1. NoahForeman's Avatar
    Mine had a lot of wiggle. Anyone else?
    Posted from my Droid Turbo via the AC App
    11-03-2014 11:46 AM
  2. Firedogee's Avatar
    Mine has lots of wiggle. I kinda like it like that.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    NoahForeman likes this.
    11-03-2014 12:15 PM
  3. Masheen's Avatar
    I wondered when somebody would mention this. After a day or two, mine started to have a wiggle to it. Not to the point where it doesn't wok, but a noticeable wiggle where my volume rocker does not.
    11-03-2014 01:38 PM
  4. Firedogee's Avatar
    My volume rocker has slightly less wiggle, but still jiggles.
    You know what they say: if it's a wiggling, then don't come a.....
    11-03-2014 02:36 PM
  5. hal1's Avatar
    I have a power button?
    11-03-2014 03:04 PM
  6. Clocks's Avatar
    mine wiggles a bit, similar to the volume rocker
    11-03-2014 03:07 PM
  7. anon154738's Avatar
    My thoughts exactly!
    11-03-2014 06:54 PM
  8. beeztrain's Avatar
    Very loose. The only part of the phone that feels cheap. It may be because the Sim tray is attached to it though.
    Masheen likes this.
    11-07-2014 04:57 PM
  9. mightyfacundo's Avatar
    Exactly. After reading the post I actually had to check it since I never use it. It has a bit of wiggle to it, but nothing major.
    11-07-2014 05:10 PM
  10. dungoyle's Avatar
    My first reaction as well.
    11-07-2014 07:22 PM
  11. emad1995's Avatar
    How do turn the screen off then?
    11-25-2014 07:12 PM
  12. mightyfacundo's Avatar
    I have the display set to turn off after 30 seconds, but I also have the Attentive Display turned on so that the screen will stay on if I'm looking at it. Plus, I have the Battery Saver Mode turned on so that the screen will sleep sooner when I'm not looking. So, when I want to turn off the screen, I just set it down or put it in my pocket and it turns off on its own.
    11-25-2014 08:56 PM
  13. Kaiser Droid's Avatar
    No wiggle on my Dad's Metallic Red...
    11-26-2014 10:58 PM
  14. Masheen's Avatar
    This makes perfect sense. I was. Thinking of reasons that could cause this. It doesn't affect the function of the button, but still...
    11-27-2014 05:08 AM
  15. Darknessevo's Avatar
    Mine is loose it wiggles. Can't even press it really to turn off screen. Glad I got attentive display on or I'd be complaining.
    12-06-2015 01:46 PM
  16. StarjackerSeth's Avatar
    I don't have any issue with the power button, about a year in, nor the volume rocker. I've never taken the sim tray out except when first purchasing the phone though.
    12-08-2015 12:04 PM
  17. KSDroid01's Avatar
    Mine has a slight wiggle but in a year of use I probably have touched it maybe 50 times. I always turn on using the approach gesture, then let the screen time out to off unless it's going right back in my pocket.
    Posted via Moto Turbo
    12-08-2015 04:10 PM
  1. Replies: 2
    Last Post: 03-29-2015, 08:36 PM
  2. Is there a case that has an adjustable stand?
    By AnimalMotherASF in forum HTC One M8
    Last Post: 11-04-2014, 05:44 AM
  3. What phone locator app is best for Note 4?
    By ChemMan in forum Samsung Galaxy Note 4
    Last Post: 11-04-2014, 01:34 AM
  4. Replies: 0
    Last Post: 11-03-2014, 12:21 PM
