1. ctenc001's Avatar
    My phones rebooted on its own at least once a day since I got it last week.
    Anyone else having similar issues?
    Also is their any way to disable the boot-up sounds? Never understood why some manufacturers/ Verizon insists on a noisy boot-up..
    11-03-2014 05:43 AM
  2. -Myk-'s Avatar
    I would return it ASAP
    11-03-2014 05:53 AM
  3. -Myk-'s Avatar
    Did you take the plastic off the screen?
    xweb10 likes this.
    11-03-2014 06:23 AM
  4. Clocks's Avatar
    Reboots are likely caused by an app you installed.
    11-03-2014 07:19 AM
  5. Firedogee's Avatar
    I have a feeling this will be a long running joke on these threads. And I laugh every time!
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    11-03-2014 08:46 AM
  6. ctenc001's Avatar
    Is there a restocking fee?
    I doubt "my phone reset itself yesterday" is a good enough reason for them to give me a new one..
    As for apps I installed:
    Facebook
    Twitter
    Dropbox
    Great Little War 1 and 2 (Probably my favorite android series atm) Had the issue before installing these..
    Flixter
    And Chromecast.
    Nothing to out of the ordinary, so I don't think this would be the problem
    11-03-2014 10:20 AM
  7. michaelc#AC's Avatar
    Mine's doing the same thing. Sometimes opening up a web page, sometimes entering a wifi area sometimes answering the phone. Happens daily.
    11-03-2014 09:14 PM
  8. Firedogee's Avatar
    Are either of you guys using launcher apps?
    11-03-2014 09:32 PM
  9. -Myk-'s Avatar
    Did you not see this? Seriously if you buy something and it doesn't work correctly then why keep it. Exchange it for one that does work correctly.
    11-03-2014 09:34 PM
  10. ctenc001's Avatar
    Mine has only happened once while out of pocket. The other times have always been while in pocket and out of use.
    If its a common issue theirs no reason to return it, I'd just wait for a software update. If I'm alone, which its beginning to look like I may be, then it'll be getting returned..
    As for returning, since I can not really replicate the instability of the OS while in store, how would I avoid restocking fees, assuming their is one? Any experience or advice?
    No launchers here. I posted every app I've installed to date above.
    11-04-2014 05:37 AM
  11. Clocks's Avatar
    If it's broken, even if it's just because you left the screen protector on, you can exchange it without a fee.
    Source: I did it
    11-04-2014 06:02 AM
  12. -Myk-'s Avatar
    You go in there and tell them the phone has a manufacturers defect that happens intermittently on its own and you have not found a way to manually reproduce the issue. Do a factory reset before you go in and tell them you did what troubleshooting you could, looked on the internet for others that were seeing the same thing, and did a factory reset and the phone still has the issue. Tell them you would like a replacement because the one you were sold is obviously a lemon.
    11-04-2014 06:04 AM
  13. Firedogee's Avatar
    Source: I did it
    This ^^^^^
    Caught that clocks.
    11-04-2014 06:09 AM
  14. Firedogee's Avatar
    Yeah, and demand some other **** while you're on a roll, like a bunch of power cords or maybe like 30 sets of earbuds. Make sure to howl and throw some stuff for effect.
    11-04-2014 06:13 AM
  15. -Myk-'s Avatar
    I've gotten lots of free stuff with my approach, I am always tactful and polite.
    11-04-2014 07:26 AM
  16. Firedogee's Avatar
    I think my joke went over your hood
    11-04-2014 09:18 AM
  17. anon(1733)'s Avatar
    Start running circles around the store swinging your arms around while screaming. Don't stop either. Keep running around until your issue is resolved and you get a boat load of free stuff. Of course I'm joking.
    11-04-2014 09:54 AM
  18. Firedogee's Avatar
    LOL! I bet any kids that might be in the store would think it was follow the leader and join in :P
    anon(1733) likes this.
    11-04-2014 10:19 AM
  1. Replies: 5
    Last Post: 11-29-2014, 04:24 PM
  2. A few questions about Cricket and phone compatibility
    By zeth006 in forum General Help and How To
    Last Post: 11-09-2014, 07:06 PM
  3. How do i retrieve contacts from lost phone?
    Last Post: 11-03-2014, 01:48 AM
  4. What Phone Should I Get?
    Last Post: 11-02-2014, 09:49 PM
  5. Replies: 1
    Last Post: 11-02-2014, 09:45 PM
