'm currently at a Verizon store buying the Droid Turbo and will waiting in line I wonder how many IR sensors are present on this phone. Seems like it's only one at the very top by the front facing camera. Will swiping my hand by the bottom of the phone does nothing and only when swiping around the top of the phone does actually active the display. Any takes on this? So I'm assuming the function of turning the screen off if not looking at it doesn't matter in this phone since the battery is huge...!
    11-02-2014 11:58 AM
  2. shamo316's Avatar
    there is actually 4 ir sensors. 1 on each corner of the droid turbo. go to a dark room and tilt it side to side and youll see some of them
    11-02-2014 12:25 PM
  3. Dojam's Avatar
    I really need to be enlightened. I just try on a dark room, looking thru the camera of my Moto X at the Turbo and there is only one light in up... What I'm missing, cause at the display unit Moto X (14) at the Verizon store I could swipe my hand by the bottom part and the screen will turn on... not with the Turbo!
    11-02-2014 02:32 PM
  4. whtchdr's Avatar
    It does have 4 sensors. Mine lights up with pretty much any movement nearby.
    Sent from my XT1254 using Tapatalk
    11-02-2014 02:34 PM
  5. jesta192's Avatar
    Impressive! It's not so obvious on the Turbo (compared to the X.14) but is there.
    11-02-2014 08:31 PM
  6. MA2GA28's Avatar
    I just noticed something, actually. In a slightly dim, sunlit room, I can actually see 3 IR sensors turn on if I hold the phone and don't move. One on each bottom corner and one in the top right corner, all glowing very dim red. Then, they all go out after a second. At the first slight movement, they come on again, and if there's more movement, the Moto Active Display comes on.
    What shocks me is I JUST noticed the dimly lit sensors now, after over 2 weeks with the phone. Does anyone else see the IR sensors come on?
    11-19-2014 01:41 PM
  7. NoahForeman's Avatar
    All the time
    Posted via the Android Central App on my Droid Turbo.
    11-19-2014 02:56 PM
  8. bizzyqu's Avatar
    they only come on when screen is off I believe btw
    11-19-2014 03:12 PM
  1. Motorola Droid Turbo XT1254 Disassembly / Teardown Video
    By pwrdbykyank in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 01:30 PM
  2. How do make my device support GPS and compass sensors?
    Last Post: 11-03-2014, 12:04 AM
  3. Turbo vs Maxx Video Comparison
    By Snareman in forum Motorola Droid Turbo
    Last Post: 11-02-2014, 08:50 PM
  4. Replies: 1
    Last Post: 11-02-2014, 04:28 PM
  5. Got Droid Turbo then factory reset old phone... it said activated?
    By NoahForeman in forum Motorola Droid Turbo
    Last Post: 11-02-2014, 10:35 AM
