1. hal1's Avatar
    I'm trying to see how to increase the refresh rate of the stock command center weather widget
    11-03-2014 11:42 AM
  2. galpdawg's Avatar
    don't think there is a way to change any of the settings with that yet, hopefully moto will give us some options
    11-03-2014 09:39 PM
  3. maxman1's Avatar
    I'm not sure but mine *seems to* update every time the screen unlocks.
    11-03-2014 10:51 PM
  4. VZWsucks's Avatar
    I too am having an issues with the wife's phone. The refresh is slow, as an example.... When it's morning and you wake the screen it still shows the temperature from the night before. She said it didn't used to be so slow. Any suggestions to help improve this?
    Sent from my DROID Turbo64 via Tapatalk
    01-03-2015 01:23 PM
  5. 1Coopgt's Avatar
    Could be somethings up with the Weather stations in your area that report to Accu Weather . It may not be the refresh rate of the app. that is the problem.
    VZWsucks likes this.
    01-03-2015 06:55 PM
  6. leehardballer12's Avatar
    Mine got stuck on the previous day info once. I didn't think much of it, until it stayed like that the entire day. I just restarted my phone and its been normal ever since.
    01-03-2015 07:04 PM
  7. wseyller's Avatar
    The temp on mine doesn't seem to update anymore either unless I open it up.
    01-03-2015 11:07 PM
  8. rxgadget's Avatar
    Reboot to fix. First thing I do with any trouble shows
    Sent using my Verizon Turbo charged 64GB Ballistic Nylon phone unfortunately with a case on back
    01-05-2015 12:55 AM
  9. VZWsucks's Avatar
    Tried that same results.
    01-05-2015 01:48 AM
  10. canawler's Avatar
    Mine often reports weather that's not even close, like 90° when it's 30° in January. It's definitely not a phone issue as my Razr M also did this frequently. It also isn't a weather reporting issue from one location because the other locations saved in the app are showing the wrong temps as well, almost like the app or Accuweather is displaying temperatures for the wrong date??
    01-05-2015 07:59 AM
  11. Billy Bixby's Avatar
    Mine only refreshes when I click on it.
    01-07-2015 10:44 AM
  12. anon(9228075)'s Avatar
    Mine only refreshes if I've got it set to current location. If I had it on a city by using zip code it wouldn't refresh. Now that I've got it showing current location via location services it seems to refresh.
    01-07-2015 03:56 PM
  13. VZWsucks's Avatar
    Thanks I'll try that.
    01-07-2015 04:53 PM
  14. Billy Bixby's Avatar
    Thanks, that worked.
    01-08-2015 03:51 PM
  15. VZWsucks's Avatar
    I just checked mine and it still doesn't work after changing to current location... Says I'm in Palm city, CA vs. Chula Vista CA.... I give up.
    Update: just Googled palm city CA, apparently it's a city that I'm not aware of that's in chula vista... What sense does that make, This thing is nuts.
    01-08-2015 03:54 PM
  1. Replies: 1
    Last Post: 03-29-2015, 08:38 PM
  2. Replies: 3
    Last Post: 11-03-2014, 03:22 PM
  3. does anyone have the stock moto x boot animation
    Last Post: 11-03-2014, 11:26 AM
  4. Replies: 0
    Last Post: 11-03-2014, 10:53 AM
