1. Davidoo's Avatar
    On all my past Android phones in the dialer you could go to settings and see a list of numbers you blocked and add new ones to your blocked list. Where is this in 4.4.4?
    11-06-2014 12:25 AM
  2. Davidoo's Avatar
    OK, no one has figured out how to block certain callers by phone number on this device? On my prior S3 there was a call settings menu where you could block the last caller, add any number to the blocked call list, and review/edit the list of numbers you have put into the blocked call list. I can't even find a call settings menu at all on this device. Otherwise love the Turbo, but I'm finding the menus that come up when you touch the 3 little dots are bare bones compared to what was on my Samsung when you hit the settings/menu capacitive key. I suppose there is an app for this, but I know it is already part of the OS, it is just not showing up anywhere.
    11-07-2014 06:48 AM
  3. udazavlanje's Avatar
    Only through Google Voice (from the desktop). And maybe some specific OEMs like Samsung used to have.
    via AC App on VZW Moto X DE/N7
    11-07-2014 06:54 AM
  4. brybelle22's Avatar
    If you have the number in your contacts, you can go to that contact and from the menu select the number to be sent directly to voicemail. Not exactly a block, but it will at least keep the number from ringing in.
    Attached Thumbnails Verizon Motorola Droid Turbo Where did the Block incoming call setting go-1415364911109.jpg
    11-07-2014 06:57 AM
  5. bespinct's Avatar
    Just because it was on your S3 doesn't mean it is part of the OS (AOSP) . People knock TouchWiz all the time, but it definitely provides some features that folks rely on.
    I hope you find a solution that works for you.
    11-07-2014 06:57 AM
  6. Davidoo's Avatar
    Thanks for the replies. I wouldn't go back because of how good this beast is, but I guess I do miss some of the touchwiz features. I'm sure there is an app I can find to do this. I know I can block incoming calls from the Verizon website, but that is maxed at 5 and you have to reenter every 5 days.
    11-07-2014 09:30 AM
  7. SMILEY MIKE's Avatar
    I HAVE BEEN USING A CALL BLOCKER APP FROM devmain FOUND IN THE GOOGLE PLAY THERE ARE SEVERAL FREE APPS LIKE THIS
    04-10-2015 04:18 PM
  8. maxman1's Avatar
    Seems like a good app, is it ad supported & if so, is there an in-app purchase option to remove them? I've come to detest ads and will gladly pay a couple of bucks for a good app free of them.
    04-10-2015 07:32 PM
  9. mrtonk's Avatar
    In the menu for individual contacts, there is a "send to voicemail" option.
    04-11-2015 10:29 AM
  10. maxman1's Avatar
    I use this feature now. I entered a contact for "Blocked Caller" set to send to Voicemail and add any undesirable numbers to this contact. Works well enough but truly rejecting the call (gasp, ala iPhone call blocker) would be even better. Honestly, I cannot understand why it's not baked into the OS instead of relying on manufacturer customization.
    jyotinaik likes this.
    04-11-2015 02:01 PM
  11. psf57's Avatar
    Think Verizons is every 3 months. I have to reenter mine on the 16th. Works good too.
    04-12-2015 02:16 PM
  12. Don Miller7's Avatar
    02-28-2017 12:51 AM
  13. Don Miller7's Avatar
    Try adding the number to your contacts, go to hangouts and block them from there.
    02-28-2017 12:52 AM
  14. VZWsucks's Avatar
    The setting to send a caller to VM is under the contact. Select edit, then select 3 button in top right corner. A drop down will appear then check box send calls to VM.
    03-03-2017 01:32 AM
  1. Droid Turbo defective battery? any one see this?....
    Last Post: 12-11-2014, 04:34 AM
  2. Verizon Motorola Droid Turbo Top right speaker...
    By Danny1Bears3 in forum Motorola Droid Turbo
    Last Post: 11-11-2014, 06:21 AM
  3. Replies: 2
    Last Post: 11-08-2014, 09:24 PM
  4. Screen shots of the G3 on Lololipop
    By lrrowley in forum LG G3
    Last Post: 11-07-2014, 10:47 AM
  5. Replies: 0
    Last Post: 11-06-2014, 07:36 PM
