12-13-2014 07:28 PM
28 12
tools
  1. Ggoblue's Avatar
    I liked the browser on the old DROID 4 better than this chrome browser.
    Alternatives?
    11-04-2014 05:16 AM
  2. russel5150's Avatar
    There are lots of browsers, like dolphin, i really couldnt tell ya.
    I like using chrome beta, i havent had any issues with it
    11-04-2014 05:30 AM
  3. Firedogee's Avatar
    Have you tried AOL or Compuserve? They used to be the most popular.
    Sent Turbo-fast from my bulletproof 64GB Droid Turbo
    jesta192 and quantum tao like this.
    11-04-2014 06:15 AM
  4. FredBassett's Avatar
    I discovered this one a while back. Lightweight and fast. Love it. https://play.google.com/store/apps/d...obile.cb&hl=en
    11-04-2014 06:38 AM
  5. 1901Madison's Avatar
    It seems like every browser destroys battery. Anyone know of a browser that doesn't require as much juice?
    11-04-2014 08:11 AM
  6. mobrules's Avatar
    xScope pro and Firefox are the two I use mostly.
    11-04-2014 09:09 AM
  7. Ggoblue's Avatar
    Early returns have me loving the xscope pro. I was definitely open to paying for a Browser. $3 is a small price to pay to avoid ads.
    KPMcClave likes this.
    11-04-2014 10:40 AM
  8. Firedogee's Avatar
    I usually close Chrome from the apps tray of I'm not using it. Saves tons of battery.
    11-04-2014 10:50 AM
  9. mobrules's Avatar
    Exactly.
    11-04-2014 10:58 AM
  10. beeztrain's Avatar
    Alternatives?
    Dolphin browser seems to be the only one I've found to reliably load every page I've been to. You can sideload flash player for even more functionality.
    11-07-2014 04:48 PM
  11. dungoyle's Avatar
    Compuserve. Oh, those were the days. What was the saying? "Compuserve: Everything Sears knows about computing and everything IBM knows about retail."?
    11-07-2014 08:13 PM
  12. Codger1212's Avatar
    I really like the cm browser (clean master). Check it out.
    beeztrain and dungoyle like this.
    11-07-2014 09:03 PM
  13. maxman1's Avatar
    I tend to prefer different browsers for different things & one of my favorites does not run on Kitkat. After a good deal of trial, error & research I found the Baidu Browser. Don't let the odd name fool you, it's laid out beautifully, is blazing fast and once you learn it's features, is just very slick - worth a serious look as an alternative. I use Chrome, Baidu & Dolphin Mini - suits my needd.
    dungoyle and VZWsucks like this.
    11-07-2014 09:23 PM
  14. dungoyle's Avatar
    Thanks for the recommendations guys. I don't really want to install firefox again which was okay, but not exactly a small footprint; but I did want to try something new, and "light on it's feet", and your two recommendations seem to fit that bill based on a little cursory research after reading your posts. I've installed both and will give them a try over the next few weeks.
    11-08-2014 06:48 AM
  15. maxman1's Avatar
    I'd be interested in your thoughts on Baidu - I love the ability to quickly switch in/out of full screen mode and sliding the bottom tool bar to zoom. Using it more & more.
    11-08-2014 04:34 PM
  16. hannsoft's Avatar
    Loved that service. But daaamn, expensive! But my 14.4k modem got me on and off in a flash! ;-)
    Sent from my Droid Turbo using Tapatalk
    11-08-2014 05:06 PM
  17. hal1's Avatar
    Dolphin with jetpack has word wrap/text reflow the works on many pages with zoom.
    11-10-2014 10:21 AM
  18. beeztrain's Avatar
    I switched to cm browser and haven't looked back. Thanks!
    Codger1212 likes this.
    11-16-2014 09:01 PM
  19. 1BlinkGone's Avatar
    Well, I've been using Firefox for the continuity between my laptop & Smartphone. I just picked up Baidu to mess with after I got my Turbo. Yes, it's speedy...But, I'm going to try CM Browser...mucho props for it that I can't ignore. I suppose I could transfer all my bookmarks to it from FF.
    11-16-2014 11:37 PM
  20. VZWsucks's Avatar
    I tried the Baidu browser and I like it, it's really nice just as you said. One major issue for me is I'm having trouble with sites that require a login (site/browser has an error when username an password are put in). Have you experienced this or have any setting suggestions?
    Sent from my DROID Turbo64 via Tapatalk
    12-12-2014 03:28 PM
  21. maxman1's Avatar
    None & I'm signed into a bunch of sites. I might add that both Baidu & the CM browser share the same engine & are very similar with just minor UI differences separating them. Both are blazing fast, both have speed dial, both remember zoom settings & both have (thankfully) an exit button. I'd like to drop one of them but can't decide which so may keep both.
    12-12-2014 04:52 PM
  22. VZWsucks's Avatar
    Ok thanks I'll play with it some more and DL the cm browser and give it a shot too. Thanks again, I appreciate your insight.
    12-12-2014 05:05 PM
  23. HappyFunBall24's Avatar
    I'm a CM Browser convert, going away from my ole standard Dolphin + Jetpack - just no contest. It's so lean and mean, and has some good security options.
    12-12-2014 06:28 PM
  24. maxman1's Avatar
    It is excellent and as I said, identical to Baidu under the hood. I used Dolphin Mini for years as s lightweight browser but either/both of these are light years ahead. I will say that the Droid Turbo is the first device I've owned that doesn't bog using Chrome. I'm using it for most generic searching but for sites I visit daily, it's Baidu or CM. Freaking instant response in a pretty well equipped browser.
    12-12-2014 06:49 PM
  25. HappyFunBall24's Avatar
    ^^ I know nothing about Baidu. What features do you like about it over CM Browser?
    12-12-2014 07:00 PM
28 12
  1. Verizon Motorola Droid Turbo Stock keyboard or SwiftKey?
    By yourfamilybank in forum Motorola Droid Turbo
    Last Post: 02-18-2015, 09:40 PM
  2. Droid Bionic, (no sim) wont download anything??
    By squishsquish in forum General Help and How To
    Last Post: 12-14-2014, 11:55 PM
  3. Replies: 1
    Last Post: 12-14-2014, 06:08 AM
  4. Verizon Motorola Droid Turbo Unable to use Google voicemail w/ turbo
    By Billy Bixby in forum Motorola Droid Turbo
    Last Post: 12-14-2014, 12:58 AM
  5. Why is my Droid Razr Maxx HD update failing?
    By TheZakbking in forum Ask a Question
    Last Post: 12-14-2014, 12:24 AM
