switching between WiFi and 4g
Louis Tropia
If my WiFi is on and its not a strong signal it doesn't switch to 4g data automatically . on my galaxy s3 there was a setting to change automatically I don't see it on my droid turbo.I'm trying not to keep WiFi off so as to not use all my data
Any one have the solution?
camachinist
92
There is a check box in the 'Advanced Wi-fi' settings to 'avoid poor connections'.
That would be: settings>wi-fi>three lower right dots>advanced
Unclear if that would help. It doesn't generate a notification that I can see.
Almeuit
Moderator Team Leader
Moderator
Apr 17, 2012
32,277
23
This should help -- Same function as the one on the Galaxy.
Firedogee
Banned
Sep 30, 2014
826
If you want Wifi always on then you need to UNCHECK that box and also select the other option for always on.
Sent Turbo-fast from my bulletproof 64GB Droid Turbo
pierre5463
