Anyone else having issues installing the driver for the Turbo? I tried to locate online but couldn't find one either. Installing Motorola's software didn't help either. This is on a Windows 7 machine.
I was able to work around the issue by just using the google driver install instructions below. I don't know how compatible the driver actually is but It found my device, and I was able to install the application
I can't post links but if you search "visual gdb manual usb install" on google the top result has instructions on how to install them.
