No rooting necessary. All you have to do is go to security and screen lock in settings. Check to allow installation from unknown sources. Then find the Microsoft office apk online. Download it and the download will appear in the notification bar. When its done, just tap it and tell it to install and bingo! Its because its not optimized for qhd displays. But it looks and works perfectly fine
