1. rxgadget's Avatar
    Anyone know difference between the 2 on a normal basis yet?
    What about Qi vs normal wall charger
    Sent from my SCH-I535 using Tapatalk
    11-03-2014 04:13 AM
  2. iamtron's Avatar
    Just got my qi charger. Got a Nexcon® Qi Enabled Wireless Charger Inductive Charging Pad Station from Amazon for $14. Did a quick test. Phone charged from 75% to 94% in 1 hour. That's about what I was expecting. I'm planning to use the qi charging at night, so I can just put the phone on it when I go to bed.
    The charging coil is in the lower half of the phone. The phone will display an image telling you to line it up with your charger when it detects a qi charger near by.
    11-04-2014 03:34 PM
  3. markymark's Avatar
    Does wireless charging still work if you have a case on the phone?
    11-04-2014 03:54 PM
  4. iamtron's Avatar
    I don't have a case yet. I'll post once
    I get one. The charger I got says 4-10mm distance so it should
    11-04-2014 05:52 PM
  5. NoahForeman's Avatar
    I have 3 Qi chargers and have not even used the Turbo Charger yet. If I do I will be sure to comment on the differences.
    Posted from my Droid Turbo via the AC App
    11-04-2014 05:57 PM
  6. iamtron's Avatar
    Got my case today. It is just the silicone cover that Verizon sells. it is pretty thin. But my Qi charging doesn't work with the case on. Maybe a better charger would. I just bought the cheap "Nexcon® Qi Enabled Wireless Charger Inductive Charging Pad Station for All Qi Standard Compatible Devices" from Amazon to try it out. I'm not really worried about it at this point but did want to share my findings.
    11-08-2014 02:31 PM
  7. bizzyqu's Avatar
    A qi charger can work through an otterbox
    11-08-2014 02:43 PM
  8. Eclipse2K's Avatar
    It must be the charger because the Tylt Vu worked on my Droid Maxx with a Diztronic case on it and others reported it with Otter box.
    Sent from my Motorola Droid Turbo
    11-08-2014 02:52 PM
  9. jerrykur's Avatar
    I do not have a turbo, but both my DNA and nexus 7 charge when they are in their cases. I use Nokia Qi chargers.
    11-08-2014 07:40 PM
  10. mmohn01's Avatar
    I have the Incipio hybrid case, and wireless charging works fine.
    11-08-2014 08:04 PM
  1. Verizon Motorola Droid Turbo Total charge time from empty to full
    By rxgadget in forum Motorola Droid Turbo
    Last Post: 11-07-2014, 03:08 PM
  2. Turbo vs Maxx charging speed
    By Snareman in forum Motorola Droid Turbo
    Last Post: 11-03-2014, 05:23 AM
  3. Replies: 0
    Last Post: 11-03-2014, 12:05 AM
  4. Coming from Droid Turbo to Note 4
    By tech_fan in forum Samsung Galaxy Note 4
    Last Post: 11-02-2014, 11:38 PM
  5. Why isn't my screen working on my Droid Turbo?
    Last Post: 11-02-2014, 09:54 PM
