Some observations after mine finally showed up, compared to my GS4.
The screen is a warmer color temp and I prefer it. White's are more pure white.
If it's any dimmer than the GS4, thus far it's minor and I can hardly tell it using bright lights inside. It got dark before I made it out. Blacks are notably blacker on the GS4, and grays are.. different. I think I have the GS4 set to "professional" or whatever it was fwiw.
Overall I'm pleased with the screen, it's sharp as a razor, pleasant colors, bright and dark enough, these things take time to get used to put it looks like my IPS monitor compared to my LCD in a lot of ways(I run them side by side).
I've been walking around with a wifi analyzer running on both phones observing wifi reception, and sadly the GS4 is clearly superior. I have some screencaps but even within a foot of the router the DT was five dB off of the GS4. Difference was more pronounced in a bad signal spot (my shop). I will say the little graphical icon up top, the DT is pessimistic or the GS4 is optimistic, there was a difference in dB but it wasn't as dramatic as I'd have assumed from the bars/lack of on the icons. Don't believe BS icons.
Have not checked cell reception other than it's so-so in my living room on both phones, solid 4g but not by a lot. No 4g on the GS4 after upgrade so someone else will have to screw with that. That said, I don't think it'll be a problem unless you have chronic weak wifi somewhere you need to use a phone regularly. If this is the case it'll probly be annoying unless what you are coming from is worse.
Media playback is plenty loud and sounds noticeably better, way better, than the BS speaker on the back of the GS4. I haven't touched the EQ on the DT or any of it's settings, whatever it came with is what I'm basing this on. I've yet to make a phone call but vibes are good as are notification volumes.
It's fast. Noticeably faster than the GS4. It's still not perfectly fluid every second ready to run run run, but it's fast as anything else I imagine. You can really feel the extra umph rapid fire installing apps and still having the device be useable, the GS4 would bog for a few seconds installing stuff, much less so the DT. I think the out of the box state had 50gig or so free space listed.
It's barely bigger than the GS4, not enough to notice to me personally. Feels great, I like the bay-les-tek nylon feel a lot, it's probly more scratch resistant than most backings but I doubt it has anything to do with "strength" either way. But I dig the feel a lot, not slippery.
I think it looks fine but that's subjective. Feels solid. Which isn't saying a lot coming from a GS4 but it'll go in a case before too long and all that's irrelevant anyway.
Will report later if anything interesting comes up. Haven't touched the camera yet.
Looking forward to the L update, though good on them for not screwing with the UI any more than they did.
Reminds me of Cyanogenmod on my GS3, which is cool.
