F fofjjsr Android4life Aug 18, 2011 1,026 7 0 Visit site Nov 6, 2014 #1 Is there a way to show the battery % on the status bar next to the battery icon?
C cyberr8der Well-known member Jun 26, 2011 245 1 0 Visit site Nov 6, 2014 #2 Re: Battery % Not stock. It's in the command center widget though. You can get gsam from the play store which will show the % if you don't mind using an app for it.
hal1 Well-known member Dec 1, 2009 1,269 8 0 Visit site Nov 7, 2014 #3 Re: Battery % Yup, you'll find Gsam universally accepted as the go-to battery app
J jec11718 Well-known member Mar 17, 2012 321 0 0 Visit site Nov 7, 2014 #4 Re: Battery % I'm using both. Posted via the Android Central App
