I'm not sure but mine *seems to* update every time the screen unlocks.I'm trying to see how to increase the refresh rate of the stock command center weather widget
Tried that same results.Reboot to fix. First thing I do with any trouble shows
Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
Mine only refreshes when I click on it.
Thanks I'll try that.Mine only refreshes if I've got it set to current location. If I had it on a city by using zip code it wouldn't refresh. Now that I've got it showing current location via location services it seems to refresh.
